Old 10-02-2009, 01:54 AM
Dealer : Anderson Toyota
Last Online: 10-27-2009 09:38 PM
brycerichardson is on a distinguished road.
brycerichardson's Photo Albums
Default rattle after sound deadening
I put a couple layers of raamat and a layer of ensolite on my doors and floorboards, but i still have the stock radio (non jbl) and speakers. It defiantly made a difference on how quiet the cab sounds but the problem now is that the plastic door panels rattle like crazy sometimes. At high volumes on the stock hu it seems to be fine but mid -low volumes it can be so bad you would never have guessed I coated my truck with the sound dampening material.
Is it the crappy stock speakers that are causing this? I ordered my new system and will be replacing all the speakers and the h/u so that might be a fix...If not should I coat the plastic door panels with raamat to try and stop this? or does anyone have any other suggestions/ solutions? all input will be greatly appreciated
thanks
bryce
Old 10-02-2009, 08:28 AM
Jumbo Jet's Avatar
Dealer : Deland Toyota Scion
Last Online: Today 07:38 AM
Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold.
Jumbo Jet's Photo Albums
Default Re: rattle after sound deadening
If you can locate the source, you can add a strip or two behind that panel to kill the vibration. I had a similar problem with one of the doors of my over head console vibrating. A little strip of Dynamat on the back side of the door did the trick.
2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
Honda Super Cub
Old 10-02-2009, 10:45 AM
thanks, I think am going to pick up one of those small packs of dynomat and put it on when I do my speaker install
Old 10-04-2009, 09:57 PM
07bsmcrewmax's Avatar
Dealer : Fred Anderson Toyota of Raleigh
Last Online: Today 12:39 AM
07bsmcrewmax is on a distinguished road.
07bsmcrewmax's Photo Albums
you might try checking the little compartments that have the pop out door on them under the grab handle for the door. My passenger side rattles like crazy.
