Old 08-15-2007, 01:49 PM
Dealer : Visalia Toyota
2004 Toyota Tundra
Last Online: 11-19-2009 03:40 PM
rzbobby is on a distinguished road.
rzbobby's Photo Albums
Default Factory JBL/aftermartket amp
Ok people how the heck do I get my rf, rr, lf and lr signal to run my aftermarket amp? If I tap into the wires after the JBL everyone is saying that it will blow up one of my amps and if I tap into the wires before the amp I will only get two channels and I need four. So what do I do??
Old 08-15-2007, 02:01 PM
czechm8's Avatar
Dealer : Jay Wolfe Toytota
2005 Toyota Sequoia,
- Other - Acura TL
Last Online: Today 03:11 PM
czechm8 is on a distinguished road.
czechm8's Photo Albums
Default Re: Factory JBL/aftermartket amp
Line Output Converter installed downstream from your stock amp.
It's that simple.
I use the NE-774V found here - very good quality and variable voltage.
David Navone - Adaptor Products - Car Audio Engineering
All you need coming out of your stock amp is the high-level front L&R and rear L&R signals for input to the LOC. You then have a low-level source signal that is variable between 0 and 9.5 volts that you can send to one more amps.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. Hybrid Audio Technologies drivers and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
Old 08-15-2007, 02:03 PM
czechm8's Avatar
- Other - Acura TL
Cool! I just noticed I crossed the 1000 post mark! Guess I don't spend as much time on this forum as I do on others.
Old 08-15-2007, 02:14 PM
2004 Toyota Tundra
Hey thanks for the quick response. I have been told that if I use a converter (as a matter of fact I do have the conveter you mentioned but I haven't installed it yet) it will fry either my factory JBL amp or my aftermarket amp because of the amplified signal going to the converter and aftermarket amp.......
Old 08-15-2007, 02:53 PM
czechm8's Avatar
- Other - Acura TL
No. That's exactly what an LOC is for.
Sent you a PM.
Old 08-15-2007, 03:55 PM
2004 Toyota Tundra
I have alread replaced everything. When I got the truck I took out the seats and carpet and ran all new wiring, new speakers including the tweeters, two 8" subs, an Alpine V12 amp and a Pyle DVD head unit.........
Now......I want to install my new Toyota Navigation unit E7006 but I guess I need the factory JBL amp to run with it. So yes I guess I need to tap after the JBL and hook up the LOC to the Alpine amp. I also cannot for the life of me find the grey plug (speed/reverse) that plugs into the back of the Nav unit. Did the 04 AC come with that plug?
Old 08-15-2007, 04:25 PM
czechm8's Avatar
- Other - Acura TL
No. I think the NAV option is on '05 and newer.
Ask on the board from those who know where the wiring is on '04's and older. You may have to get behind the instrument cluster to locate them.
Old 08-15-2007, 05:20 PM
2004 Toyota Tundra
Who put a quarter in you?
Old 08-15-2007, 05:42 PM
czechm8's Avatar
- Other - Acura TL
Am I running off at the mouth too much?
Old 08-15-2007, 07:22 PM
2004 Toyota Tundra
No I was joking Brother! You have helped more than anyone here so far and I thank you very much! I still need to know where to tap into the Speed and Reverse wires though. I looked behind the gages and I found the Green/orange wire but I also found two Black/ yellow wires. Which one of the Black/yellow wires do I tap into?
Old 08-15-2007, 09:28 PM
czechm8's Avatar
- Other - Acura TL
Two options:
1. Subscribe to the forum so you can gain access to all the wiring diagrams.
2. Find someone who has already done what you want to do.
Old 08-26-2007, 09:48 PM
2004 Toyota Tundra
Hey I think I might have tapped off of the factory amp in the wrong place. When you said install the LOC after the factory amp did you mean tap off of the harness that is in the truck (2004 AC) or the harness that plugs into the back of the unit? If I tap off the harness that plugs into the Nav unit I will only R and L, no front and rear ........................
Old 08-27-2007, 12:04 AM
czechm8's Avatar
- Other - Acura TL
No, the LOC is hooked to the Output of the amp --- Or the wires that go directly to the speakers from the factory amp. Not before the amp.
HU and AMP for 02 Sequoia - Confused? gnb Audio & Stereo 0 05-20-2007 08:00 PM
Using existing factory wires for new speaker/amp set-up... yay/nay? Tundradrenalin Audio & Stereo 2 05-15-2007 08:40 AM
Anybody add an amp to factory headunit? lzl Audio & Stereo 4 05-29-2004 02:14 PM
Help! Alpine HU sounds WORSE than factory radio! Waveman Audio & Stereo 8 08-16-2003 01:57 AM
I need help with an amp install nhparrot Audio & Stereo 0 03-28-2002 01:56 PM
