Re: Question about sirius.
I have a sirius sat unit as well, when I first installed it I had verry weak resption and no siginal strength. my ant. is on the roof about six inches in front of the third break light, I ran the wire thru the break light, under the plastic panels and then under the carpet to the center councel where I have my unit mounted. circut city has a connecter that hooks up to the radio ant. and has a wire that plugs into the docking station of the unit.
its a simple install just remove the center cover by poping out air vents there are a couple of screws behind the vents once the cover is off there are four screws holding the radio in, remove those pull the stereo out unplug the ant. and plug it into the adapter then plug the other end of the adapter into the ant. slot run the docking station wire to your unit and put it all back togather. its been about three years since I installed it so I might be missing a step , that's it in a nut shell there is no loss of siginal except under a few bridges but I get exclent reception.
