Old 10-14-2009, 04:34 PM
Dealer : Star Toyota
2005 Toyota Tundra
Last Online: 11-19-2009 03:25 PM
bigripper is on a distinguished road.
bigripper's Photo Albums
Default 2005 Tundra AC stereo wire codes
Hi forum members! I'm in the middle of a huge install, and can't even seem to find the correct wire color codes for my 2005 Tundra Access cab. Its got the Fujitsu 86120-0C060 headunit (Its the unit with the amp under the rear passenger seat). I just need the wire colors for the ground, acc, positive, and illumination. None of the diagrams I've found have the colors from my headunit. I'm doing the whole system: amps, subs, front separates, etc.. and can't even get my new headunit in!! Everythings ripped out to the sheetmetal, including the amp under the rear seat. I've even used a volt meter and still can't find the right wires. What am I doing wrong? There are three connectors that plug into the stock headunit, I supposed this is where I'd find the power connections? Am I looking in the wrong place? Going crazy shortly!
I found this, but it doesn't seem correct:
| RADIO 12V|blue/yellow |+ |radio | (no blue/yellow)
| RADIO GROUND|brown |- |radio |
| RADIO SWITCH|gray |+ |radio |
| RADIO ILLUMINATE|green |+ |radio |
Thanks, Greg
Old 10-15-2009, 09:53 AM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Today 06:32 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
Default Re: 2005 Tundra AC stereo wire codes
These are for a 2004 Tundra but they may help you. At least you'll have something to check out.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 10-15-2009, 02:50 PM
NoKz's Avatar
Was I Speeding Officer?
Dealer : Penske Toyota
2005 Toyota Tundra
Last Online: 11-21-2009 05:05 PM
Images: 19
NoKz is a splendid one to behold. NoKz is a splendid one to behold. NoKz is a splendid one to behold.
Send a message via MSN to NoKz NoKz's Photo Albums
Does it have the JBL system? If so, you'll need PAC Toyota Factory Integration Adapter Install a new receiver while retaining your JBL amplifier in select 2003-up Toyota vehicles (Model TATO) at Crutchfield.com
Because the speakers and power go to the amp, then the amp goes to the head unit. Which screws up all of the wiring. I ran into the same issue.
www.OutlawOffroad.com
- Tell Them John w/the Tundra Sent You!
Car Domain: www.cardomain.com/ride/3304446
Old 10-15-2009, 03:50 PM
2005 Toyota Tundra
No JBL system. Does the power go from the amp then to the headunit with the standard 6 speaker system? (i have a Fujitsu stock headunit). Been searching around, and I'm still stuck. 3 connectors plug into the stock headunit, from what I've been gathering the large 20 pin connector is all I need : red/green stripe is constant (pin 1) , ACC is gray (pin 11), illumination is green (pin 2), and brown is ground (pin 20). I plugged in the climate controls, and the amp that was under the rear seat, and still NO POWER to my new headunit!! Tested with voltmeter as well... ARGHH ... no voltage at the above wires.
Thought I had it! Thanks for all your replies... My hair is turning gray by the hour
