Old 11-06-2009, 06:52 PM
2009 Toyota Tundra DC, 5.7L, TRD, White,
2006 Toyota 4Runner Sport Edition, Gray,
- Other - 1988 Chevrolet K5
Last Online: Today 11:26 AM
KP Texan is on a distinguished road.
KP Texan's Photo Albums
Default Crutchfield Master Sheets?
Does anyone have these for the 2nd Gen DC Tundra? If so, I would be very thankful if you could post or send them to me! They normally send them to you in a PDF format if you order from them.
I'm basically looking for info on pulling the interior panels all the way to the back bulkhead so that I can install a sub/amplifier. I've found certain components (door panels, for instance) with DIY's on removal but not all the others. Also, what path are you guys using to run your amp power cables from the battery? Entrance into the cab from the engine compartment? I'm just running a single 8 awg cable so it shouldn't be too hard to find the room.
Thanks so much for the help,
Wes
2009 Toyota Tundra, Double Cab, 5.7L, Super White, TRD Package
Old 11-06-2009, 07:52 PM
Jumbo Jet's Avatar
Dealer : Deland Toyota Scion
Last Online: Today 07:00 PM
Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold. Jumbo Jet is a splendid one to behold.
Jumbo Jet's Photo Albums
Default Re: Crutchfield Master Sheets?
What part of the tear out is giving you trouble? I've taken my interior apart about 6 times already and am about to take apart my buddy's DC on Sunday to lay Dynamat and pull our wires. Let me know what your having trouble with, maybe I can help. If you want to PM me I'll give you my phone number and hopefully help talk you thru it. Its actually very easy to take these trucks apart.
I ran my power wire (4 awg) thru the small rubber boot on the fire wall on the drivers side. There is a small rubber nipple on the bottom of the boot that is empty, its almost as if it was designed for amp wires. Snip the tip of the nipple off and pull your 8 awg thru there. There is also a matching boot on the pass. side. From there I ran my power wire down the drivers side door sills.... there is tons of room under there.
2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
Honda Super Cub
