Overhead monitor
+ Reply to Thread
Results 1 to 6 of 6
Thread: Overhead monitor
  1. #1
    AGC
    AGC is offline
    Rookie AGC is on a distinguished road.
    Join Date
    Oct 2003
    Location
    NYC/NJ
    Age
    41
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Question Overhead monitor
    How hard is it to insatall an overhead monitor, I have a 02 Sequoia Limited w/sunroof. I originally wanted to install them in the headrest but decided to install an overhead instead because I didn't want to cut into the leather. Also what is a good size monitor.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member DCTUNDRA is on a distinguished road. DCTUNDRA's Avatar
    Join Date
    Nov 2003
    Location
    Dayton, OH
    Posts
    114
    Liked
    0 times
    Rep Power
    10
    Quote Originally Posted by AGC
    There are several suppliers that will sell you a headrest with the screen already installed. Typical price seems to be from $250 to $300. Check on ebay or some of the other internet electronic sites.
  4. #3
    Junior Member rizico is on a distinguished road. rizico's Avatar
    Join Date
    Sep 2003
    Location
    LULING, TX
    Age
    30
    Posts
    267
    Liked
    0 times
    Images
    3
    Rep Power
    10
    I have a 8 inch wide screen flip down monitor in my 03' Tundra, It is a bit big for just the small back seat of a Tundra, but I think the size would be perfect for a Sequoia. I installed it myself and it wasn't much trouble to me, and it shouldn't be if you have had experience in removing panels and runnig wires and things. The screen is made by ProVision and is very clear. Be very aware of price when buying a screen, I paid $300 for mine, there was a $200 about identical to it, but was a different brand, I got the salesman to hook them both up, and you couldn't even make out the credits of a movie on the $200 screen!! It was just blurry lines, so the more you pay, the more Dots Per Inch you will get is what I assume.
    HTH,
    2007 Tundra CrewMax 4X4 Limited
  5. #4
    No Really, I swear, I'm Done.. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone is a name known to all. Imdone's Avatar
    Join Date
    Mar 2001
    Location
    Peoria, AZ
    Posts
    3,110
    Liked
    2 times
    Images
    40
    Rep Power
    279
    Quote Originally Posted by rizico
    HTH,
    Did you need to do any exterior attaching or is it just replacing the dome light and using the dome light bracket, or is it a velcro/silicone type of install?
    TRD S/C, RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, TIMBREN, HYPERTECH
  6. #5
    Join Date
    Sep 2003
    Location
    LULING, TX
    Age
    30
    Posts
    267
    Liked
    0 times
    Images
    3
    Rep Power
    10
    It called for some 1/2" wood screws to drill thru the attachement bracket of the screen and then thru the Headliner! This was unacceptable so I drilled 2 holes in the attatchment bracket in the same places as the 2 screws that hold the dome light in, and i just used those screws, that away I can go back to stock if need be without any problems.
  7. #6
    Join Date
    Mar 2001
    Location
    Peoria, AZ
    Posts
    3,110
    Liked
    2 times
    Images
    40
    Rep Power
    279
    Cool how about the wiring, are there many wires that run to the actual screen like a power, ground, din cable, or is it just an RCA bundle? Thanks.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
