Parrot Bluetooth MKi9100 w/IPOD in a 2006 Highlander w/JBL audio
+ Reply to Thread
Results 1 to 1 of 1
Thread: Parrot Bluetooth MKi9100 w/IPOD in a 2006 Highlander w/JBL audio
  1. #1
    Rookie oldenewe is on a distinguished road.
    Join Date
    Feb 2011
    Location
    MD
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default Parrot Bluetooth MKi9100 w/IPOD in a 2006 Highlander w/JBL audio
    I've been attempting to install the MKi9100 in my 2006 Highlander with JBL option for quite some time now. I purchased the QCJBL1 harness from www.quickconnectproducts.com but it does not allow for complete plug and play integration. There is a QCJBL2 connector however this harness apparently does not work with the 2006 Highlander as noise develops in the lines when cutting in pre-amplifier.
    The solution I am told by the harness maker is to customer run the speaker in and outs to the factory amp in rear and it should work. Problem is that the factory amp wiring is hard to make heads or tails of. The speaker out connections (to the speakers) I have figured out but it's the input from the harness to the amp that has me stumped.
    Has anyone ever wired anything to one of these amps or have any tips as to how I would cut into the amp source? The schematic is attached.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
