Is it OK to use....
+ Reply to Thread
Results 1 to 4 of 4
Thread: Is it OK to use....
  1. #1
    Veteran Member Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue likes to be on top. Stone_Blue's Avatar
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,033
    Liked
    292 times
    Rep Power
    12181
    Default Is it OK to use....
    a 100W amp with 180W speakers?...The volume will never be turned up past 3/4s at most...
    Also, is it OK to use the stock speaker wiring to and from the amp?...I want to splice the input/outputs to the amp near the stock radio plug. I want to be less intrusive/destructive to the stock wiring as possible, in case I ever sell the truck, so I can pull the amp & speakers and go back to stock.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Beer Me ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra has earned a doctorate in rep power. ZapcoTundra's Avatar
    Join Date
    Feb 2008
    Location
    Central California
    Age
    25
    Posts
    1,636
    Liked
    352 times
    Images
    57
    Rep Power
    22264
    Default Re: Is it OK to use....
    first ? is yes you certainly can, that speaker wont ever ever play at 180w anyways, the voice coil will smoke like a newlywed wife trying to cook.
    second, yea you can, but its pretty easy to run an loc and rcas to the back, but to each his own...
    Jason
    It's got 4 wheels with a bed and it starts every time I turn the key.
    If You seek advice, then LISTEN with your EARS not your MOUTH.....
  4. #3
    Join Date
    Mar 2012
    Location
    NY
    Posts
    1,033
    Liked
    292 times
    Rep Power
    12181
    Thread Starter
    But my HU doesnt HAVE rcas. Also, I would still have to run wires from the amp, and then cut into the harness to feed speaker wires thru the door grommets... ???
  5. #4
    Join Date
    Feb 2008
    Location
    Central California
    Age
    25
    Posts
    1,636
    Liked
    352 times
    Images
    57
    Rep Power
    22264
    thus the line output converter, there are a ton of companies that make them, a good one is audiocontrol. or jl's cleansweep, jbl has one as well that is pretty good.
    you tap signal from h/u then the box (line out converter) has rca outputs to connect to an amplifier. and if you really want you can just run speaker wire to the oem harness, but doing that takes just as much effort as running them to the doors.
    its not very difficult to get past the oem grommet for the doors i promise you. it just takes some patience. if you want a trick of the trade, go to your local hardware store and get a big Fxckin zip tie. tape one end with speaker wire attached and feed it through. its easy as pie.
    but thats my opinion...
    Jason
Posting Permissions
  • You may not post replies
  • You may not edit your posts
