Upgrade Do I have a JBL SYSTEM OR NOT? Need help
+ Reply to Thread
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By SuckersWalk
Thread: Do I have a JBL SYSTEM OR NOT? Need help
  1. #1
    Rookie sergfuentes is on a distinguished road. sergfuentes's Avatar
    Join Date
    Feb 2013
    Location
    Huntington Beach
    Posts
    4
    Liked
    0 times
    Images
    2
    Rep Power
    0
    Default Do I have a JBL SYSTEM OR NOT? Need help
    I have an 05 tundra limited trd stepside. I want to upgrade the factory stereo to an aftermarket double din in-dash navigation system. My question is do I need to buy an integration adapter for the factory JBL System? How do I know if I have a JBL system? (I do not see any JBL markings on factory stereo or on door panel grills.) Second, is any of the trucks electrical components connected to the factory stereo? What installation accessories do I need to complete the in-dash navigation installation besides the head unit? Thanks
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk has earned a doctorate in rep power. SuckersWalk's Avatar
    Join Date
    Aug 2009
    Location
    STL
    Posts
    2,666
    Liked
    855 times
    Images
    24
    Rep Power
    21818
    Default Re: Do I have a JBL SYSTEM OR NOT? Need help
    Quote Originally Posted by sergfuentes View Post
    Mine has "jbl" on the head unit and also on the speaker grills. I also have the jbl amp on the rear wall. Go to crutchfield dot com and plug in your vehicle info and select the nav unit; it will tell you what you need.
    jdrama12 likes this.
    2005 Tundra DC Limited 4wd - Phantom Gray Pearl
    Quote Originally Posted by Thundra04struck View Post
    I hope you bought a Tundra because you needed a truck and not for the outstanding gas mileage it is NOT known for.
    Search for your answer. http://www.tundrasolutions.com/forums/1gen-tundra/106548-how-to-search-this-forum/
  4. #3
    Join Date
    Feb 2013
    Location
    Huntington Beach
    Posts
    4
    Liked
    0 times
    Images
    2
    Rep Power
    0
    Thread Starter
    I tried the crutchfield site but its unclear. It says if JBL system equipped and on some models. Does not specify for my particular one. Maybe I should call the dealer
  5. #4
    Rookie Jay O is on a distinguished road.
    Join Date
    Feb 2013
    Location
    United States
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Mine says JBL on the doors but not on the dd????
  6. #5
    Rookie Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some. Canehdianman has done just about everything...and then some.
    Join Date
    Jun 2012
    Location
    Calgary, AB
    Posts
    14
    Liked
    8 times
    Images
    15
    Rep Power
    0
    I am having a very similar problem. I have a 2005 Tundra SR5 Access Cab. My head unit says JBL on it. However, I replaced the speakers (which had no name on them at all), and the factory amp (which was made by Panasonic).
    Here is the head unit -
    And here is a picture of the door showing no JBL logo on the speakers at all (unlike SuckersWalk states above?) -
    I have also replaced the head unit. I am using the Scosche TA07SR adapter, as that it is the one that is needed for JBL systems. It isn't working at all, I am getting no power to my head unit (which is making me question whether I have the JBL system or not). I know that the TA07SR adapter is designed for if you want to keep the factory amp. That was my initial plan, but upon seeing how crappy it is, I swapped it out for a new one and re-wired all of the speakers to the amp.
    My hope is that I could simply use the aftermarket harness on the TA07SR (without using the separate module). Given the fact that it isn't working, perhaps I'm using the wrong part and should go get a standard aftermarket harness instead.
    Thoughts, o' gurus of audio/stereo?
  7. #6
    Junior Member UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder is almost part of the TundraSolutions family. UPbuilder's Avatar
    Join Date
    Feb 2012
    Location
    U.P. of Michigan
    Posts
    347
    Liked
    186 times
    Rep Power
    5945
    Quote Originally Posted by Canehdianman View Post
    You need a completely different harness if not using the factory amp. This one from Amazon will work . The wires will be marked for speakers/power/ground/etc. Just hook them up to the corresponding wires on the plug from your new stereo. Better yet search for the correct plug to go from the vehicle directly to your HU.
    eta: Walmart or Best buy also carries a Toyota harness, not Scosche and can't remember the name or # of it but they have it.
    2003 Tundra SR5 TRD AC, Bilstein 5100's top notch, diff drop, ES steering rack bushings, Wheelers single leaf AAL's, the "No-fan mod".
    http://thebrakedoctor.com
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
