Go Back   Tundra Solutions Forum > Technical & Vehicle Assistance Forums > Aftermarket Products
KORE
Free Shipping at Buy.com!
FREE Personal Trainer Program
Aftermarket Products Discussions about aftermarket products and accessories.
This is a discussion thread titled "Tundra V-6 Manual Cruise Control", within the Aftermarket Products forum, part of the Technical & Vehicle Assistance Forums category.
Old 02-14-2006, 12:29 PM
orb orb is offline
Dealer : Koons of Annapolis Toyota
2005 Toyota Tundra
orb's Photo Albums
Last Online: 07-06-2008 05:31 PM
orb is on a distinguished road.
Default Tundra V-6 Manual Cruise Control
Has anyone found a aftermarket cruise control that will work with an '05 V-6 manual Tundra?
I bought and started the install on this unit:
http://www.mnrelectronics.com/totucrcokit2.html
only to find out halfway through that it really can't hook into the electrics.
thanks,
ed
Old 02-16-2006, 10:59 PM
RSLAND's Avatar
RSLAND's Photo Albums
Last Online: 03-29-2008 12:14 AM
RSLAND is on a distinguished road.
Default Re: Tundra V-6 Manual Cruise Control
Yeah, the lack of cruise on the V6 seems like an oversite. Can you use the one off the newer Tacomas? I wonder what that would cost? I would think they would use the same ECU since the engine and tranny are identical.
Rob
2002 SR5 V-6 5spd, Helwig Anti-Sway and helper springs. TRD supercharger. URD FTC. TRD headers. Spintech Muffler, Falken STZ 04 tires, Prodigy trailer brake controller, Smittybilt nerfs.
04 Acura TSX - 200 hp and 30 mpg
07 Civic Coupe - 37 mpg - who needs a hybrid?
Old 02-17-2006, 12:20 PM
orb orb is offline
2005 Toyota Tundra
orb's Photo Albums
Good idea, but I don't know. The Rostra kit was designed to work on later Tacomas too but the instructions for it showed a completely different wiring harness configuration.
It should work though. Anyone tried an OEM Taco cruise in the V-6 Tundra?
ed
Old 02-23-2006, 12:43 AM
Jdog's Avatar
2004 Toyota Tundra
Jdog's Photo Albums
Last Online: 06-16-2008 06:04 PM
Jdog is on a distinguished road.
I don't know what you guys are talking about. I own a 04 Tundra with a V6 5speed manual and it came with cruise control, which works great by the way.
Old 04-08-2006, 06:33 AM
Inactive Account
Dealer : Serra Toyota Scion
2005 Toyota Tundra
henrywl's Photo Albums
Last Online: 04-08-2006 06:35 AM
henrywl is on a distinguished road.
The '05 is a different engine implementation from the '04. The '05 has electronic throttle control, not a vacuum system like most other implementations. According to Toyota there is not currently an after purchase speed control for this engine/trans combo. Yes, a real oversight and something that troubles me. No after market folks had introduced one as of about six months ago. The thought here is that since there are so few Tundras that do no have the speed control there may not be a market for it. The hope is that Toyota will come out with one and if so it should be about $600.
Old 04-10-2006, 06:53 PM
orb orb is offline
2005 Toyota Tundra
orb's Photo Albums
Thanks for the info. Thought it must be something like that, since I think I have called every after market cruise control supplier out there. I alway get the same answer, "sorry buddy you're outa luck!".
You seem to be "in the know", if you hear about a kit being developed, please keep me posted.
thanks
orb
Old 04-14-2006, 03:15 AM
Dealer : Toyota of Greensburg
2005 Toyota Tundra
cookiemech's Photo Albums
Last Online: 02-07-2008 12:48 AM
cookiemech is on a distinguished road.
Here's something to investigate: I don't know anything specific about the 4.0 V-6, but when I bought my 2005 Tundra V-8 "work truck" I was disappointed to find that it did not come with factory cruise (though the brochure and website at the time said that it would). I researched the wiring diagram and the truck itself and found that ALL of the wiring was there for factory cruise; it just lacked the switch and harness in the steering wheel. After buying the cruise switch and harness (really just a short wire with connectors) for around $55, I installed it (had to cut a hole in the small plastic cover on the side of the steering wheel that covers the bolt for the airbag; this is where the factory switch goes). Guess what? Took it for a ride, hit the switch, the green "cruise" light illuminated on the dashboard, and the cruise worked just perfect!
Hope there is something available for yours. You will have to find a really good parts guy to help you; lots of them don't know how to order the right parts. My local parts guy (who is very good) told me that it was impossible; that I'd have to buy a new ECU and it was a several thousand dollar proposition. I wound up talking with Jaffarian Volvo-Toyota in Massachusetts.
Old 04-18-2006, 01:47 PM
orb orb is offline
2005 Toyota Tundra
orb's Photo Albums
Thanks for the suggestion, but unfortunately the V-6 manual does not come pre-wired. The Rostra kit I originally bought is designed to be plug & play for the Tundra, but it turns out only works on the V-8, just as you described.
Very frustrating since it would probably cost all of $1.98 for Toyota to add the wiring for the V-6 as well!
Orb
Old 10-25-2006, 09:08 PM
Dealer : Conicelli Toyota Scion of Springfield
2005 Toyota Tundra
camper2's Photo Albums
Last Online: 06-18-2007 02:27 PM
camper2 is on a distinguished road.
I also own '05 Tundra V-6 manual. I have been searching for a cruise control option. I have worked with a couple dealerships and sent letter to Toyota coporate. No success. Has anyone found a solution.
Old 12-02-2006, 01:01 PM
orb orb is offline
2005 Toyota Tundra
orb's Photo Albums
Nope, but still looking! If I hear of anything I'll definitely let you know.
Orb
Old 05-03-2007, 10:37 AM
Dealer : Jim Norton Toyota
2003 Toyota Tundra
ronc164's Photo Albums
Last Online: 02-07-2008 01:05 AM
ronc164 is on a distinguished road.
Does anybody have any suggestions for a 2003 v6 auto tundra work truck,
i am thinking about putting a cruise control in it . has anybody put an after market kit in this combo. thanks ronc164
Old 12-23-2007, 07:59 PM
orb orb is offline
2005 Toyota Tundra
orb's Photo Albums
It's the end of the year and I thought I would buy myself a little Christmas present, if it's around. Anyone come up with a viable cruise control, option for the V-6 manual yet?
Happy holidays!
Orb
Questions? Please use the Contact Us link. Dealer Hunter JPV Photography Consumer Electronics Hunter
