Replacing stock 6x9s in 07 Tundra
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: Replacing stock 6x9s in 07 Tundra
  1. #1
    Join Date
    May 2007
    Location
    Bossier City, LA
    Posts
    176
    Liked
    0 times
    Rep Power
    9
    Default Replacing stock 6x9s in 07 Tundra
    Ive decided to upgrade the stock speakers in my truck. Im looking at going with the Polk db691s powered off of a Pioneer Avic Z2. I know that our trucks have 6x9s stock so why do I need to purchase adapter plates for them? Also where can I purchase these adapter plates to make the speakers fit? Thanks in advance everyone.
    2007 Slate Metallic TRD DC. 5.7L 4x4
    Readylift Leveling kit/ JBA Exhaust
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supercharged Member Jumbo Jet's Avatar
    Join Date
    Mar 2007
    Location
    Florida
    Posts
    2,966
    Liked
    29 times
    Rep Power
    6708
    Default Re: Replacing stock 6x9s in 07 Tundra
    The adapter plate is needed if you want to change out your stock 6x9's for 6 1/2" components. Its basically a plastic plate that has screw holes to fit the stock locations, but they have cut outs for 6 1/2" speakers. You can make your own out of MDF. I bought the Scosche kit off ebay for pretty cheap. ebay links are frowned upon here but do a search there for Scosche kit #SAT69
    2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
    Honda Super Cub
  4. #3
    Join Date
    May 2007
    Location
    Bossier City, LA
    Posts
    176
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Quote Originally Posted by Jumbo Jet View Post
    I saw the ones you speak of but I also saw some kits on EBAY for 6x9s. It says they gives you more clearance so the speakers will clear. Are these even needed or can I just bolt in the 6x9s in the stock location with no adapters?
  5. #4
    Supporter asianflava's Avatar
    Join Date
    Jan 2004
    Location
    Longmont, CO
    Posts
    1,716
    Liked
    14 times
    Rep Power
    4039
    You need the adapter plates because they space the speaker off the door. Without them there is very little depth. Also, the speaker hole is not 6X9, it is much larger, you need the adapter to make up the space.
  6. #5
    Veteran Member Henry T's Avatar
    Join Date
    Jun 2007
    Location
    chicago IL
    Posts
    1,495
    Liked
    4 times
    Images
    25
    Rep Power
    3036
    You can also just cut the stock speakers out of the adapter they use from the factory. This works well for 6x9 replacements. Just screw it in to the plastic a 3 1/4" deep speaker will fit with this set up.
    2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Modified Pioneer sealed sub box, MTX Audio TT 6510-04 10" shallow sub, Alpine 450 mono amp 220 watts, All 4 doors and rear wall Dynamat, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear camera, Interstate Battery Mega Tron Plus MTP27F.
  7. #6
    Veteran Member TRDatVT's Avatar
    Join Date
    Dec 2006
    Location
    Newport News, VA
    Posts
    547
    Liked
    0 times
    Images
    6
    Rep Power
    9
    Quote Originally Posted by asianflava View Post
    How many spacers did you use on the adapter to space it off the door some? If you use to many it will hit the inner panel and not enough could let the window or something hit it?
  8. #7
    Join Date
    May 2007
    Location
    Bossier City, LA
    Posts
    176
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Thanks for the info everyone!!
  9. #8
    Join Date
    Jan 2004
    Location
    Longmont, CO
    Posts
    1,716
    Liked
    14 times
    Rep Power
    4039
    Quote Originally Posted by TRDatVT View Post
    It does hit the door panel, the door panel also didn't snap all the way down. I could have dremeled out the honeycomb on it but didn't bother. If you don't use enough spacers, it will hit the window track. I don't think you can install them where the window will hit them (but I don't know for sure.)
  10. #9
    Supporter millsp's Avatar
    Join Date
    Jul 2007
    Location
    Fort Lauderdale FL
    Age
    45
    Posts
    1,323
    Liked
    1 times
    Images
    39
    Rep Power
    9
    I trimmed the door panel and it snaps down completely. I bought my adaptors off Ebay but I had to add to them in order for my infinity kappa 6X9s to fit.
    Also remember our doors are what they call Wet doors meaning water will run inside them from the window edge. Be sure to protect your speakers from this water.
  11. #10
    Join Date
    Dec 2007
    Location
    seattle, WA
    Posts
    404
    Liked
    5 times
    Rep Power
    32
    I used db690's like asianflava did. I also used the stock adapter. I just cut the stock speaker out and screwed in the polks right on top. I then trimmed out all the honeycomb behind the door panel speaker grill. This way, I kept the factory water guard over the speaker and there was plenty of clearance for the magnet. did not have to space out the window track either.
  12. #11
    Join Date
    Dec 2006
    Location
    Newport News, VA
    Posts
    547
    Liked
    0 times
    Images
    6
    Rep Power
    9
    So it looks like the ebay adapters do have the water guards attached? Has anyone found a way to mount the 6x9's without trimming? Do you have to trim with the 6.5" adapter?
  13. #12
    Join Date
    Oct 2007
    Location
    Scott Air Force Base
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    Crutchfield: Car Audio, Home Theater, Speakers, Home Electronics sells the adapters and the reason we need them is because the factory speakers are 6x9 but are not a traditional shape in regards to how they mount. The brackets allow you to put a traditionally shaped 6x9 mounted speaker in the doors.
    Good Luck!
  14. #13
    Join Date
    Dec 2006
    Location
    Newport News, VA
    Posts
    547
    Liked
    0 times
    Images
    6
    Rep Power
    9
    Quote Originally Posted by johnnyjay View Post
    Good Luck!
    I can't find the 6x9 adapter, but I can find the 6.5" adapter. Maybe thats because the 6x9 adpaters don't fit without cutting the doors!
    Josh
    2008 Salsa Red Pearl DCSB SR5 2WD
    Corsa Sport Single Exit, Doug Thorley's, 20% Tint up front, Line-X, Access Roll-Up Tonneau, Alpine Touchscreen Nav, Sirius Satalite Radio...
    VA 757 Area Group MEETS
    Future Mods: Color Matches Grill, Lowering Kit, TRD CAI, Wheels, Fender Flares, Supercharger, JL Stealthbox, Black Headlight Mod...
  15. #14
    Join Date
    May 2007
    Location
    Bossier City, LA
    Posts
    176
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Josh
    no they should fit with zero cuting. I ordered some off of ebay and they came in today. Do a search on ebay under tundra speaker adapter and they should come up. Cant tell you how they fit yet because my speakers arent here yet.
  16. #15
    Join Date
    Dec 2006
    Location
    Newport News, VA
    Posts
    547
    Liked
    0 times
    Images
    6
    Rep Power
    9
    Quote Originally Posted by use2vtec View Post
    Were you implying that the 6x9 adapters should fit without cutting or the 6.5"? From what I have seen on the forums, 6x9 adapters hit the door panel and the door needs to be trimmed with a dremel tool on the inside in order to fit properly. I just want to do my homework before I go through the trouble. Definitely do NOT want to cut my brand new door panels if I can avoid it! Use3vtec - Let us know how your install goes and take some pictures if you think about it.
    Josh
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
