Old 10-01-2009, 03:50 PM
Dealer : Kenny Ross Toyota
2006 Toyota 4Runner
Last Online: Yesterday 09:49 PM
eharri3 will become famous soon enough. eharri3 will become famous soon enough.
eharri3's Photo Albums
Default 3 way front stage in a Tundra
Looking at possibly upgrading from my Hertz HSK 165s to a 3 way setup of some sort. As of right now tweeters are in the sail panels, mids are in the doors. But Im really looking for a 3 way setup incorporating a solid midbass driver up front that's good to 55-60 HZ so I can tune my sub lower.
What I was also hoping to do was bring a 4 inch or so mid range into the mix and make use of the dash openings so that the midrange is no more than 6-8 inches from the tweeter. The goal is moving the bass notes solidly in front of me, dedicating one set of drivers to the mid range frequencies and at the same time getting better imaging and more solid vocals by putting the mid range and tweeter close to eachother.
Im tempted because it would seem like a simple thing to just throw some mids into the openings on the corners of the dash, put a 6.5-8 inch midbass in my door openings, new tweeters in the holes I already have in the sail panels, and be done with it without having to cut any more new holes in the interior than I already did for the tweeters. However I am leary of the aiming difficulties involved in making the proper use of windshield reflections. Just wondering if anybody on here with a GEN2 Tundra has a serious 3 way front stage. Specifically the midbass will be in the doors and will be the biggest I can find/afford, but I'm wondering where people are placing the tweeter and midrange, whether they're making use of the dash or putting the midranges higher in the doors, etc... I have my tweeters in the sail panels right now aimed towards the center of the truck but am open to all suggestions, including replacing the drilled sail panels and moving the tweeters to the windshield panels.
Any suggestions or input? It's an 09 Crewmax, non-JBL, with currently disconnected dash speakers in each corner and the empty cenner channel opening below the clock.
09 Crewmax 4x4 5.7.
Stampede bug deflector/ventvisors
Matching front tint.
Pioneer PRemier DEH 980BT
Pioneer Premier Shallowmount 10
Hertz HSK165.
Eclipse rear coaxials.
Eclipse EA4200/Alpine MRP M500
Old 10-01-2009, 05:23 PM
Jumbo Jet's Avatar
Dealer : Deland Toyota Scion
Last Online: Yesterday 09:28 PM
Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold.
Jumbo Jet's Photo Albums
Default Re: 3 way front stage in a Tundra
Check this thread: Worklog - Road RagE II (2007 Tundra)
Rage did a 3 way set up in his crew max. Its a long thread, but well worth the read. Tons of great info in there.
2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
Honda Super Cub
Old 10-01-2009, 10:20 PM
2010 Toyota Tundra
Last Online: 11-23-2009 11:07 PM
tdc_worm is on a distinguished road.
tdc_worm's Photo Albums
i have been debating the same thing. my initial thought is to put the midrange driver in the a piller next to the sail panel. seems like this would point the speaker in the same direction as the tweet, i am just not sure how much room there is to work with behind the panel.
as for the mid bass in the door, depth is the main issue. realistically, i think between spacing the speaker and possible the window frame track there is in the neighborhood of 3.5" of depth to work with. when you do find an 8" mid bass that is not too deep, then you run into the problem of the factory 6x9 square grill that is built into the door panel...which doesnt even line up square over the speaker. i am not sure how you would find the room to keep the speaker from bouncing off of the back of the door panel without cutting it...
hopefully more people will chime in...would love to have a great 3 way front stage myself...
Old 10-01-2009, 11:41 PM
Lymerock's Avatar
Last Online: 11-24-2009 09:35 PM
Lymerock is on a distinguished road.
Send a message via AIM to Lymerock Lymerock's Photo Albums
Q logic is just about done making a kick pannel that will accept a 6" I think. not aware of depth.
find a contact on the website and be a pioneer, im thinking about getting a set myself by next summer
Old 10-02-2009, 06:26 AM
2010 Toyota Tundra
seems like that would get in the way of the E Brake. and your still stuck w/ the each of the 3 way components being more than 12" away from each other and pointed in different directions...
Old 10-02-2009, 12:06 PM
ChitownTundra's Avatar
Dealer : Mark Toyota
2007 Toyota Tundra,
2008 Toyota Tacoma
Last Online: Yesterday 02:41 PM
Images: 6
ChitownTundra will become famous soon enough.
ChitownTundra's Photo Albums My eBay
Putting the Mid in the Dash location does have its problems. Time alignment is necessary and the reflections off the glass can change the tone of the sound as well as the direction.
Im going to be putting my 3" mid and tweeter on my A pillar shooting to the opposite side of the truck. I have used velcro and set them up that way and it sounded tons better.
If you can aim your dash mount mid, that would help too to keep the direct effect off the glass down.
Joe
2007 RCSB 5.7 4x4 Black Sport
Tundra Racing 2/5 Drop, TRD Brakes, Wheels, Swaybar, Exhaust
Morel Elate 3 Way Speakers, Alpine PDX amplifiers, Phoenix Gold Ti 15" Subwoofer in custom enclosure, K40 Laser/Radar Detector, Seat Rail Modification, Back up Camera, Full LED Interior upgrade from VLEDS.com, Homelink Rear View Mirror,
http://s116.photobucket.com/albums/o4/sq60ss/
Old 10-02-2009, 12:53 PM
2010 Toyota Tundra
Joe
i agree. i think i am going to leave the tweeter in the sail and put the midrange in the a piller...they both appear to aim just to the inside of the driver/passenger. the midbass should be fine in the door. not sure what to do about center speaker yet.
one other note...the nav voice appears to be to come from the driver dash speaker only. i am not sure how the JBL DPS directs sound, bu that could turn out to be an issue when making changes...
Old 10-29-2009, 09:53 AM
andoneward's Avatar
Dealer : Valdosta Toyota
Last Online: 10-30-2009 02:12 PM
Images: 3
andoneward is on a distinguished road.
andoneward's Photo Albums
eharri3,
I am planning my 3 way setup too and i am also very tempted to use the factory locations so that it can be a true stealth install. Are you planning to run a passive or active setup?
~Matt
2008 Toyota Tundra Crewmax Bluestreak
CBTMA Member...woot woot!
