  #16 (permalink)
Old 01-11-2009, 12:17 PM
jliltd's Avatar
Dealer : Las Cruces Toyota
2007 Toyota Tundra 4WD DCab Longbed 5.7,
2001 Toyota Sequoia (Wife's Broomstick)
Last Online: 11-04-2009 11:46 AM
jliltd is on a distinguished road.
jliltd's Photo Albums
Default Re: Common Signal Lines for the 2007 Tundra
Originally Posted by jliltd View Post
Here is how the OHD monitor connector should be wired to drop signal down to Nav unit. For a shorter run there is a connector under the driver's side A-pillar cover that has the same circuits with the same color coding. It is one of two connectors down low right below the curtain airbag mount. The one that can be used is closer to the driver with tape wrapped up it. You won't have to mess wit the headliner that way.
Here's the diagram of how I finally got things to work after finding the broken wire in my tailgate harness:
I'm still not convinced there may be similar circuits in the unused K9 plug or in the K3 plug behind the Nav but forewent the continuity check because I already had everything set up and buttoned up.
As an update to the above post, there is a connector for the rear camera harness behind the glove box. Forget the overhead or A-pillar. This new behind the glove box location would probably be the way to go. More information found here:
DIY: OEM Backup Camera Install With Auto Anytime Camera
"The beauty of the second amendment is that it will not be needed until they try to take it." -- Thomas Jefferson
  #17 (permalink)
Old 01-17-2009, 08:43 AM
Dealer : Gene Messer Toyota
2005 Toyota 4Runner,
2007 Toyota Tundra Black Ltd CM 4WD
Last Online: Today 03:10 PM
pinoy is on a distinguished road.
pinoy's Photo Albums
Originally Posted by kinginthecastle View Post
For those with navigation units, K6 also has a red wire that is the emergency parking brake wire.
Do you know where it should be connected and what function it is used for? I am about to start my nav install and want to know if i need to connect this line for the parking brake. Thanks.
  #18 (permalink)
Old 01-17-2009, 11:51 AM
jliltd's Avatar
You only need worry about the K6 connector's parking brake pin (Pin 1) if you have an RSE (rear seat entertainment). That means there is a factory drop-down video monitor in the back seat area for the passengers to watch. I would assume any upgrade to Nav would not need this connection for any reason as there should be no RSE already in a non-nav vehicle. So basically you can forget about it. I just taped mine off when I did my install.
For clarification the parking brake connection is the purple wire in the following photo. Your color may vary so don't go by wire color, go by pin position in the connector. In this photo pin 1 is the one on the left. Now that you know which one it is, tie it off and forget about it.
  #19 (permalink)
Old 03-13-2009, 09:07 PM
fasteddiefire's Avatar
Last Online: 07-07-2009 02:27 PM
fasteddiefire is on a distinguished road.
fasteddiefire's Photo Albums
I am looking to tap into this over head feed "K6" to wire a flip down monitor for the back seat. " basically a custom RSE." I am going to put the camera feed on SPDT switch with a dvd player in the glovebox. I am a novice but a brave one at that. Do I need to worry about the parking brake "green" wire or is what I am doing goin to do basically gonna bypass all that? Thanks for any help.
  #20 (permalink)
Old 05-26-2009, 02:36 PM
Alan760's Avatar
Dealer : Reno Toyota
Last Online: 11-02-2009 05:01 PM
Alan760 is on a distinguished road.
Alan760's Photo Albums
Anyone know which wire I splice into for the remote amplifier turn on?
My Tundra inspires my students to go to college.
My Tundra Photos
  #21 (permalink)
Old 05-28-2009, 09:35 AM
velocitymotorsports's Avatar
Last Online: 10-11-2009 12:32 AM
Images: 9
velocitymotorsports is on a distinguished road.
velocitymotorsports's Photo Albums
Switched Accesory is GRAY (+) at the RADIO HARNESS
Jeff Sit, Owner & Installer
Velocity Custom Home Theater
Mobile Audio/Video Specialist
Morden, Manitoba
http://www.velocitymotorsport.com
Suspension, wheels, tires, accessories & more
This is a SWEET TRUCK: 2007 Tundra Pics and Sound clips williakr Tundra 25 09-21-2007 12:57 PM
Toyota Goes Local, Gets Back To Basics To Market The All-New tundra TS Support Toyota, Scion & Lexus News 0 02-01-2007 10:24 PM
Toyota Unveils Long Bed Versions Of All-New 2007 Tundra Full-Size Pickup Truck TundraSoul Toyota, Scion & Lexus News 0 09-18-2006 01:42 PM
