  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 02-02-2005, 12:56 PM
Dealer : Classic Toyota
2003 Toyota Tundra
Last Online: 11-18-2009 10:47 AM
BoneDigger is on a distinguished road.
BoneDigger's Photo Albums
Default Radio installation question.
I have ordered a new Pioneer XM ready head unit for my '03 Tundra so I can do away with FM modulation. I have read the instructions on this site for removing the existing factory radio and I do not believe it will be difficult. My question is about general radio wiring. I realize that the new Pioneer radio will have a wiring harness, but is an adaptor needed to wire it into the truck? I have only done this once (replace a radio) and it was in a 1993 Chevy truck where you have a seperate tuner and receiver. In that instance I had to buy a wiring adaptor and an antenna plug adaptor.
As of right now, what I have ordered is a radio (Pioneer XM ready), an IP/BUS cable for taking XM from my receiver to the new head unit, and a dash kit for a 2003 Tundra. Is there anything else I would need?
Lastly, if you just cut the wires and wire like colors to each other, can you just use wire nuts or do you have to soder (spell?) them?
Todd in TX
Old 02-02-2005, 01:26 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 08:35 PM
nhparrot's Photo Albums
Todd in TX
Assuming you plan to remove the Toyota HU & Amp (if you have a OEM external amp), if you get a harness adapter (such as those from Scosche or Metra) then the adapter will plug right into the Toyota wiring and you connect the wire leads from the adapter to the connections on your new HU. Ususally the harness adapters are standard wire color schemes to match up with the wire color scheme used by the major manufacturers.
~Glenn
Old 02-02-2005, 03:17 PM
2003 Toyota Tundra
Default How do you tell?
How can you tell if you have the amp or not, unless you pull out the radio? Is there a way to determine this? I have an '03 Tundra TRD package with a basic CD/cassette/AM/FM unit.
I spoke to a radio shop and they said that some of these radios have two plugs and some have one plug. Which would I need? This is the Metra plug that was recommended: 70-1761. Their price is right around the $15 mark. I'm sure ordering online would be cheaper, but I'm not positive this is the one I need. He said if there are two plugs, then this one will not work.
Ideas?
Todd
Old 02-02-2005, 03:19 PM
CATiger's Avatar
Dealer : Dublin Toyota Scion
Last Online: 11-04-2009 04:05 PM
CATiger is on a distinguished road.
Send a message via AIM to CATiger CATiger's Photo Albums
Todd in TX
I used inline butt splices for my install. They look like little tubes, and you just crimp them together. You can use splices, wire nuts, or solder. I soldered my power connection, just because the wires were different size and I didn't have a splice that fit both well. Be sure to use some heat shrink tubing or some other form of insulation if you solder...
You won't always be able to just pick like colors, but if you have the manuals you should be fine.
- JD
2000 Toyota Tundra Limited 4x4 w/ TRD Package
Thunder Grey Metallic
Factory Options: Leather Captain's Chairs, Color Keyed Running Boards, tow package Aftermarket Additions: JVC KDSHX900 w/ HD, Sirius S50 Satellite Radio, JL Audio Stealthbox, Eclipse 500W 5-channel Amp, MB Quart Ref Components w/ 1.5" tweeters up front, Coax rears, Peel & Seal sound deadening, Trenz Billet Grill, Tailgate Extender, Sylvania Silverstar headlights, Hella SuperTone Twin Horns, Ivan Stewart Body kit Modifications: Unichip with custom tune, JBA Titanium coated headers, Hellwig Anti-Sway Bar, TRD Dual Side Exit Exhaust, Powertraxx No-Slip, TRD IS Wheels Polished and Powdercoated Gunmetal Grey, shod w/ 285/75R16 Michelin LTX A/T2, Fabtech Performance Coil-overs & Donahoe Racing leaf springs with bilstein 5100, Rear Porterfield Carbon Kevlar Shoes with cryo-treated drums, Power Outlet Mod, Rear Seat Mod, NGK iridium plugs
MySpace
Old 02-02-2005, 03:41 PM
Salty_Dog's Avatar
Assistant Administrator
Dealer : Toyota Of Stafford
2001 Toyota Tundra,
2002 Toyota Corolla
Last Online: Today 07:23 PM
Images: 580
Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything. Salty_Dog has done just about everything.
Send a message via Yahoo to Salty_Dog Salty_Dog's Photo Albums
Todd in TX
Try Crutchfield. They have adapters for everything. I don't care much for their equipment prices, but you can often find wire harness and mounting kits that you can't find anywhere else. And it's spelled "solder"
Salty Dog
You've been..... TUNDRASTRUCK!
Ride: 2001 Tundra SR5, 4WD, The Lean Mean Green Machine, Lift, Front: Bilstein 5100 Adjustable Shocks w/ Total Chaos Diff Drop, Lift, Rear: 1" Wheeler's Blocks, Wheels: Chromed Factory 4Runner Rims, 17", Tires: Bridgestone Revos, 285/70R-17, Performance: Unichip, Borla Exhaust, Optima Yellow-top Battery, Flux Capacitor, Interior: Dog Hair on Back Seat, Coffee Stains on Console, Bling: Ivan Stewart TRD Grille, Westin Nerf Bars, Clear Corners & Eurotails, Debadged, Audio: Kenwood DDX512 Head Unit, Kenwood KCA-XM100V Satellite Radio Interface, Polk Audio db6501 component speakers (Front), Polk Audio db651s speakers (Rear), Profile AP740 4-channel amplifier, Rockford Fosgate 8” Punch subwoofer (x 2) in Q-Logic enclosure, Profile AP700M mono subwoofer amplifier, Audiovox ACA200W Rear-view camera, Shark Fin Antenna, Other: Viair 450C compressor, 2.5 Gallon air tank, Kleinn Pro Series 4-Trumpet air horns, Eye Candy: Hottie Wife in Passenger Seat, Security System: One Very Ornery Dog
Old 02-02-2005, 04:53 PM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
Ideas?
Todd
With or without an amp the factory harness will have 2 plugs that look like the attachment. Your harness adapter should match up. If you do not have an external amp, the factory harness plugs into the Radio/Player, if you do have a factory amp then the factory harness plugs into the amp and a 20 pin pigtail runs from the amp to the Radio/Player. The Radio/Player may also have a 20 pin plug for steering wheel controls.
~Glenn
Old 02-02-2005, 05:07 PM
2003 Toyota Tundra
Default Excellent
That answers my question perfectly. Thanks for the help!
Todd
LinkBack to this Thread: http://www.tundrasolutions.com/forums/audio-and-stereo/35762-radio-installation-question/
Posted By For Type Date
Vans Shoes, Vans Aircraft, Vans Warped Tour - Defouwbmw This thread Refback 03-08-2009 01:21 PM
CAR CREW: Question: How hard is it to install a new deck? - Page 2 - NoNewbs This thread Refback 06-23-2008 10:33 PM
