Help with Speed Sensor and reverse wire identification
I have a 2003 SR5 without JBL system. I am looking to install the Eclipse AVN6620 and from my research so far it is all plug and play other than three wires:
Parking brake signal: which will be grounded to allow function while vehicle is in motion
Speed pulse signal: where is this located on the truck?
Reverse signal: I can just ignore this wire if not using a backup camera, correct?
My other question was in regards to the GPS antenna, has anyone found an easy and effective mounting spot? Thanks
