Old 10-05-2004, 08:31 PM
Last Online: 12-05-2006 09:27 AM
sidwin is on a distinguished road.
sidwin's Photo Albums
Default radio install problem
Hi Everyone,
I have an 01 limited seq. I bought the metra harness 70-8112 that is supposed to be able to allow u to keep the stock jbl speakers and amp. I pulled everything out and sure enough the harness didn't fit. I then went to the store and bought the standard toyo harness. Once again i could only get the main harness to fit and not the speaker harness. I know if you go that route you have disconnect the stock amp. You disconnect the medium size connector up top and the small connector down under. Am i just using the wrong harness?
Thanks,
Sid
