Question The Big 3 Mod??????
+ Reply to Thread
Results 1 to 7 of 7
Thread: The Big 3 Mod??????
  1. #1
    Join Date
    Jul 2008
    Location
    Peosta, IA
    Age
    37
    Posts
    33
    Liked
    0 times
    Rep Power
    7
    I have heard tid bits about this mod so I tried to do a search on it and I cannot come up with much.....not sure if it's me or what but can someone please either send me to a post about it and how to do it or explain it here? I just upgraded my stereo system in my 08, the subs and amp are going in on Friday to complete the upgrade and I just want to be prepared for what I might have to do. My amp running my subs is a 1000 watt, 2 channel amp and I also have a 600 watt, 4 channel running my doors. Any little secrets anyone has or heads up's of what I might encounter would be really appreciated!
    Todd
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member ChitownTundra's Avatar
    Join Date
    Apr 2009
    Location
    Illinois
    Posts
    187
    Liked
    1 times
    Images
    6
    Rep Power
    25
    Default Re: The Big 3 Mod??????
    Well it sounds like you might have to look out for some nice tunes coming your way... If that is what you are asking?
    2013 RCSB 4x4 White.
    Modification Pictures Here
  4. #3
    Join Date
    Jul 2008
    Location
    Peosta, IA
    Age
    37
    Posts
    33
    Liked
    0 times
    Rep Power
    7
    Thread Starter
    Quote Originally Posted by ChitownTundra View Post
    Well, that is what I am hoping for but my main concern is going to be power, or lack of to the amps....will they draw to much from my battery, are my battery and ground cables going to be heavy enough??? I hear mixed opinions, some say it will be fine, some say I am going to need a optima battery and some sort of a big 3 mod which I think is upgrading the factory cables to the alternator and ground.....
    I'm kind of confused! Afraid I am in a little deeper than what I wanted to be!
  5. #4
    Just Call Me Hank Tankerhank's Avatar
    Join Date
    Mar 2006
    Location
    Tucson
    Posts
    1,415
    Liked
    0 times
    Images
    46
    Rep Power
    29
    Your cable concerns can be figured out by taking your watts divided by volts and that will give you the amps of draw the cable/wiring has to be rated to carry.
    Your 1000 watt amp divided by 12 volts = 83 amps!! Yikeeesss!!!!
    Looks like you need to head off to welding supply to get some really big cable.
    I ran 00 cables in my RV solar setup from the batteries to the inverter to hand the heavy AMP draw, and I was restricted to length of that cable also.
    Hank
    2007 Tundra SR5 DC LB 5.7, Underseat storage, Sonar, Backup Camera, Prodigy brake contoller, Reese 16k 5'er hitch, Towing Mirrors, Michelin LT AT2 275/65R18/E, Hellwig Helper Springs 2,000 lbs, 7/75 Platinum Warranty from Handy Toyota.
    Future mods:
    Stebel 300hz Horn
    Fog Lights
    2000 Tundra (bought 9/9/99)
    JBA Headers
    Gone but not forgotten~
  6. #5
    Slowpoke shooter2jim's Avatar
    Join Date
    Jul 2002
    Location
    Chattanooga, TN
    Posts
    608
    Liked
    1 times
    Rep Power
    20
    I'd doubt seriously that you're going to ever run 1kw RMS continuously..or that the amp could even do it. You probably want to mount the amps close to each other and run 6 or 8ga. red/black straight to the battery with a 30a fuse... maybe 40... (start low first)... installed close to the battery. If you're going to sit with the doors open and jam with the engine off, then get an Optima as a 2nd battery and install an isolator and run the system off the 2nd battery. Installing a big capacitor at the amp will help smooth big power draw on bass thumps. Otherwise, I think you'd be good to go. And for God's sakes, don't take my advice without triple checking with pro installers. There are plenty of members on here who are and I'm not.
  7. #6
    Jedi Ninja in Training mxsjw's Avatar
    Join Date
    Jan 2007
    Location
    Lakewood, WA
    Posts
    8,309
    Liked
    13 times
    Images
    12
    Rep Power
    79
    Moving thread to the Audio Section of Tundra Solutions.
    Beer please!
  8. #7
    Join Date
    Oct 2005
    Location
    Boulder,co
    Posts
    639
    Liked
    3 times
    Images
    4
    Rep Power
    14
    How to upgrade the Big Three
    that explains the whole big 3.
    Dont buy a Cap its a waste of money, do the Big3 and try to run 1/0 wire for the whole thing, and depending on the amps i would run 1/0 to those also, match the fuse to the total fuse rating on the amps, probably be around 100-150.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
