How did you run your amp's power wire?
+ Reply to Thread
Results 1 to 14 of 14
Thread: How did you run your amp's power wire?
  1. #1
    Junior Member F1Jim's Avatar
    Join Date
    Sep 2003
    Location
    Columbus, GA
    Posts
    252
    Liked
    0 times
    Rep Power
    12
    Default How did you run your amp's power wire?
    What is the best route for my amp's power wire to take to get through the firewall and to the battery? I have a Sequoia, but I imagine they are the same as the Tundra in the area of the driver's foot well, yes?
    thanks!
    Jim
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member dunwithdodge's Avatar
    Join Date
    Dec 2003
    Location
    Austin, TX
    Posts
    91
    Liked
    0 times
    Rep Power
    12
    Quote Originally Posted by F1Jim
    thanks!
    Jim
    On the Tundra there are two large rubber boots on each side of the firewall. The one on the battery/driver side is the one I used and it comes out above the foot rest on the left side of the driver's footwell. I started at the battery and worked it inside.
    This probably isn't the best way, but I used a long #3 blunt phillips screwdriver (that was a little smaller than my 8 gauge wire) to poke through, being careful not to damage the wiring harness. After installation is complete, put a dab of Permatex silicone windshield sealant. It will flow in around the crack to seal everything well.
  4. #3
    Join Date
    Mar 2003
    Location
    Honolulu, HI
    Posts
    112
    Liked
    0 times
    Rep Power
    13
    You can feed at least a 2Ga wire through the stock firewall grommet on the driver's side without poking a hole into the grommet, though that would surely work. It already carries a wiring harness. The grommet has a nipple on it, with tape that starts on the nipple and runs onto the wiring harness. Carefully peel the tape off and pull the grommet out of the hole in the firewall- this gives you some working room. You can use a thin screwdriver or wire hanger with the tip taped to a length of cord. Run it from the cabin side of the grommet, being very careful not to damage the wiring harness, then untape the cord. Tape the cord to your power cable and carefully work the cable through the grommet. Take your time - a 2 to 4Ga cable has some girth. Once you have it passed through into the cabin, simply retape the grommet to the harness/cable bundle, reinstall the grommet into the hole in the firewall, and you're done.
    Hope this helps.
  5. #4
    Supporter JnEsPappa's Avatar
    Join Date
    Jul 2002
    Location
    Lafayette, LA
    Age
    46
    Posts
    1,642
    Liked
    0 times
    Rep Power
    15
    Here's what I did with my 4 ga. wire: http://www.sounddomain.com/memberpage/372071/4
    - Mark
    Just a hangin' out.
  6. #5
    mgp
    mgp is offline
    Supporter mgp's Avatar
    Join Date
    Sep 2002
    Location
    Watauga, Tx
    Posts
    93
    Liked
    0 times
    Rep Power
    13
    thanks!
    Jim
    I ran my 4 ga wire thru the driver side rubber boot under the main wire harness. I used a long phillips screwdriver and taped the wire to it. I then put some wire pulling lubricant(available at Home Depot etc) on the cable and it pulled thru easily.
  7. #6
    Join Date
    Sep 2003
    Location
    Columbus, GA
    Posts
    252
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    Thanks folks!
    NOW, how did you make the actual connection to the battery? I would prefer not to actually go directly to the battery's "lug" or whatever you call it. I would like to be able to connect at a point near the battery. Imagine a big cable coming off the + pole of the battery, that is a foot or so long. And at it's other end of the cable is a point where it branches off to go to the various components? Get the idea? Does that exist on our truck?
    thanks again
    Jim
  8. #7
    mgp
    mgp is offline
    Join Date
    Sep 2002
    Location
    Watauga, Tx
    Posts
    93
    Liked
    0 times
    Rep Power
    13
    Thanks folks!
    thanks again
    Jim
    Check out my photos. 4 ga wire fused at battery back to a fused distribution block with 8 ga running from it..
  9. #8
    Junior Member JeffD's Avatar
    Join Date
    Jul 2002
    Location
    Jupiter, Fl
    Age
    42
    Posts
    417
    Liked
    0 times
    Rep Power
    14
    I cheated and ran my power wires (2) under the body, one wire up through a hole into the compartment under the rear seat to an amplifier there, and the other up through a hole under the passenger seat to an amplifier there. I ran both wires through heavy rubber grommets. I used to check the entire run for rubbing, etc - but never saw any signs of movement or wear. Both wires are fused with 40 amp fuses near the battery. I ran a smaller third wire to power the deck from the amp. I ran all the speaker wires in the trays under each door sill except for the sub which runs directly from under the seat to the stealth box.
  10. #9
    Join Date
    Sep 2003
    Location
    Columbus, GA
    Posts
    252
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    MPG, sorry I wasn't clear. I mean- is there already a power distribution location near the battery where the various components of the car (starter, etc.) are attached?
  11. #10
    Junior Member adamkn's Avatar
    Join Date
    Dec 2003
    Location
    Columbus, OH
    Age
    36
    Posts
    76
    Liked
    0 times
    Rep Power
    12
    Default Remote power wire?
    What route do you guys use for the remote power wire? Do I have to remove the factory receiver to get to it, or is there a way I can access it in the engine compartment? I thought I would find a wire in the engine compartment to tap into, and then run the blue wire along side the 4 ga power ware into the cab to the amp. Any comments? Thanks!
  12. #11
    Join Date
    Jul 2002
    Location
    Lafayette, LA
    Age
    46
    Posts
    1,642
    Liked
    0 times
    Rep Power
    15
    Quote Originally Posted by adamkn
    There is an article in the TS garage that shows you what wire to use from behind the OEM radio. I believe it is called "how to add an amplifier to your factory stereo" or something close to that.
    If you run wire straight from the battery to the amp, you would need to put a relay setup or at least a toggle switch between the battery and the amp. Otherwise the amp would always receive voltage and it would stay on and kill the battery.
    You can always tap into a "switched" fuse like say the turn signals at the fuse box. That way when you turn the ignition key on the amp comes on, but there's drawbacks to that too. The best way is to use the TS article wiring setup.
    -Mark
    - Mark
    Just a hangin' out.
  13. #12
    Lurking Member squeipo's Avatar
    Join Date
    Sep 2002
    Location
    Boston, MA
    Posts
    24
    Liked
    0 times
    Rep Power
    13
    Default Amp Location
    Hi all:
    I've got a 2002 Tundra Access Cab.
    Just wondering where you guys mounted your amps. I looking at gettting the Q-logic sub box (dual 8" subs) and I don't see much room for the amp. Any help is appreciated. I'm kinda new to this whole car audio thing, I'm really good with home audio though. Thanks.
  14. #13
    mgp
    mgp is offline
    Join Date
    Sep 2002
    Location
    Watauga, Tx
    Posts
    93
    Liked
    0 times
    Rep Power
    13
    Quote Originally Posted by squeipo
    Hi all:
    Under the front seat and behind the rear seat.
  15. #14
    Join Date
    Sep 2003
    Location
    Columbus, GA
    Posts
    252
    Liked
    0 times
    Rep Power
    12
    Thread Starter
    Can I tap into the rear "accessory plug" (a.k.a. cigarette lighter plug) that is located in the rear cargo area of the Sequoia for the amplifier's remote 'turn on' wire? I think this and the other cigarette lighter plugs are only powered when the the truck is running.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
