factory amp in 04 doublecab-JBL system
+ Reply to Thread
Results 1 to 7 of 7
Thread: factory amp in 04 doublecab-JBL system
  1. #1
    Lurking Member eubie5 is on a distinguished road.
    Join Date
    Oct 2007
    Location
    southern indiana
    Posts
    23
    Liked
    0 times
    Rep Power
    6
    Default factory amp in 04 doublecab-JBL system
    does anyone know the size of the factory amp and where it is installed. i have the jbl system and am thinking of intalling new speakers. i plan on buying the bazooka VSE. i wanted to install a new amp for my new speakers, possibly under one of the front seats. but i looked and there are air ducts coming out under both front seats. what amp are people installing under the front seats, without any modifiing of the air ducts. OR, i thought i could just upgrade the factory amp if it is actually separate from the factory HU, which i plan on keeping till my wallet gets a little heavier. is there room for a larger sized amp? sorry the post is so long and ramblin. new to the website and i love it. LOTS of good info
  2. #2
    Supercharged Member JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23 has much to be proud of. JBK23's Avatar
    Join Date
    Sep 2007
    Location
    Macon, GA
    Age
    54
    Posts
    2,424
    Liked
    0 times
    Images
    10
    Rep Power
    52
    Default Re: factory amp in 04 doublecab-JBL system
    Try looking under the back seat that is a most likely place for it or it could be behined the back theses are just a few places to check and plus that will be a good time to clean
    out your truck but I'm thinking that the only place they can put it is back there unless
    it can fit under the driver or pass seat but I dought that so just look in thoses places and you should find it good luck to you
    JBK23.
    2006 Tundra Double cab SR5 4x2 4.7L V8:laughing:
  3. #3
    Join Date
    Oct 2007
    Location
    southern indiana
    Posts
    23
    Liked
    0 times
    Rep Power
    6
    Thread Starter
    no, there is 0 room under the back seats. i'm thinking it might be behind the panel where the rear power window slides down into. that is if this system even HAS an amp. i don't even know that it does. but thanks for replying!!!
  4. #4
    Random Poster Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold. Jodan is a splendid one to behold.
    Join Date
    Jul 2004
    Location
    South Glens Falls ,NY
    Age
    41
    Posts
    328
    Liked
    10 times
    Rep Power
    19
    The factory amp is behind the back seat panel in the wall, on the drivers side. The amp dimensioal size is roughly 8x11, roughly 2 inches thick.
  5. #5
    Join Date
    Oct 2007
    Location
    southern indiana
    Posts
    23
    Liked
    0 times
    Rep Power
    6
    Thread Starter
    would an aftermarket amp work if i found one to fit? can you recommend any that would be the right size for that spot. i'm going to upgrade the speakers and probably install the bazooka VSE. thanks
  6. #6
    Rookie tdriver is on a distinguished road.
    Join Date
    Sep 2012
    Location
    United States
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    actually the factory amp is in the dash. should be a silver unit just under and behind the air conditioning controls. taking it out though, might be a challenge.
  7. #7
    Rookie bblocker68 is on a distinguished road.
    Join Date
    Jan 2004
    Location
    Torrance
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    The amp is behind the back seat, behind the rear panel below the rear window.
    I believe the HU and amp are a matched set. If you replace the amp, you'll need something to help send it the correct signal.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
