LinkBack (18) Thread Tools Display Modes
  2 links from elsewhere to this Post. Click to view. #106 (permalink)
Old 10-28-2007, 09:09 PM
toyota40runner's Avatar
Dealer : Carson City Toyota
Last Online: 10-18-2009 12:39 PM
toyota40runner is on a distinguished road.
toyota40runner's Photo Albums
Default Re: Worklog - Road RagE II (2007 Tundra)
I don't really understand how to splice in the the factory camera wires and make it an rca... i know it was explained but i dont think i know the abbreviations
2007 Tundra SR5 w/ Nav
Upgrades: 100% Stock
1989 Toyota Pickup 4WD
Upgrades: Dana 44 straight front axle conversion, dana 60 rear, about 9 inch of lift total, 35x13.5 pro comp Xterrain tires on 18in american racing wheels, Ford 5.0 efi under the hood, Kenne Bell 6 pound supercharger, msd ignition, magnaflow dual exhaust, custom cold air intake, dodge nv4500 transmission, dual transfer cases, Pioneer avic-z1 dvd/nav, jl audio zr front and rear components powered by 450/4 amp, jl audio 12 w7 powered by 1000/1 amp.
  #107 (permalink)
Old 10-31-2007, 07:25 PM
Dealer : Toyota of Nashua
Last Online: 09-23-2009 02:42 PM
jeffmarshall911 is on a distinguished road.
jeffmarshall911's Photo Albums
Dale,
Impressive work, thanks for all the effort you have put in to the detail of this thread. Quick question, what do you use for your cellular amplifier and it’s components? Since you installed it, I have to imagine you’re impressed with it, have you found any limitations?
I have a corporate Crackberry and the hills and valleys in New England tend to make an extended conversation unpredictable and would probably invest in a similar setup as you’ve shown if the result is worth it.
TIA,
/Jeff
P.S. Much to others chagrin, holes in vehicles is nothing new to me either.
  #108 (permalink)
Old 10-31-2007, 09:33 PM
PS-RagE's Avatar
Dealer : James Toyota - Timmins
Last Online: 10-12-2009 02:05 PM
PS-RagE will become famous soon enough.
PS-RagE's Photo Albums
I'll nip a cable later and photograph how the connections were made.
Dale McLean
aka PS-RagE
House of RagE
See Road RagE II thread for details
  #109 (permalink)
Old 10-31-2007, 10:18 PM
PS-RagE's Avatar
Originally Posted by jeffmarshall911 View Post
Dale,
TIA,
/Jeff
It is a Wilson 801210. It actually works surprisingly well. Cell coverage in Northern Ontario is poor at best - this thing helps smooth out the fringes between towers. Worst case it will simulate the signal you get if you were to stop the car and get out. When we were camping at Lake Superior area this summer there was only analog available so my smart phone was dead. My wife's little tri-band Nokia was fringing between zero and one bar but when she got to the amp she jumped up to four bars and made her calls. Downside? You have to keep your phone right next to the internal antenna - headset or BlueTooth required.
Dale McLean
aka PS-RagE
House of RagE
  #110 (permalink)
Old 11-01-2007, 10:41 AM
Dealer : Hoover Toyota Scion
Last Online: 10-25-2009 02:15 AM
randomwalk101 is on a distinguished road.
randomwalk101's Photo Albums
PS-rage,
So the black wire is the one that is used to power the camera requires the voltage regulator (+7v). However, the green wires triggers the camera (reverse mode) that takes the normal +12v ?
  #111 (permalink)
Old 11-01-2007, 12:39 PM
PS-RagE's Avatar
The green wire connects to the headunit - not the camera
Dale McLean
aka PS-RagE
House of RagE
  #112 (permalink)
Old 11-02-2007, 11:01 AM
Do-It-Yourself Re: Worklog - Road RagE II (2007 Tundra)
As you might have known already..i was trying to follow your mod and add a switch to manually turn on the backup camera for my factory installed backup camera with monitor on the overhead liner. The plugs that goes into the monitor doesn't have the green wire as mentioned. The plug looks totally different also.
  #113 (permalink)
Old 11-02-2007, 04:32 PM
PS-RagE's Avatar
As I said in the PM, this is the connecter in the headliner:
The assembly you are showing must plug into this connecter.
Dale McLean
aka PS-RagE
House of RagE
  #114 (permalink)
Old 11-04-2007, 10:00 AM
Thanks Dale. The connector is indeed on the other end. I hacked into the camera wire itself (easier for me since I can take it down) and the wire is the blue one which connects to the green wire as you mentioned. Works great.
  #115 (permalink)
Old 11-05-2007, 12:06 PM
Last Online: 04-02-2009 01:48 AM
TUNDRA786 is on a distinguished road.
TUNDRA786's Photo Albums
Wow that is some impressive work.
TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
  #116 (permalink)
Old 11-05-2007, 09:50 PM
Dealer : Stevens Creek Toyota
Last Online: 09-26-2009 02:19 AM
outriderx is on a distinguished road.
outriderx's Photo Albums
Sorry to clutter your thread more Dale, probably should put this in the other thread about the wiring.
Wouldn't the correct voltage for the camera already be coming from that harness in the overhead console, perhaps on another wire?
If I were to buy the factory backup monitor that mounts in the console the instructions say to simply plug that monitor's cable into the harness. Power for the camera and monitor must be coming from that harness somewhere?
Maybe I'm just confused, or that power only works when in reverse?
  #117 (permalink)
Old 11-06-2007, 11:30 AM
PS-RagE's Avatar
The regulated voltage for the camera is supplied by the factory monitor. I'm not using Toyota's monitor so I have to regulate the supply voltage myself
Dale McLean
aka PS-RagE
House of RagE
  #118 (permalink)
Old 11-27-2007, 12:43 AM
TS
Dealer : Northshore Toyota
2007 Toyota FJ Cruiser
Last Online: 10-11-2009 12:11 AM
Images: 2
Dixie4x4 is on a distinguished road.
Dixie4x4's Photo Albums
To be safe, I pulled the tailgate apart and checked for continuity on the wires:
Sure enough, these are the right wires. So I spliced a sheilded cable to the video feed (red V+, grey V-) and a red/black cable for the camera power (black B+, white GND):
Again, these were fished down the A-pillar and over to the center console.
When you terminated these wires, did you convert them to RCA? How does one go about such a task? Do you have pics of the wire ends? Do I simply cut the rca, use the inside line as - and the shield as + and splice the two?
Tundras: 02 AC - Gone, 07 DC - Gone, 04 DC - Gone
FJ BRUISA! - Got
  #119 (permalink)
Old 11-27-2007, 08:27 AM
PS-RagE's Avatar
Pretty much. I used a suitably long cheapo RCA cable from my miscellaneous box of stereo parts and nipped off one end. The red wire (V+) goes to the center and the grey wire (V-) to the shield. Solder and heat shrink - tada!
Dale McLean
aka PS-RagE
House of RagE
  #120 (permalink)
Old 11-27-2007, 09:43 AM
TS
Images: 2
I'm going to take a swing at this soon. I appreciate the help
FJ BRUISA! - Got
LinkBack to this Thread: http://www.tundrasolutions.com/forums/audio-and-stereo/104796-worklog-road-rage-ii-2007-tundra/
Posted By For Type Date
Hoe Hack uw wagen - Stereo, GPS, Subs, etc | Hack N Mod This thread Refback 11-09-2009 01:41 AM
Come la vostra auto Hack - stereo, GPS, Subs, etc | Hack N Mod. This thread Refback 10-01-2009 04:41 PM
Hvordan Hack bilen din - stereo, GPS, Subs, osv. | Hack N Mod This thread Refback 09-28-2009 10:00 AM
Cómo Hack su automóvil - estéreo, GPS, Subs, etc | Hack N Mod. This thread Refback 08-02-2009 03:33 PM
Troubleshoot Automotive Voltage Regulator, Troubleshoot 1999 Honda Accord Climate Control, Troubleshooting 1992 Park Avenue Buick Air Conditioning - Alwaysboots This thread Refback 03-08-2009 09:52 AM
View Ford 4X4 S With Alterain Tires, Videos That Show What Happens To The Human In A Car Crash, View Headlight Assembly 1940 Ford - Kawasakimules This thread Refback 03-08-2009 08:50 AM
Car Radios For Mercedes Benz 500Sel, Car Radio Parts, Car Related Graphics Backgrounds - Donitaatk This thread Refback 03-08-2009 06:24 AM
How to Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod This thread Refback 01-13-2009 08:18 PM
Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod - Amazingly Cool Hacks, Mods, and DIY Projects This thread Refback 09-20-2008 10:44 AM
Hack your Car - Stereo, GPS, Subs, etc. - HacknMod.com - Amazingly Cool Hacks, Mods, and Projects. This thread Refback 08-30-2008 08:50 AM
Hack your Car - Stereo, GPS, Subs, etc | Hack N Mod - Amazingly Cool Hacks, Mods, and Projects This thread Refback 08-15-2008 06:40 PM
Hack your Car - Stereo, GPS, Subs, etc. - HacknMod.com This thread Refback 10-25-2007 07:15 PM
Digg / Mods / Upcoming This thread Refback 10-25-2007 05:17 PM
Digg - Road RagE II This thread Refback 10-25-2007 05:12 PM
House of RagE - Road RagE II This thread Refback 09-09-2007 03:38 PM
Road RagE II - Page 2 - [H]ard|Forum This thread Refback 09-03-2007 08:10 PM
Road RagE II - Page 2 - [H]ard|Forum This thread Refback 08-27-2007 06:17 PM
House of RagE - Road RagE II This thread Refback 08-21-2007 07:28 PM
Gulf State Toyota's June incentives bmc4041 Pricing and Dealers 0 06-05-2007 08:43 AM
Invoice Price on 2007 Tundra SR5 DC 4x4 TundraHunter Pricing and Dealers 20 05-25-2007 03:07 PM
All-New Tundra CrewMax To Make World Debut At 2007 North American International Auto TS Support Toyota, Scion & Lexus News 0 01-06-2007 08:02 PM
We Got Jokes!!! -Thread 2- Possum Off-Topic 500 01-30-2005 07:56 PM
