LinkBack (18) Thread Tools Display Modes
  #16 (permalink)
Old 07-23-2007, 06:03 PM
PS-RagE's Avatar
Dealer : James Toyota - Timmins
Last Online: 10-12-2009 02:05 PM
PS-RagE will become famous soon enough.
PS-RagE's Photo Albums
Default Re: Worklog - Road RagE II
The brass mount for the radio antennas has a rubber O-ring and it is lubricated with silicon grease before tightening down. That GPS antenna is only sealed with the 3M adhesive so I put RTV on it from the inside.
Dale McLean
aka PS-RagE
House of RagE
See Road RagE II thread for details
  #17 (permalink)
Old 07-23-2007, 06:43 PM
PS-RagE's Avatar
Finally, I can install the head unit. I'm using an Alpine IVA-D105 multi-media unit.
Since I cannot install my own amplifiers, I have to use the JBL for now. I bought a Axxess TYTO-01 level shifter/harness to connect the two together. You can see it here along with the zillion wires from the head:
The navigation unit needs a connection to the speed sensor. Again looking in the schematics, I find it conveniently is located in one of the harnesses that was connected to the JBL:
It is pin 4 of connecter K9. Looks like this:
Also required from the JBL harness is the connections for the steering wheel controls. The schematic shows it to be pins 6,7 and 8 on connecter K3 (brown, light green and grey):
The steering wheel interface unit says to install a 560 ohm resistor between pins 7 and 8:
Don't think I mentioned it earlier but all spliced connections are protected with heat shrink:
Dale McLean
aka PS-RagE
House of RagE
  #18 (permalink)
Old 07-23-2007, 06:59 PM
PS-RagE's Avatar
I need both B+ and switched B+ for all the electronics. I fed a temporary run of #10 from the battery, through the firewall to the driver's side kick panel (temporary because I will be bringing a heavy line to the amplifiers later). Switched B+ is a bit more of a trick though. I discovered the cigarette lighter is a true ignition switch turning immediately on and off with the key. I don't smoke anymore and the plug is covered by the radio head so I cut the switched line from it and fed it over to the coil of a 30A relay:
Dale McLean
aka PS-RagE
House of RagE
  #19 (permalink)
Old 07-23-2007, 07:23 PM
PS-RagE's Avatar
Here is the head in the closed position:
The backup camera:
Navigation:
iPod interface:
DVD playback:
So there is the progress to date. I figure that is about a third of the work completed.
Dale McLean
aka PS-RagE
House of RagE
  #20 (permalink)
Old 07-24-2007, 07:50 PM
Dealer : Stevens Creek Toyota
Last Online: 09-26-2009 02:19 AM
outriderx is on a distinguished road.
outriderx's Photo Albums
Very nice work and nicely documented. I still can't get over those holes in the roof, I just don't think I could do it!
On the video feed, is the power switched? If not I assume the camera stays on whenever the truck is on? I believe factory design is to have the camera on in reverse only. I would be afraid of the camera burning out after prolonged use.
  #21 (permalink)
Old 07-24-2007, 09:33 PM
PS-RagE's Avatar
Yes, I have the camera on ignition switched power. These little CCD cameras can run 24/7 so keeping it powered while the truck is running is not a concern.
As for the holes - its gotta be done. Mag bases scratch and their cables vibrating in the wind wear out the paint. On-glass sucks. Permanent mounts look better and work better.
Dale McLean
aka PS-RagE
House of RagE
  #22 (permalink)
Old 07-24-2007, 09:37 PM
PS-RagE's Avatar
Originally Posted by Toxarch View Post
If the cigarette lighter is connected the same way the 12 volt power points are connected then you might have a problem. If the power point is feeding power to anything, then the power is not cut off when the key is removed. It actually keeps feeding power to the device for 20 minutes(?). It might be longer. So using it as an ACC switch might not be a great idea.
The cig lighter is true switched - it shuts off immediately with the ignition.
Dale McLean
aka PS-RagE
House of RagE
  #23 (permalink)
Old 07-25-2007, 01:42 PM
Last Online: 02-11-2008 12:52 PM
smithrob26 is on a distinguished road.
smithrob26's Photo Albums
Holy "F"
Sounds like a crap load of work but looks great.
  #24 (permalink)
Old 07-25-2007, 01:53 PM
Dealer : Toyota Of Fort Worth
Last Online: 11-19-2008 08:06 PM
walkerkd is on a distinguished road.
walkerkd's Photo Albums
awesome job!!!!!!!!!!!!!!!!! thats very good write up!
2007 Black CM 4.7 sr5 First Gas Truck and i love it!!!
2006 Ford F250 CC Diesel (60k)
2004 GMC CC 6.6 Diesel 440 hp/770tq (198k)
1986 Ford F350 CC 6.9 Diesel (795k)
1984 Ford F250 XC 6.9 Diesel (275k)
  #25 (permalink)
Old 07-25-2007, 03:47 PM
Last Online: Yesterday 11:14 PM
Images: 1
cliff clavin is on a distinguished road.
cliff clavin's Photo Albums
nice work. i hope you plan on keeping your vehicles for awhile, because drilling the holes in the roof will deter some buyers...
  #26 (permalink)
Old 07-25-2007, 04:02 PM
PS-RagE's Avatar
In Northern Ontario, half the vehicles on the road are pickups and half of those have antennas permanently mounted in the roof. If I were to sell it though, I would cap off the antenna mounts. The truck is so tall (I'll show that later as well) that the caps would not be visible.
Dale McLean
aka PS-RagE
House of RagE
  #27 (permalink)
Old 08-06-2007, 05:24 AM
R0CKETMAN's Avatar
Last Online: 01-03-2008 03:32 PM
R0CKETMAN is on a distinguished road.
R0CKETMAN's Photo Albums
The attention to detail and what appears to be the mindset of "doing it right" IE cardboard sub box ect is impressive. I and trying to figure out how to mount/box my 3 JL 10's. Nice work. Keep us posted.
  #28 (permalink)
Old 08-06-2007, 01:32 PM
PS-RagE's Avatar
How did you connect the stock camera wiring to the head unit? I saw where you extended the wires from the overhead. Did you have to do anything special to use it with the head unit?
Nope, nothing special. It is spliced it to a composite cable.
Dale McLean
aka PS-RagE
House of RagE
  #29 (permalink)
Old 08-06-2007, 05:55 PM
PS-RagE's Avatar
Just got back from holidays - thus the lack of update posts - and got some pics of the latest mods that were completed before I left. Had a Toytec 3" lift put on, installed some Toyo Open Country A/T 305/55/20, debadged and the lettering done:
The guy did an awesome job - took him 18 hours! The logos and lettering of Motorola are actually cut-outs so the blue showing through is the paint.
Dale McLean
aka PS-RagE
House of RagE
  #30 (permalink)
Old 08-06-2007, 10:34 PM
shadyskins's Avatar
Dealer : Tri County Toyota
2007 Toyota Tundra Crewmax Bench Seat,
- Other - 2008 Civic Si Sedan,
1999 Lexus LX470 SOLD - 182,000 Miles
Last Online: 11-19-2009 10:41 AM
Images: 14
shadyskins is on a distinguished road.
shadyskins's Photo Albums
looks great!! I hope Moto is paying your monthly payment
2007 CrewMax SR5 4x4 5.7 Nautical Blue
My Pictures
TRD Rear Sway Bar, Pioneer FH-P8000BT w/ Sirius, Carriage Works Black Replacement Grille + Top Insert, Color Matched Sequoia Door Handles, Bench Seat, Dual Headrest DVD, back up camera w/monitor, Nüvi 660, Line-x, undercover, Tekonsha P3, debadged, enjoyed since 7/20/2007
FUTURE MODS -
25-30 ft Travel Trailer....... bye bye Pop-Up
LinkBack to this Thread: http://www.tundrasolutions.com/forums/audio-and-stereo/104796-worklog-road-rage-ii-2007-tundra/
Posted By For Type Date
Hoe Hack uw wagen - Stereo, GPS, Subs, etc | Hack N Mod This thread Refback 11-09-2009 01:41 AM
Come la vostra auto Hack - stereo, GPS, Subs, etc | Hack N Mod. This thread Refback 10-01-2009 04:41 PM
Hvordan Hack bilen din - stereo, GPS, Subs, osv. | Hack N Mod This thread Refback 09-28-2009 10:00 AM
Cómo Hack su automóvil - estéreo, GPS, Subs, etc | Hack N Mod. This thread Refback 08-02-2009 03:33 PM
Troubleshoot Automotive Voltage Regulator, Troubleshoot 1999 Honda Accord Climate Control, Troubleshooting 1992 Park Avenue Buick Air Conditioning - Alwaysboots This thread Refback 03-08-2009 09:52 AM
View Ford 4X4 S With Alterain Tires, Videos That Show What Happens To The Human In A Car Crash, View Headlight Assembly 1940 Ford - Kawasakimules This thread Refback 03-08-2009 08:50 AM
Car Radios For Mercedes Benz 500Sel, Car Radio Parts, Car Related Graphics Backgrounds - Donitaatk This thread Refback 03-08-2009 06:24 AM
How to Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod This thread Refback 01-13-2009 08:18 PM
Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod - Amazingly Cool Hacks, Mods, and DIY Projects This thread Refback 09-20-2008 10:44 AM
Hack your Car - Stereo, GPS, Subs, etc. - HacknMod.com - Amazingly Cool Hacks, Mods, and Projects. This thread Refback 08-30-2008 08:50 AM
Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod - Amazingly Cool Hacks, Mods, and Projects This thread Refback 08-15-2008 06:40 PM
Hack your Car - Stereo, GPS, Subs, etc. - HacknMod.com This thread Refback 10-25-2007 07:15 PM
Digg / Mods / Upcoming This thread Refback 10-25-2007 05:17 PM
Digg - Road RagE II This thread Refback 10-25-2007 05:12 PM
House of RagE - Road RagE II This thread Refback 09-09-2007 03:38 PM
Road RagE II - Page 2 - [H]ard|Forum This thread Refback 09-03-2007 08:10 PM
Road RagE II - Page 2 - [H]ard|Forum This thread Refback 08-27-2007 06:17 PM
House of RagE - Road RagE II This thread Refback 08-21-2007 07:28 PM
Gulf State Toyota's June incentives bmc4041 Pricing and Dealers 0 06-05-2007 08:43 AM
Invoice Price on 2007 Tundra SR5 DC 4x4 TundraHunter Pricing and Dealers 20 05-25-2007 03:07 PM
All-New Tundra CrewMax To Make World Debut At 2007 North American International Auto TS Support Toyota, Scion & Lexus News 0 01-06-2007 08:02 PM
We Got Jokes!!! -Thread 2- Possum Off-Topic 500 01-30-2005 07:56 PM
