Old 04-21-2008, 04:41 AM
Dealer : Puente Hills Toyota
2005 Toyota Tacoma
Last Online: 11-20-2009 02:49 PM
point45 is on a distinguished road.
point45's Photo Albums
Default Kenwood DNX8120 Review
Took me about 2 hours for the install in my 05 tacoma and most of that was trying to run the wires for the GPS antenna and hands free mic. My arms and hands just dont fit well into the tight spaces trying to snake around all the brackets and ducting.
When i get some more time im going to add a garage remote to the system so that i can use the built in switches.
Overall its an awesome unit. Does everything I want and more. The interface isnt the most stream lined but 5min of playing with it and i was able to use it well and could navigate the menus easily, would have been faster if i just sat down and read the manual first. I just need to get accustomed to using the dvd player.
The only down side is the fast forward for the video, you cant or at least i havent figured out how to do it from the video screen. I must switch to the source screen, press fast forward go back to the video so that i can see where the video is and i can press play from there. However if you use the remote its just pressing one button.
DVD play back is excellent, the screen looks great. No complaints, the remote control works wonderfully in controlling playback.
The bluetooth works great, the phone syncs with it every time and all i need to do is get in the car and turn it on, no more headsets for me. The unit downloaded all my contacts automatically and the voice dialing works but is seperate from the phone and you need to record a sample of the name, SMS texting dosent work however and i think this is going to vary from phone to phone. I do need to relocate the mic as there is some echo as it sits close a speaker and i havent played with the settings yet.
I was able to ground out the parking wire and enable all of the functions of the unit all the time. I attached the wire to a screw behind the glove box that connects to a support bar. I have found no option in the head unit to turn off this feature through the software.
One complaint is that sometimes and its only with one of the videos on my ipod, when it plays the screen goes blue and it says no video signal. But it goes away if i try to play it again. I think its just the ipod and the way i converted that video for the ipod.
Ipod music and video is easily searched by catagory and playlist. I wish i could make playlists on the fly but i guess while driving thats a bit excessive.
If you can swing it i think this is the unit to get so far.
heres some pics of it working
point45/DNX8120 - Photobucket - Video and Image Hosting
Video of me running though some of the basic features.
1.flv - Video - Photobucket - Video and Image Hosting
Update:
After using the unit for almost a week i have found no issues. After relocating the mic there is no echo but people say they can definatly tell that im on a speaker phone. The odd thing about this is when i taped the mic to its current position and called my friend to test it out he said it sounded fine and couldnt tell that i was using the speaker phone. I still cant get the SMS to work but its not a huge deal as everything else is working wonderfully and im not a big text messaging guy. If someone sends me a text message its usually not an emergency. I have added a picture of where i installed the mic to my photobucket album.
Someone said their unit does not resume playing the last song when starting up, i have not experienced this with my head unit. It always resumes the last function when powering on, either playing a dvd, radio station or music from the ipod.
The usb port works great for audio, i have not had any luck getting movies to play but then i havent tried too hard as all my movies are on the ipod.
I tried installing my garage remote to the headunit and it worked great untill i shoved the remote under the dash. Once i did that the signal was not strong enough. I now need to find a different remote or boost the signal somehow. It really is alot of work just to get the head unit to control the garage remote as it required me to solder a voltage regulator to the PC board of the remote, and then attach a relay and now seems like i need to extend the antenna. Beyond that the external switches work great, still need to figure out what to hook up to the second switch.
I found the reason for the "no video signal" when playing video from the ipod, apparently the unit will not play video if you try to access it from the music controls. You must use the video button to play ipod video.
My one nag about using the unit to control my ipod is that it plays EVERYTHING, as in if i just tell it to play songs from the ipod it will play the audio from music videos, and podcasts along with the music. I just want music. If i want to listen to a podcast ill select the podcasts.
If anyone has any questions or wants me to take a specific picture of anything let me know.
Old 04-21-2008, 08:50 AM
Jumbo Jet's Avatar
Dealer : Deland Toyota Scion
Last Online: Yesterday 07:00 PM
Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold.
Jumbo Jet's Photo Albums
Default Re: DNX8120 Review
Thanks for the review, I cant wait till mine gets here.
So you only had to ground out the one wire...... correct? Is there a speed sensor wire too?
2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
Honda Super Cub
Old 04-21-2008, 09:19 AM
2005 Toyota Tacoma
correct, just one wire and no speed sensor wire.
Old 04-21-2008, 10:47 AM
Dealer : Champion Toyota Scion of Austin
Last Online: 07-14-2008 01:12 AM
cabster101 is on a distinguished road.
Send a message via MSN to cabster101 cabster101's Photo Albums
I just put the parking brake wire on the harness with ground for the deck.
The backup camera doesn't come on when you put it in reverse by default. You have to change that in the settings.
Old 04-21-2008, 05:14 PM
Dealer : Kingsway Lexus Toyota
Last Online: 05-07-2009 10:26 AM
xnaron is on a distinguished road.
xnaron's Photo Albums
Where did you guys order yours from? Crutchfield lists it for about $1599 I think...I am trying to decide between this unit and the Pioneer AVIC-Z3. Did you guys compare it to the Pioneer? If so what made you get the dns8120 over the avic-z3?
Does the 8120 need to have a DVD in for GPS navigation or are the maps stored in memory?
thanks!
Old 04-21-2008, 05:32 PM
Be nice to see some install pics..hint...hint
Old 04-21-2008, 05:40 PM
2005 Toyota Tacoma
thanks!
Maps are stored in flash memory, no dvd needed and updates are done via SD card slot.
I bought mine from sonicelectronix.com
I chose this over the avic because it allows video from ipods and you can sort through the music on your ipod by artist, genre, album, etc. The garmin nav is better then whats on the pioneer unit and I can just plug in a USB stick to play songs.
Bluetooth is built in for hands free calling vs buying a seperate unit to add on to the avic. Also the built in switches allow me to use the headunit to control outside devices with a relay, such as a garage door opener.
The 8120 has 5v preouts so when i upgrade the rest of my stereo system with an amp and speakers its ready to go. The 7100 and avic only have 2v preouts.
Old 04-21-2008, 06:00 PM
Thanks! They have a great price!
Old 04-21-2008, 07:55 PM
Jumbo Jet's Avatar
I ordered mine from Sonics and they shipped it later that same day, although I think I just got really lucky when i called that they had a few. Great price on that unit too.
Honda Super Cub
Old 04-21-2008, 08:09 PM
Dealer : Legacy Toyota Scion of Tallahassee
Last Online: 09-30-2008 11:44 AM
txbonds is on a distinguished road.
txbonds's Photo Albums
Default Re: Kenwood DNX8120 Review
Regarding the Blue Tooth in these units, it appears to be Parrot technology based on the box graphics. How do people you are talking to indicate you sound? My wife and father have both said the sound on the blue tooth of my pioneer fh-p8000bt sounds like crap. My wife went so far as to say if anyone else had called her with a phone/BT like that she would be pissed.
I've tried moving microphone placement, wire routing, heat shrinking tubing, playing with echo cancellations, reconnecting the phone pairing, etc. Nothing makes the poor sound quality for the other end improve. I can hear them just fine, but they indicate I sound like I'm in a scratchy tunnel with lots of reverb and the sound is broken and patchy. I've given up on making this one work, and am curious if the Kenwood one works better out of the box.
Old 04-22-2008, 12:10 AM
Dealer : Carlson Toyota
Last Online: 05-20-2009 11:08 AM
crazed is on a distinguished road.
crazed's Photo Albums
I bought the 8120 from 6ave.com with a coupon deal and got a killer price. I think it is expired, but try it anyway: AFLKEN1098. They were sold out/recalled at the time, but just got word it will be shipping Tuesday.
The reason I bought mine is the two USB inputs, one for iPod, one for the USB panel mount I will be installing in place of the Aux input. Here is a link to the panel mount if anyone is interested: USB Mount.
Anyway, I have a lot of TV shows converted to .avi files and the 8120 is Divx certified, so I can load up the files on a USB stick and enjoy, yet still have the iPod connected, too.
Other reasons include Bluetooth, 5V outputs, etc. But it was the two USBs that sold it for me...
Thanks for the review, I can't wait to install mine.
Old 04-22-2008, 05:51 AM
Thanks, had been looking for something like this myself. Just ordered two of them for my own install.
Old 04-22-2008, 09:56 AM
Dealer : Freeman Toyota
2007 Toyota Tundra,
2004 Toyota Avalon XLS loaded
Last Online: 11-20-2009 01:37 PM
mhejl is on a distinguished road.
mhejl's Photo Albums
I don't mean to hijack but my FH-P8000BT BT works fine. No complaints other than "it sounds a little different". Perhaps your mic is bad or something? I have mine mounted in the stock position in the overhead; I cut out the little slots so the mic sticks out about 1/4".
Old 04-22-2008, 10:55 AM
It's possible. My wife basically gave me the ultimatum on it though, as she said that it sounded so bad that it was beyond usable. We spent an hour or two talking on the phone while I moved the mic around to different spots, moved the cable to different routes, plugged and unplugged the cable, etc. Nothing improved it. There was always a low level rumble/reverb in the sound on her end, and my voice was spotty and patchy during conversation.
My Dad had previously told me the same thing last week, making point to tell me it sounded too bad to talk to customers on it.
Long and short, I couldn't get it to work better.
The unit had been working fine overall otherwise. Even had the Aux1 input attacxhed to my dvd headrests and it worked great.
But, since the BT wasn't working, and my wife sort of gave me the incentive to do something about it, figured this was the push I needed to go ahead and send the pioneer back to crutchfield and give something else a try.
Old 04-22-2008, 10:12 PM
2008 Toyota Tacoma
Last Online: 05-14-2008 02:36 PM
ponts is on a distinguished road.
ponts's Photo Albums
First time poster.....
I have a 08 Tacoma and I am looking at the Kenwood 8120. Point45 may I ask where you mounted GPS and mic. Thanks
LinkBack to this Thread: http://www.tundrasolutions.com/forums/audio-and-stereo/131732-kenwood-dnx8120-review/
Posted By For Type Date
Aftermarket Double Din Multimedia Head Unit This thread Refback 06-25-2009 07:02 PM
