Old 04-28-2009, 07:56 PM
wolfeman28's Avatar
Dealer : Metro Toyota
Last Online: 09-09-2009 02:36 AM
Images: 18
wolfeman28 is on a distinguished road.
wolfeman28's Photo Albums My eBay
Default Two 10" Sub Install In A 2001 Access Cab (pics)
So I was told it couldn't be done, but I beg to differ
Here are some pics of what I've done so far, unfortunately I'm at a stand still until the temps here get back over 65 degrees. This Isn't my first time using fiberglass, but it's the first time I've done it correctly haha. Usually I'm in such a rush I screw things up royally, but it's coming out nice so far. If anyone has any questions feel free to ask!
And don't tell me subs can't share airspace, because they can with no issues. Don't knock it til you try it. As long as they are both running mono the subs don't know the difference.
Here is what I did first, I removed the metal frame that supports the seat and holds the cargo area. I trimmed it a bit to get the width I needed. You can also kinda see what i had to do to get more airspace, I had to bang out the floor board toward the middle a bit. A small hammer did the trick pretty easy. i was afraid I was going to have to cut it and weld some sheet metal, but this was a lot easier. You can also see the spray on sound silencer material I used.
2001 Tundra Limited- Turbo install in progress......
Old 04-28-2009, 08:00 PM
wolfeman28's Avatar
Images: 18
Default Re: Two 10" Sub Install In A 2001 Access Cab (pics)
Here is the first layer of fiberglass laid out. I just laid down a garbage bag in the area and put the fiberglass over it. Made for an easy removal. I did screw up slightly since I din't let the spray on sound absorbing stuff cure long enough, so when the resin was curing it got hot and turned the liner to liquid again. No biggie though.
Old 04-28-2009, 08:04 PM
wolfeman28's Avatar
Images: 18
here it is removed and with the rest of the layers added in. This thing is strong as hell, I can stand on it and jump and it doesn't even bend. It came out of the hole uber easy thanks to that garbage bag. I also filled it with water at this point to check the size of the airspace. It will be 0.78 cu ft with the subs in. Perfect for the two Pioneer shallow subs I have for it.
Old 04-28-2009, 08:09 PM
wolfeman28's Avatar
Images: 18
And now the fun part. I trimmed it down to where I need it to be, and it's ready for the top! I cut out a mounting plate for the subs, and I'm JB welding it to the sides of the enclosure. A few clamps and by tomorrow it should be ok to start fiberglassing the top. Once I'm done with the top plate, I'm going to be adding some thick dowel rods to brace the inside- not because the subs are heavy, but because I'm afraid of putting to much stress on the fiberglass with someone sitting on the seat. With all that metal framing I removed, the fiberglass will pretty much be supporting all the weight on that seat.
Old 04-28-2009, 08:12 PM
wolfeman28's Avatar
Images: 18
And last for today, a picture of the remaining material for the enclosure. Hopefully Thursday the weather will be warm enough to get this done. All I need to do is lay down the black fabric and resin it, then add some glass mat to the inside edges and it should be done. Then I'll need to stretch the carpet over the top, drop in the subs and that's it!
Old 04-28-2009, 08:45 PM
wolfeman28's Avatar
Images: 18
Oh and I took the subs out of their boxes today for the first time. Go figure they are the exact same subs, but one is "Premier" and one is not. They look the same, have the same ratings, have the same parts, one just says Pioneer on the cone the other says Premier. Oh well not worth shipping one back and waiting for the other, no one will see them anyway. And they have the same model number... Weird.
Old 04-29-2009, 01:00 AM
fishn101's Avatar
Dealer : Bill Wright Toyota Scion
2005 Toyota Tundra
Last Online: 11-14-2009 11:40 AM
Images: 38
fishn101 will become famous soon enough.
fishn101's Photo Albums
It's looking good so far, similar to the setup I made for mine. One question though, are you planning on recessing the subs to allow for excursion? I had to lower the part of my box containing the sub nearly two inches to allow for the mounting of the sub, excursion and room for the sound to pass into he cab. Granted my sub is larger then yours but it looks like your seat will rest directly on top of the subs.
Old 04-29-2009, 12:19 PM
wolfeman28's Avatar
Images: 18
I have plans for that, you shall see in the coming days
Old 04-29-2009, 04:33 PM
NoKz's Avatar
Was I Speeding Officer?
Dealer : Penske Toyota
2005 Toyota Tundra
Last Online: 11-21-2009 05:05 PM
Images: 19
NoKz is a splendid one to behold. NoKz is a splendid one to behold. NoKz is a splendid one to behold.
Send a message via MSN to NoKz NoKz's Photo Albums
But I wanna see now!
www.OutlawOffroad.com
- Tell Them John w/the Tundra Sent You!
Car Domain: www.cardomain.com/ride/3304446
Old 04-29-2009, 06:14 PM
wolfeman28's Avatar
Images: 18
So I was able to throw on the top layer of fabric, and I just did a test fit in the truck with the seat on. I'm thinking about not worrying about the seat, it barely touches the sub baskets and these shallow Pioneers have no excursion at all, so I think I'll be good. Otherwise I'm just going to modify the bottom of the seat.
Old 04-30-2009, 01:12 AM
fishn101's Avatar
2005 Toyota Tundra
Images: 38
Modifying the bottom of the seat will probably a lot harder than modifying the top of the speaker box, JMHO.
Old 04-30-2009, 09:21 PM
wolfeman28's Avatar
Images: 18
Not on the Limted AC... Just have to unzip the seat and bend some metal framing.....
By the way your sub job is very professional...
Old 05-02-2009, 10:00 AM
2006 Toyota Tundra AC 2wd
Last Online: 05-30-2009 01:12 AM
Robmat05 is on a distinguished road.
Robmat05's Photo Albums
WOW! Looks really good. I'd like to attempt something like this, but I'll see how yours comes out. I think I might do a single 10" so that I don't have to cut to much up. Keep up the good work and lets see more pics.
Old 05-05-2009, 12:46 AM
wolfeman28's Avatar
Images: 18
Got it all done and hooked up today. Sounds great, but I'm thinking about switching to a different brand of shallow subs. the Pioneers hit good in the 60-70hz area, but anything lower just isn't loud enough. Maybe I'll try the Kicker shallows or the Rockfords next.
Old 05-05-2009, 04:36 AM
Dealer : Hellman Toyota
2005 Toyota Tundra
Last Online: 11-22-2009 08:03 PM
Images: 4
sic402 is on a distinguished road.
sic402's Photo Albums
in all honesty look into some lesser known brands, like this guy
DDAudio Digital Designs Speakers Made in the USA
