Electrical & Computer SystemsDetails discussions regarding electrical components, wiring, all lighting, wire harnesses and HID conversion for your vehicle.
This is a discussion thread titled "Tundra battery (original or new one?)", within the Electrical & Computer Systems forum, part of the Technical & Vehicle Assistance Forums category.
Well, I had my first experience with the T's battery this morning. I have a brand new access cab with less than 1k miles. I went out to start it this morning and....no go. It wouldn't turn over. I had left the door slightly open, so my interior light had been on all night. I didn't think there was any way that little light could drain a brand new battery, but I was wrong. Lesson learned. I'm tempted to stick something in there with a little more juice and reliability. Has anyone else had similair problems? Should I stick with the original battery?
I agree completely. I've got a Optima in my 69 Torino that's been in there since 1997 and it's still strong. I'll certainly replace my original Tundra battery before this winter with a Optima.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
Just recharge the battery and don't leave the door open next time. Probably if you had the new battery you could leave the door open longer though! I wouldn't get the new battery until the old one is shot.
__________________ ADDING POWER HAS NEVER BEEN SO FAST!
Agreed......don't get rid of the "new" battery. Just recharge it. That's happened to me before, too......leaving the door ajar with an inside light on all night.
go with the Optima Battery, made by Interstate Batteries.
I've never known of a dissapointed Optima owner.
Got 1 in everything I own.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
I got a spiral core gel battery too but I got the Exide Orbital instead of the Optima. It was about $50 less and the poles are already reversed so you don't need to hunt for a certain model to fit the Tundra wiring layout.
Optima had an orange top model. same as the red top except the polarities are reversed. not sure if they offer it anymore. My orange top isn't even charging anymore. I think the accident may have done something to it, to the point it doesn't hold any charge.
Don't forget about those two cargo lights in back that were also on if the door was ajar. That would be the two door lights, the dome light and the two cargo lights on all night. Another reason to change out those bulbs for LED's that don't take nearly as much juice. I agree with the previous posts - just charge it up and be sure to set the alarm. If the door is partially open and you try to set the alarm, you'll get a steady beep indicating the door isn't shut.
__________________ Factory:Leather, Tow Pkg., Tundra Floor Mats, RS 3000 Security, Six Disc In-dash CD Changer, TRD Off Road Package, Toyota bed extender, auto-dimming mirror, and running boards Add-ons: INYATI bed liner, Lund hood deflector, Stainless Billet grille, Full tint, Tundra Door sill protectors, Putco s/s bed caps, Delta polished aluminum tool box, Whelen four-way strobe, Bridgestone Dueler A/T Revos 275/70/16's, Throttle Body and Relay/Fuse Billet Covers Performance: True Flow intake and air filter, 20% Underdrive pulley, Jet Hot SS Autochrome Headers, Power Stop Cross-drilled Rotors & Maxxis Pads, Flowmaster cat-back dual exhaust. Audio: Alpine V12 amp, Kicker two-way front speakers, Rockford-Fosgate two-way rear speakers, Boston Rally Neo 3r tweets, Phoenix Gold 500.1 sub amp, Twin Rockford-Fosgate 8's in a Q Logic sub enclosure, sound deadening, XM SKYFi2 Satellite Radio Suspension: Revtek 2.5" suspension lift ,1.5" rear leveling block, Hellwig anti-sway bar w/ ADDCO end links, TRD Red/Blue shocks, TRD Add-a-leafs Mods: Rear seat angle, Dome/ Dash/Fog/DRL and Cargo Light Mods,Under carriage lights, Ignition Key and Open Door Chime Mods, Silverstar head and fog lamps, Power tailgate lock
