Re: Car stereo as mobile stereo?
What you described wouldn't be too portable!
Using the headphone jack of your iPod will work, but the signal quality will not be very good. Keep in mind as well that the output voltage of an iPod is not much and you will have to turn the gains way up on your amps
Power inverters will do you no good. You need a DC power supply. The battery will work, but you will need to keep it charged, and you better not let the voltage dip much below 12 volts or you'll kill your amps quickly. If you plan to use this indoors, then you should use a DC power supply instead of a battery since the battery will give off toxic fumes.
You can put a jumper wire from the remote turn on lead of the amp to the +12 volt power connection to turn the amp on. You could put a switch on the remote wire as well to turn the amps on and off.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. Hybrid Audio Technologies drivers and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
