Old 10-29-2007, 11:48 PM
Dealer : Longo Toyota
2006 Toyota Tundra DC
Last Online: 06-24-2009 01:00 AM
rezcar may have some regrets.
rezcar's Photo Albums
Default A51804 stock radio harness
Hi all, I have an 06 Tundra DC. It has the factory stereo which says A51804 on it. I don't know if there's an amp in the truck, haven't found it so far... Anyway, its a single disc and looks like it can control a CD changer. I want to add my old radio in it's place (already have the Metra kit) but don't want to cut up the stock harness. Is there an aftermarket kit which uses the factory plugs leading to a bare harness? Thanks!
06 Tundra DC
Old 10-29-2007, 11:51 PM
Default Re: A51804 stock radio harness
Interesting, I just did a google search on the A51804 and it turned up results from THIS forum...even though when I searched the forum itself, got no matches.
06 Tundra DC
Old 10-30-2007, 03:00 PM
Dealer : Toyota of Orange
2005 Toyota Tundra
Last Online: Today 03:38 AM
diablito1975 may have some regrets.
diablito1975's Photo Albums
i think that only JBL systems use external amps i dont know if your is a jbl , it shoud have the jbl logon on the face of the stereo, bu tto make sure if you have an amp you wil need to remove the rear panel behind the rear driver side , push your rear seat forward , then remove the (2) knobs by pulling the outer part only, then pul teh rear panel off, you will need to pull really hard at the edges as is held by clips, and if there is a external amp it should be on the bottom left hand side
Old 10-30-2007, 03:08 PM
2005 Toyota Tundra
ye sthere is a harness that plugs into the stock radio harness so you will not need to cut your stock harness check out this site. dont know if allowed to post sites in here but go there
installer dot com
Old 10-31-2007, 12:19 AM
Thanks guys, I pulled that rear panel a while ago and didn't see anything. So I thought it has no amp or it's hidden really really well! I didn't see anything behind the radio/HVAC bezel up front either. I'll check out that site too. I know Walmart carries stuff but it's all for 00-03 Toyotas, those won't fit at all right?
06 Tundra DC
Old 11-08-2007, 02:03 AM
throwback2332's Avatar
Dealer : Toyota of Richardson
2002 Toyota Tundra,
2006 Toyota 4Runner,
2007 Toyota Tundra,
1998 Toyota 4Runner,
1995 Toyota T100
Last Online: 12-11-2008 12:31 PM
throwback2332 may have some regrets.
throwback2332's Photo Albums
Is the harness to your radio one solid plug or 2 plugs, (2 plugs no amp), (1 plug has amp)
Old 11-08-2007, 08:02 PM
Mine is two plugs, so I guess no amp...
06 Tundra DC
