Ok so I paid the 18 bucks for the "Garage". There is a lot of cool stuff in there.
Including "HOW TO: How to add pre-amp outputs to the factory head unit in a Tundra. "
The write up is great but I cant get it to work. Ive cut and spiced the "line outs" from the HU to the Amp. I just spliced the common. If it is a line out I should not need the converter. Correct?
I made up four RCA conections using the common(white) and four other wires stated. My amp works fine(Tested with walkman), But i got nothing out of the HU.
To add more fuel to the fire, when I tried to see if I mis-wired anything and rechecked the HU stoped working.
Any help is GREATLY appreciated. With a good question I can get more specific for you.
ONe more: RCA common is on the outside or inside? Please tell me I just didnt answer my first question which created the second question.
thread moved to "Garage" by nhparrot, to respond to questions .
Correct - no converter. When you did the mod did you cut the black, blue, green and yellow? Also did you splice into the white, but leave it in continuity?
I moved this to the "Garage" for 2 reasons
1. I very rarely these days respond to specific electronics questions in the General forums
2. If this discussion gets technical with specifics, I do not want to give away what others have paid for.
If you check any of the wires with a multimeter and vary the volume on the head unit does the voltage change?
What did you mean when you said "when I tried to see if I mis-wired anything and rechecked the HU stoped working"?
If you reconnect the "cut" black, blue, green and yellow wires does the system work as before?
Where the wires you cut on pins 8,9,18 & 19 of the amp pigtail?
I cannot reconect and test. I cut the factory speaker wires out of the amp and routed to the new amp.
When I checked for miss connections(she's a beautiful girl) I had the common(white) on the center of the RCA so I switched them. I hope that was right. When I powerd back up there was still no output and more importantly no lights on the HU.
Now I cant test output voltage untill I get some input.
Were is the fuse for the stereo circuit? Label?
Im serously thinking about stopping by goodguys on the way home for a new HU. I can spend 3bills for my personal christmas present. OH...Maybe not i just bought a truck.
Do you have the whole dash re-assembled. The ACC and other power sources are passed through all the connects that plug into the oval piece that goes in front of the radio.
First time in the garage and this is as far as I got in my SEARCH for the HOW TO instructions for this mod.
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
Bilstein HD shocks
JBA headers
Hellwig rear bar
2005 tail lights
Tinted Windows
OEM Rubber Bed Mat
