Old 09-13-2009, 10:00 AM
Last Online: 11-18-2009 05:48 PM
Images: 2
gameover169 is on a distinguished road.
gameover169's Photo Albums
Default sub enclosure questions
What is everyone running as far as sub enclosures go in the 07 and newer DC's? I want to fit everything under the back seat. I am going to go with a JL Audio sub and amp package just trying to figure out the best set up to go with as far as enclosures and sub size and quantity go. thanks for the input.
Old 09-13-2009, 10:28 AM
Lymerock's Avatar
Last Online: Yesterday 08:12 AM
Lymerock is on a distinguished road.
Send a message via AIM to Lymerock Lymerock's Photo Albums
Default Re: sub enclosure questions
easiest thing may be to start here Tech12volts.com
he makes DC enclosures to fit under the seat, buy one or copy one, up to you
Old 09-13-2009, 11:41 AM
Jumbo Jet's Avatar
Dealer : Deland Toyota Scion
Last Online: Yesterday 07:38 AM
Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold.
Jumbo Jet's Photo Albums
I built my own, its actually really easy to do if you have a table saw and a jig saw. Mine slides under the rear drivers side seat. I used 3/4" MDF and it holds 2 10" shallow mount subs. If youre building a sealed enclosure its fairly easy to calculate the required airspace of your sub.
2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
Honda Super Cub
Old 09-13-2009, 06:42 PM
Images: 2
I am planning on building my own box. I have done this in my previous trucks but with them keeping the back seat usable didn't matter to me. In my new truck it does. which will sound better a sealed down fire or one shown above
Old 09-13-2009, 07:32 PM
2007 Toyota Tundra Super White SP
Last Online: 11-17-2009 06:38 PM
SuperWhiteHype is on a distinguished road.
SuperWhiteHype's Photo Albums
supercrewsounds.com down firing single and double enclosures
Old 09-14-2009, 02:59 PM
BIOHAZARDCYCLES's Avatar
Last Online: 09-19-2009 09:35 PM
BIOHAZARDCYCLES is on a distinguished road.
BIOHAZARDCYCLES's Photo Albums My eBay
How would you get it to downfire under the seat id like to see that!!.. Theres barely enough room with the sealed box firing up..
Old 09-14-2009, 08:59 PM
Images: 2
The sub im going to go with is only requires only 2.5 in of mounting depth, so i figure ill have some room to play with
Old 09-14-2009, 10:41 PM
Jumbo Jet's Avatar
Sounds like my subs. My Rockfords are shallow too. You only really have at the most 5" of height under that back seat, but you can make up airspace by bringing out the length as well.
Love Jupiter, most beautiful inlet in FL. Snook still stacked up in there?
Honda Super Cub
Old 09-15-2009, 12:58 PM
OT .. i moved here from north palm.. yeah the best way is the way jumbo and i have them..
MURDERED 2010 5.7 TUNDRA DC SR5
SLATE METALLIC W BLACK BUCKETS
Old 09-17-2009, 06:54 AM
Images: 2
Jumbo Jet yea the snook action is pretty good right now, ill probably go try to catch some this weekend if i catch the tides right. Does anyone know if there is a mod you can do to the back seat to gain a few more inches of room?
Old 09-17-2009, 09:21 PM
where did you want the inches?
Old 09-18-2009, 06:54 AM
Images: 2
I would like to pick up a few inches in height, i have a few different ideas for a enclosure on the drivers side. just trying to see how much space i have to work with before I start building.
Old 09-18-2009, 08:13 AM
Jumbo Jet's Avatar
My favorite place is anchored up on the inside for the first 2 hours of incoming...... we've boated some monsters there.
The way I gained a 1/4" or so was to add spacers (washers) under the bottom seat bolts. You can only gain so much height before you throw off the alignment of the bolts on the back wall. But a 1/4- 1/2 " makes a big difference in keeping your subs from hitting the underside of the seat.
Honda Super Cub
Old 11-04-2009, 12:40 AM
Beerking576's Avatar
2004 Toyota Tundra,
2006 Toyota Camry-Solara
Last Online: 11-08-2009 05:17 PM
Beerking576 is on a distinguished road.
Beerking576's Photo Albums
i have a 04 DC. anyone know where i can find a box that goes in the big main storage compartment under the back seat?? i have 2 8" kicker shallow mount cvt's. im not having much luck. someone please help!!!!
Old 11-04-2009, 01:18 PM
tundrunk's Avatar
2003 Toyota Tundra sr5 1wd
Last Online: Today 03:49 AM
Images: 18
tundrunk will become famous soon enough.
tundrunk's Photo Albums
beerking, you might be better off finding the specs of one (like the q-logic) and building it from mdf. most use 3/4 but with 8" subs i have had success using 1/2". if you have the tools, the material will cost less then $30. q-logic sells theirs for over $200! otherwise if you find a good audio shop they can easily build you one for $100 or less. note, you ideally want separate airspace with 2 subs or they will distort each other. however putting them under the seat compromises sound any way so it may not matter. good subs btw, i like kicker.
