Re: Pics of the crappy stock speakers in the non JBL models
That is one hell of a magnet and voice coil on those bad boys...
Now I kind of wonder what my JBL "upgrades" look like.
Originally Posted by 07rcsb5.7
Did you add amp or just powered off stock head unit?
How hard was the install
I used the stock head unit and got speakers that would work well with the stock unit..the install was easy once I figured out how to remove the door panel..the back speakers were a little harder but not much.
SR5 5.7 Crew Max 2WD
Airaid CAI
Borla Dual Exhaust
Doug Thorley Headers
Undercover tonneu cover
Kenwood KDC-MP38U/Alpine 6 3/4 speakers
Luverne SS running boards
Homelink Mirror
TRD Sway Bar
TRD Sport shifter
Amsoil 25k oil-GULP!
Originally Posted by greg hazlett
Wondered how long it would take for a comment on that!
Did you replace the dash speakers or only the doors? If so how hard was it to get in their to swap those out? Did you use the factory mounts or aftermarket in the doors? What do you mean worked well for the stock deck? As far as RMS output?
'07 Silver Tundra DC SR5 TRD, Tow Pkg, BedRug, Tinted, De-badged, Black Powdercoated 'TRD' 18s, Volant CAI, Alpine IVA-W200 Deck, two Pioneer Premier 12" subs, Eclipse 34230 Amp, Eclipse 32430 Amp, CDT Components f/r, 2 Farad Cap
'86 Black Porsche 944 Turbo, magnesium wheels, boost control valve, Chipped ~300hp
'05 Black/Tribal Honda CBR 600RR, smoked windscreen, rear seat cowl, flushies, integrated taillight, fender eliminator kit, Akropovic exhaust
Originally Posted by zukiman
Were the Alpine direct fit or did you have to tweek them to install? What Alpines did you go with?
They were a direct fit in the front, no adapters needed..the back I used the adapters that came with the speakers; I drilled and screwed the adapter/speaker to to the door and it fit into the stock speaker hole..
Airaid CAI
Borla Dual Exhaust
Homelink Mirror
TRD Sway Bar
TRD Sport shifter
I replaced the doors; I did not want to tackle taking the dash apart and there is not much of a selection for the dash speakers. I used the factor holes in the front and the supplied bracket plate for the rears...
When I ordered from Crutchfield they recommended the Alpines as the best bang for the buck for the stock head unit. If you order from them they will tell you that the speakers will not fit and you will need to dremel down the bracket and the grille on the door but they are wrong...
Airaid CAI
Borla Dual Exhaust
Homelink Mirror
TRD Sway Bar
TRD Sport shifter
