LinkBack (17) Thread Tools Display Modes
  #76 (permalink)
Old 08-31-2007, 04:23 PM
PS-RagE's Avatar
Dealer : James Toyota - Timmins
Last Online: 10-12-2009 02:05 PM
PS-RagE will become famous soon enough.
PS-RagE's Photo Albums
Default Re: Worklog - Road RagE II
Slight update: the green wire from the monitor harness is an active high back-up indicator.
Dale McLean
aka PS-RagE
House of RagE
See Road RagE II thread for details
  #77 (permalink)
Old 09-08-2007, 03:27 PM
PS-RagE's Avatar
Default Re: Worklog - Road RagE II (2007 Tundra)
So a cold rainy weekend means no camping trip and thus an "excuse" to get some work done on the back wall/subwoofer.
Keep in mind, I am not a bodyman and just going with things I have done in the past based on information pulled from the 'net.
Anyhow, with the back wall removed, I covered it with green painter's tape. Previous experience has shown that fiber glass resin will not stick to this:
Next, I tightly stretch polar fleece around it doing my best to ensure it follows all the contours:
And now I soak it down with fiber glass resin:
Once the resin has dried, I pull it away from the plastic and I have a form to work with that gives me the basic shape of the back wall (minus the subwoofer section):
So once again, I completely gut the rear section of the Tundra including the temporarily installed radio components. Once the seats are out I replaced the bolts back in their holes both to protect the holes as well as to not lose the bolts:
This weekend's main job is to get the wall completely roughed in. That means working with fiber glass inside the truck. This stuff is the stickiest, messiest material of all. If any of it comes into contact with the interior, it will be ruined and have to be replaced. Therefore, I am not taking any chances and sectioned off the rear of the truck with two layers of a heavy plastic drop sheet:
So with a test fit of the new back wall and some trimming I have my two pieces placed:
Now I have to figure out how I am going to keep the wall in place before I join it to the subwoofer enclosure.
So with a pot of coffee on and the Symphony X discography in shuffle mode on the iPod I'll see if I can have this done today.
Dale McLean
aka PS-RagE
House of RagE
  #78 (permalink)
Old 09-08-2007, 09:05 PM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
Last Online: Today 03:30 PM
czechm8 is on a distinguished road.
czechm8's Photo Albums
That's a pretty sick ride, man!
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. Hybrid Audio Technologies drivers and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
  #79 (permalink)
Old 09-08-2007, 10:25 PM
Dealer : Coughlin Toyota
Last Online: 12-28-2008 01:25 PM
Ohiodish is on a distinguished road.
Ohiodish's Photo Albums
Looks good, you may need 2 pots of coffee... I bet this portion of your install will take some time. Fiberglass = lots of time, sanding & more sanding. Then after all that work; it's hidden behind the seat. I applaud your effort. Without a doubt the best A/V Tundra ('07) system I have seen.
'07 Crew Max Limited 4x4, Black, 20" OEM wheels & tires, Redrock, Nav, Rear DVD, X-liner, Pace-Edwards Bedlocker Electric Retractable Tonneau Cover, Carriage Works 5 pc polished billet grill, Compustar Remote start & Alarm & V1
  #80 (permalink)
Old 09-08-2007, 10:29 PM
I forgot to ask... How far back will your seat go? Will it slide all the way back and what about tilt?
  #81 (permalink)
Old 09-08-2007, 11:09 PM
PS-RagE's Avatar
Hopefully by tomorrow it will be strong enough to support its own weight so I can pull it out. Then I can work on it a little each evening before I go home at night.
The small seat will still have its full motion. The large seat is going to lose about 6" of travel.
Dale McLean
aka PS-RagE
House of RagE
  #82 (permalink)
Old 09-09-2007, 03:50 PM
PS-RagE's Avatar
I decided to reuse the factory mounts and fed a bolt back through it. When this piece is done, it is going to be really heavy so I may not have to bolt it in place at all but if I do, this mount will be handy as it will give me some side-to-side play for adjustment.
Again using the fleece, I make an angled bridge between the MDF subwoofer enclosure and the fiber glass back wall. The fleece is simply hot glued to the wood but in order to keep a straight line at the junction to the wall I screwed down a metal bar.
The fleece is soaked with resin and once it has hardened the first layer of glass is applied.
Next, the sides of the wall and the sub enclosure are bonded together. I need this to be as strong as possible before I remove it from the truck. It has to be a solid and inflexible so as not to change shape while working on it outside the truck otherwise it won't fit right.
As I kind of expected, when I removed the metal bar from the top of the fiberglass bridge I found that the top of the bridge was not bonded to the wall.
This actually works out in my favour as it lets me make a last minute adjustment to the back wall.
Now I just have to add a second layer of glass to all three joints and once hardened I can finally get this thing out of my truck! I know most people would shudder as I drilled holes or snipped harnesses but this part was the most nerve-wracking to me and I'll be glad to be doing the rest of this on a workbench and not in the truck!
Dale McLean
aka PS-RagE
House of RagE
  #83 (permalink)
Old 09-17-2007, 09:58 AM
tooldud's Avatar
Dealer : Leith Toyota
2003 Toyota Tundra
Last Online: 07-22-2009 10:53 AM
tooldud is on a distinguished road.
tooldud's Photo Albums
Wow! I just read the whole thread. Really nice work. Back in my 20's I had a job in car electronics installion. I installed some 2-ways and alot of car mounted cellular phones. I drilled many a roof holes for antennas. I look forward to the rest of the install. Thanks for the thread.
Tom
03 AC SR5 Silver Sky Metallic
Cab height ARE cap, Westin chrome step bars, tinted front windows 35%, Hella mini foglights under front bumper ,fog lights under the frame to light up the door area, fog lights under rear bumper (factory dash switches for each set of lights),Bedrug, Hellwig swaybar, one-touch window control for both windows,Kenwood DDX-6019 double din dvd unit,2 amps, 2 sets of speakers, 6 disc cd changer,Q-logic sub box, subs, rearview camera, & skid plate.
Freebies: Power outlet mod,fog light mod, map light mod &, debadged.
Hope to add: Chrome bull bar, headest monitors for back seat passengers (daughters)
Waiting for time to install: kicking alarm w/remote start.
My Website
  #84 (permalink)
Old 09-18-2007, 12:21 PM
ZX10R's Avatar
Dealer : Girard Toyota-Bmw
Last Online: 10-07-2008 05:43 PM
ZX10R is on a distinguished road.
ZX10R's Photo Albums
Dont know if this was asked or if you already mentioned it, but can you use 1 antenna for the Nav and Sat systems or do you have to use individual antennas.
Thanks.
2007 Toyota Tundra SR5 DC 4x4 5.7 V8 TRD
Sky Silver Met, Debadged, ARE LSII, BedRug, SwayAway 2.5" Coilovers, PRG Spring Pack, TRD Rear Stabilizer, TOYO OC A/T 285/75/18, TRD CAI, Corsa Touring Exhaust, Kenwood DDX8019/G510 Units, Wet Okoles front and rear.
  #85 (permalink)
Old 09-18-2007, 02:30 PM
PS-RagE's Avatar
If by "sat" you mean XM or Sirius then: no, you must use individual antennas
Dale McLean
aka PS-RagE
House of RagE
  #86 (permalink)
Old 09-18-2007, 02:42 PM
ZX10R's Avatar
Thanks for your answer. Looks good by the way.
  #87 (permalink)
Old 09-18-2007, 05:18 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Dealer : Voss Toyota
Last Online: 11-06-2009 05:41 PM
Images: 22
Beautiful, and clean! That's quite a pile of toys at the beginning of the thread ...amazing they all fit . Nice job, I'll be following your thread for sure ...
-Sean
GFX by FreedomEagle50
Manual Hubs
  #88 (permalink)
Old 10-01-2007, 10:07 PM
zukiman's Avatar
Dealer : Modern Toyota
Last Online: 09-27-2009 03:04 AM
zukiman is on a distinguished road.
zukiman's Photo Albums
So far your truck is looking awesome and is inspiring me to spend more money than I want to...
Couple questions...
Was there not a factory backup camera plug in the dash that would hookup to the factory NAV with backup camera option where you could hook into for the Alpine unit instead of using the one in the overhead? From what I have gathered from this forum, all the wiring for all accessories are pre-installed by Toyota so I would think that it would be back there???
Second, I have looked for a permanent mount GPS antenna without luck, even searching your part numbers... is this item still available?
Third, I am considering the Blackbird PMD-B200 as my navigation system for a couple reasons, double duty portable GPS and plug in to the W205 and you now have on board NAV and it also comes with factory bluetooth, plus it is about $1000 cheaper than the DVD NAV system. Did you consider this at all and if you did what made you go with the DVD NAV?
Thanks in advance...
www.psychowheeling.net
  #89 (permalink)
Old 10-02-2007, 09:48 AM
PS-RagE's Avatar
I know that feeling - wait till you see the next update......
Couple questions...
The factory nav is a factory option because it uses a different harness. It seems there are three different styles. Check this thread: http://www.tundrasolutions.com/forum...r-2007-tundra/
Check with a local Motorola Two-Way radio dealer. This sort of stuff is not typically available on-line.
There are a few reasons actually.
First off, I do not trust "quick connect" type devices. It is my experience that they break far too easily when docking and undocking. Also, with time the connections get sloppy resulting in intermittant operation.
Secondly, I was told the N872 has more advanced features and I'm a sucker for gadgets.
Unfortunately, I live so far north that the maps are sadly out of date. The "advanced features" only work if the device has detailed information about your location. So I mainly use my fancy navigation system as a scrolling map whose roads often end before you reach the end of them. I understand this is a problem with all of these things. It will be helpful when I go to the bigger cities.
Anyhow, I understand the B200 is not shipping yet. It is in limbo with my SPX17PROs
Dale McLean
aka PS-RagE
House of RagE
  #90 (permalink)
Old 10-02-2007, 11:46 AM
MARINE_WINGER's Avatar
Dealer : Sterling Mccall Toyota of Fort Bend
2005 Toyota Tundra,
2006 Toyota Camry-Solara
Last Online: 10-15-2009 02:18 PM
MARINE_WINGER is on a distinguished road.
MARINE_WINGER's Photo Albums
Rage - Im dying to see the completion of your sub box project...Hows it coming?
- Semper Fi -
MODS
ALPINE CDA-9855 | JL ZR-650 COMPONENTS | JL 6.5" SUB |ALPINE AMPS | AUDIOVOX - MULTIMEDIA | DYNO-MAT EXTREME | LIMO TINT (ALL THE WAY AROUND) | CLIFFORD ALARM W/ REMOTE START | MAGNAFLOW EXHAUST | TRUE FLOW INTAKE | 3" TOYTEC LIFT | ALCAN 1.5" AAL'S | 20X10 HELO MAX 6 | 305-50-20 NITTO TERRA GRAPPLERS | TRUXEDO LO-PROFILE
LinkBack to this Thread: http://www.tundrasolutions.com/forums/audio-and-stereo/104796-worklog-road-rage-ii-2007-tundra/
Posted By For Type Date
Come la vostra auto Hack - stereo, GPS, Subs, etc | Hack N Mod. This thread Refback 10-01-2009 04:41 PM
Hvordan Hack bilen din - stereo, GPS, Subs, osv. | Hack N Mod This thread Refback 09-28-2009 10:00 AM
Cómo Hack su automóvil - estéreo, GPS, Subs, etc | Hack N Mod. This thread Refback 08-02-2009 03:33 PM
Troubleshoot Automotive Voltage Regulator, Troubleshoot 1999 Honda Accord Climate Control, Troubleshooting 1992 Park Avenue Buick Air Conditioning - Alwaysboots This thread Refback 03-08-2009 09:52 AM
View Ford 4X4 S With Alterain Tires, Videos That Show What Happens To The Human In A Car Crash, View Headlight Assembly 1940 Ford - Kawasakimules This thread Refback 03-08-2009 08:50 AM
Car Radios For Mercedes Benz 500Sel, Car Radio Parts, Car Related Graphics Backgrounds - Donitaatk This thread Refback 03-08-2009 06:24 AM
How to Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod This thread Refback 01-13-2009 08:18 PM
Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod - Amazingly Cool Hacks, Mods, and DIY Projects This thread Refback 09-20-2008 10:44 AM
Hack your Car - Stereo, GPS, Subs, etc. - HacknMod.com - Amazingly Cool Hacks, Mods, and Projects. This thread Refback 08-30-2008 08:50 AM
Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod - Amazingly Cool Hacks, Mods, and Projects This thread Refback 08-15-2008 06:40 PM
Hack your Car - Stereo, GPS, Subs, etc. - HacknMod.com This thread Refback 10-25-2007 07:15 PM
Digg / Mods / Upcoming This thread Refback 10-25-2007 05:17 PM
Digg - Road RagE II This thread Refback 10-25-2007 05:12 PM
House of RagE - Road RagE II This thread Refback 09-09-2007 03:38 PM
Road RagE II - Page 2 - [H]ard|Forum This thread Refback 09-03-2007 08:10 PM
Road RagE II - Page 2 - [H]ard|Forum This thread Refback 08-27-2007 06:17 PM
House of RagE - Road RagE II This thread Refback 08-21-2007 07:28 PM
Gulf State Toyota's June incentives bmc4041 Pricing and Dealers 0 06-05-2007 08:43 AM
Invoice Price on 2007 Tundra SR5 DC 4x4 TundraHunter Pricing and Dealers 20 05-25-2007 03:07 PM
All-New Tundra CrewMax To Make World Debut At 2007 North American International Auto TS Support Toyota, Scion & Lexus News 0 01-06-2007 08:02 PM
We Got Jokes!!! -Thread 2- Possum Off-Topic 500 01-30-2005 07:56 PM
