Old 01-29-2004, 12:49 PM
rizico's Avatar
Dealer : San Marcos Toyota Scion
2003 Toyota Tundra,
2007 Toyota Camry the Wifey's
Last Online: 09-15-2009 05:43 PM
Images: 2
rizico is on a distinguished road.
Send a message via MSN to rizico rizico's Photo Albums
Question Power Amplifier?
Did the 03' trucks come with power amplifiers? The wiring diagram does not show it for the 03's, but my truck has one?? I only ask because looking at the wiring diagrams for the 00-02 tundras it shows radio and player diagrams with and without the power amplifier, but the diagram for the 03' does not. Also, is there any way that the Radio and Player diagram for the 03' could have a typo? it shows that the right rear midbass gets a pos and a neg (+) and (-), but that the left rear midbass gets two pos (+) and (+).
~Johnny-Don~
My Webpage
Exterior-SS Nerf Bars, Bed rails, Delta tool chest, Sylvania silverstars in headlights (removed, burned out too often), Flowmaster Muffler w/2 SS corvette tips, MY foglight mod, K&N FIPK
Interior-Pioneer AVIC-D2, Grey marble dash kit, fluorescent lights, DVD player, AVIC D@ Navigation, TV tuner, Remote start security system, 600w power inverter, 800w Kenwood amplifier, 10" Kicker SoloBaric in custom (My own design & Work!) box
Factory/Port-LSD, power slider, 17" split-spoke alloys, color-keyed:grille, bumper, mirrors, and side moldings, steering wheel audio controls, limited seats, heated side-view mirrors, compass/temp rearview mirror, tow package, heavy duty battery/alternator, in-dash 6cd changer/tape player, tint by Madico, custom glass etching, permavin security, RS3200 VIP security.
Old 01-29-2004, 01:04 PM
dunwithdodge's Avatar
Last Online: 01-19-2005 07:50 PM
dunwithdodge is on a distinguished road.
dunwithdodge's Photo Albums
I believe that 6 speaker systems (including the tweeters) have an amp and the 4 speaker systems do not. At least this was the case with my 4 speaker (Front only) 2001 regular cab.
Old 01-29-2004, 11:23 PM
Dealer : Motor Imports
2002 Toyota Tundra
Last Online: 07-15-2009 11:44 PM
jmats1 is on a distinguished road.
jmats1's Photo Albums
Does anyone know the power of the factory amps? And any thoughts on component speakers that sound good powered with it? Looking to upgrade speakers all around for now. Thanks in advance.
Old 01-30-2004, 06:40 AM
sessiondrummer's Avatar
Dealer : Price Toyota
2003 Toyota Tundra
Last Online: 03-13-2008 04:05 PM
sessiondrummer is on a distinguished road.
sessiondrummer's Photo Albums
Yes the 03's have a built in amp, it's behind the dash and bolted to the firewall. I don't know for sure but I thought I heard that it was like 20 watts for the fronts and 14 for the rears. Not really much going on with it, rear speakers are like 6 ohms and the fronts are 4, I think. If you're thinking of upgrading, I highly recommend upgrading the amp (If you're going high power) or at least, upgrade the head unit (lower power). Check my sig. as there is a picture of the stock speaks. One look at the factory speakers and you'll understand why they sound so blah.
S.D.
Old 01-30-2004, 08:08 AM
Brandon1's Avatar
Moderator
Dealer : Leith Toyota
2003 Toyota Tundra
Last Online: Today 08:57 PM
Brandon1 will become famous soon enough. Brandon1 will become famous soon enough.
Send a message via AIM to Brandon1 Brandon1's Photo Albums
you will definatly have to have an amp or hu for components. They need at least 25 watts rms to sound even halfway decent.
Brandon
Old 01-30-2004, 02:58 PM
2003 Toyota Tundra
Brandon
I'm backing Brandon on this one. Comps. really need an amp to drive them. My only thought is if you're really strapped for cash, if you found some very sensitive coax speakers (like 93 dB), you could get away with head unit power.
S.D.
Old 01-30-2004, 03:27 PM
2002 Toyota Tundra
Thanks for the input guys. By looking at the Crutchfield speaker fittings, they have Alpines SPS-170A coaxs with 92dB sensitivity, 2-40 RMS for the rear and Pioneers TS-C1653 6.5 comps with 90dB sensitivity, also 2-40 RMS for the fronts. If I go this route, I will need to hear these speakers, but they have to sound dramatically better than the stock cones right? Or should I not even waste my time?
Old 01-30-2004, 03:46 PM
2003 Toyota Tundra
Well this is just my opinion of course, but I think the 92 dB would be better just looking at the sens. not necessarily the brand or quality of the speaker. Most times (not always), when they spec. speaker power if the first or starting number is low like 2, in your case, that implies that head unit power would be fine. This is because for the most part most head units really only put of 15-20 Max., not what they claim, or PEAK numbers which don't really matter. It's not to say that the other speakers which are 90 dB and are spec'd to run (2-40) would be bad either but it might be quieter than you'd lke. As an example, my last Toy truck had Infinity Kappa comps., rated at 89 dB, and I had around 100 watts a piece to them, and I really had to crank it up to get any appreciable level out of them, and that's with 100 watts. 90 dB is starting to get into that (might be loud enough, might not) range.
I've used plenty of 6X9's and 6.5 coaxiles in other installs that were 92 or 93 dB and the head unit was plenty. Unless you really understand the dB scale, it's confusing.
To get (for example) the same output out of a speaker rated at 89 dB, and a speaker rated 92 dB, you'd have to put twice the power to the 89 dB speaker as it is 3 dB LESS sens. It may not sound like alot but as the power multiples go up, it gets VERY expensive to double power., ie. 10,20,40,80,160,.320, etc.
Just my .02
As far as the "should I bother or not". You can't go wrong with ANY speaker choice. Check my sig. and look at my photo of the stock driver. Very lame. I was really expecting MORE with my "6 speaker Premium system", but alas, it is a Dealer system. I think any speakers, with or without an amp, will make you very happy.
S.D.
Old 01-30-2004, 04:21 PM
OKCTundra's Avatar
Dealer : Dub Richardson Toyota
Last Online: 01-17-2009 12:33 PM
OKCTundra is on a distinguished road.
OKCTundra's Photo Albums
And the great thing is, if you decide it's just not quite what you want, then you can find a cheap amp and throw quite a bit more power to them. Back in the olden days I had a '79 Z28 with Jensen Triax II 6x9s powered by a Sparkomatic amp!! Still sounded a helluva lot better than stock.
White 2000 SR5 4x2 Tundra
22x9.5 ADR Magnus wrapped in Toyo Proxes S/T 305/40/22, S&S long tube headers & Y-pipe, R.A.P.S., Trenz grill, clear corners, X-Pel Clear Bra, HID Conversion Kit, 55W auxiliary reverse lights, Sir Michaels roll pan w/ hidden hitch, EuroTails, DeBadged, Granite dash kit, IS color keyed bumper, fender flares & mirror covers, Hellwig Anti-Sway Bar, CST leather interior, sound deadener all 4 doors, rear wall and floor pans, Nu-image guage cluster & A/C panel, blue split loom, PPD billet TB cover and fuse box cover, painted calipers & drums, dropped the rear 2" w/Belltech 6400, Color-keyed body side molding, Alpine H/U, Archos 20GB Jukebox Multimedia wired to H/U, JBL 1200.1 pushing 2 RE XXX 10s in a custom console box, RF 551X pushing Diamond Audio M561 comps in the doors and Alpine SPR-175 comps in the kicks, and JL Audios in rear straight from the H/U
Old 01-30-2004, 07:07 PM
2003 Toyota Tundra
I'll second the Sparkomatic, and raise you a Kraco.
S.D.
Old 01-30-2004, 09:26 PM
2002 Toyota Tundra
SD-
Class is in session!
Which spec is more critical then, the sensitivity level or the recommended power range? Let's say for instance a comp system with 10-100 RMS and 92dB vs. comp system with 2-40 RMS and 90dB? (unfortunately powered by the factory installed amp for now anyway) Thanks.
Old 01-30-2004, 09:31 PM
ipedal's Avatar
Dealer : Hoover Toyota Scion
2003 Toyota Tundra
Last Online: 07-10-2007 09:19 PM
ipedal is on a distinguished road.
ipedal's Photo Albums
OKC,
In the '60's I used to put 2 8" Radio Shack speakers in the bottoms of 18" tall round rubber garbage cans turned upside down, screwed to the floor behind the rear seat of my VW's and drive 'em with a Sparko or some kind of $20 amp and they were swell. Of course you had to duck if you did like I did one night and rear ended a Buick. Those suckers came across both seats and put some dents in the windshield.
bill, grand funk killed my ears, g
Fair weather ride: '67 Chevelle Ragtop
Old 01-30-2004, 09:56 PM
2003 Toyota Tundra
Cool
SD-
I'd say the sens. would be more important. The recomended power is more secondary. I think OKC is right. Better to buy a higher quality, or more appealing to you (could be less sens.) speaker, and decide later if you've got enough power or not, as opposed to a crappy (very efficient) speaker that will sound bad, or you will not like regardless of the power. Go with the sens. spec. if you have to choose.
S.D.
