It doesn't bother me to add a fuse buss in the engine compartment.
However, I am sick of pulling wires through the firewall.
Is there a convenient place to mount an additional fuse buss within the cab of the vehicle? For certain lighting requirements (under-cab, aux-reverse, camper) an additional in-cab fuse buss would be ideal!
If so, is there a way to protect the wire leading to the fuse buss? Another fuse, fusible link etc...
In my limited experience with 12v DC wiring, I've learned to PROTECT YOUSELF! In my first vehicle (way back in high-school
I wired a camper light directly to the battery. I ran the wire along a stock wiring harness. When it shorted out it burnt through entire harness. I spent days diagnosing and fixing the problems.
I would imagine that the 8-guage wire I must run to the in-cab fuse buss would mess up more than a few things if it shorted out, so how do I prevent that?
You know how it goes: you add one electronic component, read a thread on T/S, add another electronic component, then another... When you have fuse busses near by, these mods become simpler.
By the way, anybody know where to find a fuse buss that uses the same mini-blades as the Tundra? The fuse buss I found at PepBoys uses "normal" blade fuses. I really don't wanna cart around two different types of fuses.
