Originally Posted by 03SilverSky
I'm looking at my window sticker from my Tundra. Under standard equipment it states -P245/70R16 Radials. Under optional equipment it states -P265/70R16 Radials. (It is indeed equiped w/ 265's)
I am wondering if the speedometer and odometer is calibrated for the 245's. If that is the case are my readings off due to the larger optional tires?
Yes the truck is set at the factory to read speeds with the 245's since THOSE are the "base" model equiptment. There was a GOOD thread on this subject a few years ago.
Would someone PLEASE post the conversion tables again? Thanks.
SATundra
2001 Limited, V8, 2wd, TRD, Metallic Silver Sky
MODS:
TIRES: Michelin LTX M/S LT265/75/R16 load C rated
SUSPENSION: front - red/blu 4x4 HD Bilsteins shocks & HD TRD 4x4 coils providing 1.75" lift, rear - TRD add-a-leafs, Hellwig swaybar, yell/blu 4x4 Bilsteins
INTERIOR: CB-Ham/Scanner/150W linear amp in custom console, 10 disc CD player, Donnelly comp/temp mirror, Toyota All Weather floormats, tinted windows, radar detector, backseat angle mod,
EXTERIOR: Grizzly SS brushguard, Better Built alum toolbox w/lights, Weatherflector Ventvisors, chrome step tubes, UTR bedliner, hitch, SteelHorse Bull Rings, Mobil 1 oils, 2 TS stickers, 2 TS license frames, 2 www.TundraSolutions.com stickers,
ELECTRICAL: 55W undercarriage entry lights, extra set 55W reverse lights, 55W underhood lights, DEI alarm, 12V Acc plug/engine compartment, 400watt power inverter, foglight/cargolight/acc plug/maplight mod
