Old 03-28-2002, 02:00 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 06:22 PM
nhparrot's Photo Albums
Default Antenna TSB
Topic: Antenna TSB
TundraDome
TS Supporter
Member # 1281
Member Rated:
posted 02-20-2002 08:41 PM
The antenna mount seems secure on my Tundra, but the antenna still shakes loose. At my last service, I asked the tech to use lock-tight or some other glue to keep the antenna from vibrating loose. So far, seems to have done the trick.
-- TundraDome
2000 V8 Tundra SR5 4WD Access Cab, Thunder Gray. All stock except: hitch/7pin round harness, interior MAP light mod. Next Mod: Hella Horns
Posts: 16 | From: Santa Fe, New Mexico | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Platinum TS Supporter
Member # 73
Member Rated:
posted 02-20-2002 05:47 PM
quote:
Originally posted by Terry:
I'm thinking class-action suit against the Al-Queda.
I didn't put my flag on my antenna but I'll join in the suit against the Al-Queda.
SATundra
2001, SR5, V8, 4x2, Access Cab, Metallic Silver Sky
MODS: Better Built alum toolbox w/lights 2 inside 2 outside, lots of antennas, CB/Ham/Scanner/linear amp all mounted in custom made console, 10 disc CD player, DEI Sidewinder 5000 ESP alarm, undercarriage entry lights, extra set 55W reverse lights, underhood light, TRD add-a-leaf (ordered), Lund bugshield, chrome step tubes, UTR bedliner, hitch, tinted windows, fuzzbuster hard wired, 4 block power terminal under dash, 12V Acc plug engine compartment, synthetic oils, fog light mod, cargo light mod, acc plug mod, map light mod, back seat angle mod soon, 2 TS stickers (back windows), 2 TS license plate frames (front, rear)
Posts: 461 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
Terry
TS Member
Member # 716
Rate Member posted 02-20-2002 05:41 PM
My antenna was just fine until the flapping American flag made it work loose at the base. I'm thinking class-action suit against the Al-Queda.
Posts: 5 | From: Seattle WA | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Member # 12
posted 02-20-2002 04:20 PM
For those wondering
TSB AU002-01
Antenna Mast Durability '00 - '01 Tundra
Introduction - Some customers may experience a loose Tundra antenna due to the breakage of the antenna holder. A revised antenna holder assembly is available to resolve this issue.
Part 86300-0C010
Repair - Replace Antenna Holder Assembly
~Glenn~
Moderator
Please consider a TS Supporter or Platinum TS Supporter subscription
Posts: 493 | From: New Hampshire | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Member # 73
Member Rated:
posted 02-20-2002 04:10 PM
quote:
Originally posted by nj1266:
Ok, here is what is happening on occasion with my radio. Every now and then, my radio looses reception and jumps the preset channel. It just loses reception for some reason.
Is that related to the Antenna TSB?
Your problem does NOT sound like a TSB related issue. The TSB is just for a LOOSE antenna MOUNT. Sounds like the dealer might need to look at your radio. Or if you know how check the connection where the antenna plugs into your radio, that just might be loose.
SATundra
nj1266
TS Member
Member # 786
Rate Member posted 02-20-2002 03:36 PM
Posts: 24 | From: Long Beach, CA | Registered: Feb 2002 | IP: Logged
red's tundra
Member # 308
Member Rated:
posted 02-20-2002 02:18 PM
The TSB is from June of 2001 and refers to 00 and 01 Tundras. I'm ot sure if it carried into the 2002 model or not.
Posts: 177 | From: Campbell, CA. | Registered: Feb 2002 | IP: Logged
Ricey
TS Supporter
Member # 203
Member Rated:
posted 02-20-2002 02:09 PM
Chris,
Is it for 2000's or does it include 2001s and 2002s?
Ricey
Posts: 37 | From: N. Attleboro, MA | Registered: Feb 2002 | IP: Logged
red's tundra
Member # 308
Member Rated:
posted 02-20-2002 01:36 PM
Glenn,
Check your email. I sent them over to you. I didn't realize that email adresses were displayed publicly.
Chris
ra1nman
TS Supporter
Member # 63
Member Rated:
posted 02-20-2002 01:24 PM
I realized I needed mine replaced when I herd it rattling around on the highway. Yes it does kinda loosen up from the fender. If you grab the base of the antenna and it moves around, you need it replaced
Posts: 94 | From: Appleton, WI | Registered: Feb 2002 | IP: Logged
red's tundra
Member # 308
Member Rated:
posted 02-20-2002 01:19 PM
I also have one of the rear brake TSB if you want it. It didn't come out very well, but you can still see it.
red's tundra
Member # 308
Member Rated:
posted 02-20-2002 01:16 PM
Glenn,
The TSB is one that was put out by Toyota, not the NHSTA. The number is AU002-01. I have a JPG of the actual TSB. Send me an email and I will reply with the attachment, unless you know of another way I can show it to you.
Chris
2000LtdKen
TS Supporter
Member # 70
Member Rated:
Glenn,
Had the same problem with mine. The dealer just replaced it under warranty. I did change antennas afterwards to a shorter version that I got from Radio Shack. It is only about 18" long and the reception is decent. No more problems after that.
Ken
Posts: 31 | From: Southern CA | Registered: Feb 2002 | IP: Logged
nhparrot
Moderator
Member # 12
posted 02-20-2002 01:07 PM
Does anyone have any info on the antenna TSB - IS it beacuse the antenna loosens up from the fender?
Thanks
~Glenn~
Moderator
