Tundra Radio Wiring
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Tundra Radio Wiring
  1. #1
    Join Date
    Sep 2004
    Location
    Egg Harbor City, NJ
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default Tundra Radio Wiring
    Does anyone know what wires coming out of the radio are for the speakers? Before it gets to the amp?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Guest
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    5,988
    Liked
    34 times
    Rep Power
    120718
    Default Re: Tundra Radio Wiring
    Quote Originally Posted by ftjeep
    What kind of vehicle?
    Yera?
    make?
    model?
    Nav?
    Amount of speakers?
    JBL?
    Need to know some of this stuff to get you and accurate description and diagram
    Retired
  4. #3
    Join Date
    May 2009
    Location
    South Florida
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    I'm trying to hook up an aftermarket stereo and need detailed wiring diagram...HELP!!!
    2006 Toyota Tundra Limited Access Cab TRD Sport
    Stock CD/Tape Amp under Backseat 6-speaker set-up
    Anybody Help Please
  5. #4
    Supporter bstaley's Avatar
    Join Date
    Jul 2006
    Location
    Fresno, CA
    Posts
    249
    Liked
    0 times
    Rep Power
    11
    RSS Re: Tundra Radio Wiring
  6. #5
    Join Date
    May 2009
    Location
    South Florida
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thanks, but I'm having a hard time figuring out which wires are which, I mean I got the speaker wires down, but the others don't match up with the aftermarket stereo...Maybe if I had the pin diagram, I dunno...
  7. #6
    Guest
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    5,988
    Liked
    34 times
    Rep Power
    120718
    What color are the aftermarket stereo wires you need help with?
    Then we can tell you which wires they go to on your Truck harness.
    Retired
  8. #7
    Join Date
    May 2009
    Location
    South Florida
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    The wire colors on all the diagrams I've found don't match the colors in my truck???
    I've hooked it up and have figured out the Power, Illum., Acc. and Ground...I actually get motion on the display, but no sound...
    The speaker colors for my aftermarket HU are: Front Lft +Wht -Wht/Blk
    Front Rt +Gray -Gray/Blk
    Rear Lft +Grn -Grn/Blk
    Rear Rt +Violet -Violet/Blk
    I'm so close any advice will help...
    Thanks
  9. #8
    Junior Member Erich_121's Avatar
    Join Date
    Dec 2008
    Location
    Brewer
    Posts
    63
    Liked
    0 times
    Rep Power
    7
    I would like to know this also, on aftermarked systems a low level signal is sent to the amp, but does the factory system have high level signals to the amp? If thats the case you would need to remove the amp and spice the wires.
  10. #9
    Join Date
    May 2009
    Location
    San Marcos, CA.
    Posts
    30
    Liked
    0 times
    Rep Power
    7
    I believe crutchfield, or any other stereo retailer should sell wiring harness adapters. It makes this job incredibly easy and you go cutting your trucks wiring to pieces.
  11. #10
    Join Date
    Nov 2007
    Location
    Fort Mcmurray
    Age
    33
    Posts
    1,131
    Liked
    1 times
    Rep Power
    49
    i know people are cheap nowadays. but what is your time worth?? for the amount of time youve spent chasing wires, it wouldve probably been worth it to just buy the scosche wiring harness. its only $100.
    2007 Tundra LTD CrewMax, Black, De-badged, TRD intake, TRD exhaust, Grillcraft grill, 24" BZO Elite wheels, AVIC-Z2 DVD/NAV, 2x10" BA subs
    2006 Chrysler 300 SRT8, Brilliant Black, Tinted Windows, Full Stereo, 22" Forged MHT Stilleto's, KW V2's, Hotchkis Swaybars, Magnaflow hi-flo cats, Corsa cat-back exhaust, VORTECH SUPERCHARGED
    2005 Yamaha R1, Blue
    2009 Harley Davidson FXCW Rocker, Blue
  12. #11
    Join Date
    Dec 2008
    Location
    Brewer
    Posts
    63
    Liked
    0 times
    Rep Power
    7
    so after doing some research and a subscription to TIS I found the info I needed. First The AC and DC are wired differently, they have different harnesses. The system configuration is pretty advanced for a stereo because of the AVC-LAN communication, but when hooking up a new HU, that wont matter. Basically the factory radio sends a 2 channel low level input to the amp along with 12v constant and switched and a few other things. The amp then of course sends that to the speakers. All the speaker outputs are located at the 12 pin connector that hooks to the amp. When you remove the old radio, at larger 20 pin connector, look for a L-Y-BR wire or pin 1. That is the constant battery. The ACC is GR-BR wire or pin 11. The illumination is the G-BR wire or pin 2. Ground is BR pin 20. So the 4 wires are all you need to power your new HU. Next run 4 pair of wires for each channel to the old amp location. (if you have tweeters in the door they are already wired in parallel with the door speakers.) Then splice the correct wires together. (RL+ is pin 2, RL- pin 7); (RR+ is pin 3, RR- is pin 8); (FL+ is pin 4, FL- is pin 11); (FR+ is pin 5, FR- is pin 12.) If you are looking at the connector the upper right is pin 1, upper left is pin 5, lower right is pin 6, lower left is pin 12. The numbers go in order. so 5,4,3,2,1 then bottom is 12,11,10,9,8,7,6. So instead of spending 100 or more bucks on a harness just splice 4 wires for the HU and 8 for the speakers.
  13. #12
    Join Date
    May 2009
    Location
    chester
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    i hooked up an aftermarket stereo in my 06 AC and it sounds great. i removed the factory amp from under the passenger rear seat and used the factory amp wiring harness but reindexed the wires to be used as speaker wire to connect from the radio to the speakers. my only problem now is i have no A/C bezel lights or instrument panel(gauge cluster) lights. does anyone know of a solution. all help will be greatly appreciated
  14. #13
    Guest
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    5,988
    Liked
    34 times
    Rep Power
    120718
    Quote Originally Posted by r_rutledge85 View Post
    The wiring for the FACTORY RADIO had a GREEN WIRE going to it, so does the A/C control panel.
    This GREEN wire will test as a ground with the headlights off. When you turn the Headlights ON it will switch to a 12v power, this is the signal to the toyota radio and A/C control panel that the lights are on and that the radio should dim and the control panel should light up
    The Toyota wiring also has a WHITE wire with a GREEN Stripe, this wire went from the radio to the A/C integration control panel and is the ground from the Rheostat which is what adjusts the brightness of the radio, and A/C panel.
    You need both of these wires for the ILLUMINATION circuit to work.
    Is the rheostat turned down?
    Retired
  15. #14
    Join Date
    May 2009
    Location
    chester
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    so how would i do it to make it all work again, should i just connect the white wire with the green stripe to the green wire or what?? im not electronically stupid or anything, hell ive prolly installed 20 stereos or better in my lifetime but this one is being really frustrating. Once again i greatly appreciate any and all help and support
  16. #15
    Guest
    Join Date
    Feb 2003
    Location
    Henderson, NV
    Posts
    5,988
    Liked
    34 times
    Rep Power
    120718
    Do not connect the 2 wires. That will cause a short.
    I have never experienced this issue using an aftermarket radio, so someone else is going to have to chime in.
    Retired
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
