Anyone used a shallow mount sub in the front door?
+ Reply to Thread
Results 1 to 3 of 3
Thread: Anyone used a shallow mount sub in the front door?
  1. #1
    Join Date
    May 2009
    Location
    Gulfport
    Posts
    42
    Liked
    0 times
    Thanks
    0
    Rep Power
    6
    Default Anyone used a shallow mount sub in the front door?
    When I used the "Fit My Car" tool at Crutchfield, this speaker showed up to fit in my front door of 07 Tundra Regular Cab.
    JL Audio ZR800-CW Evolution™ ZR Series 8" component woofer (midbass driver) at Crutchfield.com
    JL 8" Free-Air Midwoofer. Looks like it could really add some bass without having to put a speaker box behind the seat.
    I also found this one.
    Kicker CompVT 08CVT654 Shallow 6.5" subwoofer at Crutchfield.com
    Kicker Comp 6.5" woofer.
    I would like to add some more bass in the truck without loosing the nice storage space behind the seat. Would you go with this or try and find a shallow mount 6x9?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jan 2003
    Location
    philly, pa
    Age
    35
    Posts
    915
    Liked
    12 times
    Thanks
    0
    Rep Power
    4101
    Default Re: Anyone used a shallow mount sub in the front door?
    Quote Originally Posted by Shadesy View Post
    The real question is what will you have for midrange and higher? I would have to imagine incorporating 2 8 inch or 6.5 inch midbasses or subs into a do-it-yourself three way system would make for a pretty bangin system that will hold its own without a sub. But if you're looking to get bass from your door speakers, maybe 50 HZ and above, you'll need really good deadening and lots of power. Not the kind of thing I'd waste on head unit amplification.
  4. #3
    Join Date
    Jun 2008
    Location
    Dallas
    Posts
    163
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    This is a pretty common set up with the C5 and C6 Corvette owners. My C5 has a kicker 8" midbass in each door, as well as a 4" MB Quart component set. The trick is definately in the installation. You will really need a stiff mounting surface and a lot of dynamat in the door. Would really sound even better if you can make an actual enclosure for the speaker. Power will need to be pretty stiff too, like a nice 600w RMS 4 channel, 2 channels dedicated to the mid / subs. I have a JBL / Crown 600.4 on my Corvette... those amps rock
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
