stock speaker info
Topic: stock speaker info
jkreese
TS Supporter
Member # 721
Member Rated:
posted 02-15-2002 12:43 PM
Yo Chris S,
Were the Polks direct replacements or did you have to make some modifications to mount them?
Thanks.
Posts: 18 | From: Park City, UT | Registered: Feb 2002 | IP: Logged
Chris S
TS Supporter
Member # 93
Member Rated:
posted 02-14-2002 09:07 PM
I don't know, but I replaced both pairs of speakers w/ 4 ohm Polk components, and they sound MUCH better!
FWIW, I have a Ltd. w/ the in-dash changer.
Posts: 21 | From: Austin, TX | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Platinum TS Supporter
Member # 73
Member Rated:
posted 02-14-2002 05:15 PM
Thanks guys, I'm gonna assume that the fronts are the 4 ohms until I can pull the door panel off and check to make sure.
Joe - SATundra
2001, SR5, V8, 4x2, Access Cab, Metallic Silver Sky
MODS: Better Built alum toolbox w/lights 2 inside 2 outside, lots of antennas, CB/Ham/Scanner/linear amp all mounted in custom made console, 10 disc CD player, DEI Sidewinder 5000 ESP alarm, undercarriage entry lights, extra set 55W reverse lights, underhood light, TRD add-a-leaf (ordered), Lund bugshield, chrome step tubes, UTR bedliner, hitch, tinted windows, fuzzbuster hard wired, 4 block power terminal under dash, 12V Acc plug engine compartment, synthetic oils, fog light mod, cargo light mod, acc plug mod, map light mod, back seat angle mod soon, 2 TS stickers (back windows), 2 TS license plate frames (front, rear)
Posts: 461 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
hovisimo
TS Supporter
Member # 378
Member Rated:
posted 02-13-2002 06:10 PM
i wonder how the amp is configured to work with this setup? i've been debating the whole impedance issue myself. if i wired 2 4@ 6.5" speakers and the stock tweeters in sequence, would it work with the stock amp?
-Ryan
my page
Posts: 248 | From: Pennsylvania | Registered: Feb 2002 | IP: Logged
Hover
Member # 110
Member Rated:
posted 02-13-2002 01:53 PM
I ran across this picture the other day and remembered about your situation but just forgot to mention it.
If I remember right, the only one of the speakers you had had the long dustcap (or whatever you call it) in the middle of the speaker. Whoever made this pic could have just used the rear speaker for the pic but who knows...
[ My Tundra | Tundra Picture Archive (1,600+ pictures) ]
Posts: 280 | From: San Antonio, TX | Registered: Feb 2002 | IP: Logged
Bugser
Member # 296
Member Rated:
posted 02-13-2002 11:11 AM
I can't remember either but... I'm thinking that since the front speakers are wired in series with the tweeters, the 4 ohm speaker and tweeter would have the same impedence as the 6 ohm speaker.
Thus making the 6 ohm rear speakers.
2000 Tundra, V8, SR5 Access Cab, Blue/Gray 2 Tone Paint, Running Boards, Color Keyed Fender Flares,Tinted Windows, Bed Liner, K&N Air Filter, Borla Dual Exhaust, Reese Towing Package, VIP RS 3000 Security System, JVC Cassette Deck/12 Disc Changer, JVC 9 Band Equalizer, 6 1/2" 3 Way Speakers & Tweeters in Doors, 600 Watt 4 Channel Amp, 500 Watt 2 Channel Amp. and 450 Watt Subwoofer. Replaced OEM Horns, Power Outlet Mod. Map Light Mod. 17X8 Rage 160 Polished Rims and 275/60/17 Continental Tires!!
Posts: 189 | From: NC Sandhills | Registered: Feb 2002 | IP: Logged
Jwitz
TS Supporter
Member # 119
Member Rated:
posted 02-11-2002 05:44 PM
If I remember right, the front stock speakers were 4ohm and the rear were 6ohm.
Just roll with it...
2001 Tundra SR5 V6 5spd 4x4
2.5" Fabtech lift w/ rear add a leafs, JL, Rockford, Pioneer stereo system, CB radio, Homemade diff breathers and sway bar disconnects, 31" Duler A/T's on the stock rims
Posts: 88 | From: Auburn, AL | Registered: Feb 2002 | IP: Logged
SATundra
Moderator
Member # 73
Member Rated:
posted 02-11-2002 05:28 PM
Can someone tell me about the stock front speakers. Are the stock front speakers the 4 ohm or the 6 ohm. I have 2 sets but can't remember which was which. 1 of them, the 4 ohm has larger tweeters than the other ones. Anyone know? Thanks.
SATundra
