Audio & StereoTechnical discussions about factory or aftermarket audio and video systems.
This is a discussion thread titled "5 or 6 channel amp, need help....", within the Audio & Stereo forum, part of the Technical & Vehicle Assistance Forums category.
I'm struggling to pick amps. I've got a zapco z100c2 on the way, but am thinking strongly about just going with a 5 or 6 channel amp for simplicity. I like musical, warm sound, not just loud. Will be using two 8 inch subs, 6.5 components in front and 6.5 fill in rear.
Within the range of the following based on some new prices found at a few places, how do you pair these down for a simple system and what other options am I leaving out?
My preference is cheaper rather than more expensive, but I want a nice sound as well. The fosgate limited 1000 seems like good price to features ratio, but not sure how refined it would sound.
Any input appreciated.
The Alpine should be a good amp. Really small for the power. I just picked up two of the PDX amps to try in my shop install and I"ve been impressed so far.
You might also consider the Elemental Designs NINe.5 amp. They are closing it out @ $350. I'ts a beast of an amp and does more than rated power since its rated at 12.5 volts. Here's the specs:
Model Name : NINe.5 Amplifier
RMS Power @ 12.5v : Front Channels
4 x 100 @ 4Ohm @ 0.05%THD
4 x 55 @ 8Ohm @ 0.05%THD
4 x 175 @ 2Ohm @ 0.05%THD
2 x 350 @ 4Ohm @ 0.05%THD
RMS Power (Subwoofer Channel) @ 12.5v :
1 x 250w @ 4Ohm @ 0.09%THD
1 x 450w @ 2Ohm @ 0.09%THD
1 x 600w @ 1Ohm @ 0.09%THD
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, TRD air filter, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner, DLS Nobelium components and coaxials, TRU 2-channel amp, 13" eD sub, eD Nine.1 amp, iPod hookup. SilverStar lamps.
I actually ended up buying an arc mini 125.2, and have an alpine 4.100 arriving on Friday that I bought for $196 shipped in mint condition - missing the cross over cover only.
That said, after doing some test fittings with the arc mini, which is roughly half the size of the pdx4.100, and taking more measurements, I don't see anywhere that the pdx is going to fit in what I ended up doing system design wise.
I'm putting all my amps on the front end, which on an 06 DC is limited space wise, so what I'm probably going to do is just get another Arc Mini instead. I've been trying to sell the alpine on another forum but no such luck. I'll have it in hand on Friday though, and if no one offers me what I'm looking for for it, then I may just try to force fit it into the front of the center console somehow.
