Re: quick question about amps
It means its capable of converting a full range signal into only a low frequency range signal (for subwoofer duty) at a point anywhere from 50 Hz to 300 Hz on a 12 db slope (2nd order). example: if your reference point is a 0 db signal, the crossovers' 12 db slope will taper off, or reduce the output of that particular frequency by 12 db for each octave you go down.
Here's some good information. Look at chapter 27 specifically.
Basic Car Audio Electronics
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. Hybrid Audio Technologies drivers and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
