Bluetooth microphone location
+ Reply to Thread
Results 1 to 12 of 12
Thread: Bluetooth microphone location
  1. #1
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    23 times
    Rep Power
    1673
    Default Bluetooth microphone location
    I will be installing an Avic D3 and a CD-BTB 200 Bluetooth Adapter in the near future, does anyone have any recommendations for a location for the microphone? Has anyone tried using the Toyota factory location in the overhead console?
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter millsp's Avatar
    Join Date
    Jul 2007
    Location
    Fort Lauderdale FL
    Age
    45
    Posts
    1,323
    Liked
    1 times
    Images
    39
    Rep Power
    9
    Default Re: Bluetooth microphone location
    I was going to put mine there. But after examining the mic I noticed it has several entry points for voice and I didn't want to hinder them. I ended up mounting it right up front at the roof/window line just to the left of the over head console.
    P.S. I have the Z2
  4. #3
    Join Date
    Oct 2007
    Location
    JAX BCH
    Posts
    45
    Liked
    0 times
    Rep Power
    8
    Mounted mine by the visor, no feedback and recipient cannot tell hes on speaker phone
  5. #4
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    23 times
    Rep Power
    1673
    Thread Starter
    Quote Originally Posted by millsp View Post
    P.S. I have the Z2
    Quote Originally Posted by reelmagic View Post
    Thanks
    ~Glenn
    Yes I am a pirate!
  6. #5
    Junior Member PS-RagE's Avatar
    Join Date
    Mar 2007
    Location
    Timmins, ON
    Age
    47
    Posts
    355
    Liked
    1 times
    Rep Power
    9
    I removed the factory mic and put mine in there. Used a little hotmelt glue to hold it in place:
    Dale McLean
    aka PS-RagE
    House of RagE
    See Road RagE II thread for details
  7. #6
    Supporter asianflava's Avatar
    Join Date
    Jan 2004
    Location
    Longmont, CO
    Posts
    1,716
    Liked
    14 times
    Rep Power
    4039
    I'm gonna try it in the switch blank next to the tow/haul switch. I've been using it there with the voice commands but haven't tried the BT yet.
  8. #7
    Join Date
    Oct 2007
    Location
    Rockledge, FL
    Posts
    87
    Liked
    0 times
    Rep Power
    8
    Quote Originally Posted by asianflava View Post
    I Tried it there it seems to pick up alot of road noise from behind the dash. I would definitely go with the factory location or one higher up in the cab.
  9. #8
    Tundra Solutions Founder Truck Champion's Avatar
    Join Date
    Oct 1999
    Location
    Fort Lauderdale, FL
    Age
    51
    Posts
    1,702
    Liked
    141 times
    Images
    8
    Rep Power
    19806
    I also installed my Eclipse mic in factory location similar to Toxarch's picture above. I aimed it at the drivers seat and it works perfectly.
    I am the founder of TundraSolutions.com and a 5-time Tundra owner. @TruckChampion
    15th anniversary TS decals are available.
  10. #9
    Join Date
    Jan 2008
    Location
    San Gabriel Valley
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    I placed mine on the windshield right behind the rear view mirror and tucked all wires along headliner and windshield. Works well, it does not pick up noise from the AC at all and people I speak have not complained or commented on the clarity or volume.
  11. #10
    Join Date
    Nov 2007
    Location
    New England
    Posts
    29
    Liked
    0 times
    Rep Power
    8
    I find in just about any vehicle the best placement for the microphone is on top of the steering wheel column. You can speak right into it. Most mics now have noise cancellation, if you put it behind a panel it defeats the purpose.
  12. #11
    Join Date
    Jan 2004
    Location
    Longmont, CO
    Posts
    1,716
    Liked
    14 times
    Rep Power
    4039
    Mine still isn't mounted, I have it free and am experimenting with different locations. I had it low next to the tow/haul button, it worked fine but the other people said that there was a lot of echo. I mounted it higher, just jammed it into the a/c vent to see how it worked. The other side said that it was a lot better but there was still a little bit of echo. I'm gonna mount it right under the brow of the instrument cluster and see how it goes. I guess that is the same as mounting it on the steering column.
  13. #12
    Join Date
    Dec 2007
    Location
    Orlando
    Posts
    85
    Liked
    0 times
    Rep Power
    8
    I wound up mounting my mic on the side of the roof console, on the driver's side, about half way back, and angled at about 45 degrees. I used a small strip of double sided foam tape to hold it in place, although the cable keeps it pretty much there. (I ran the cable inside the console, so the cable by the end of the mic is trapped between the console and the headliner.
    No echo and sounds great.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
