Old 02-27-2005, 12:38 PM
Dealer : Toyota Of Fort Worth
2005 Toyota Tundra
Last Online: 05-14-2008 08:18 PM
faaengr may have some regrets.
faaengr's Photo Albums
Default Amplifier behind 2005 Tundra Double Cab Rear Seat
Has anyone found a amplifier that fits behind the seat of the 2005 Double Cab. I've removed the large pocket and took a few measurements. It looks like I have two seperate areas to mount amplifiers. One measures 14.5" x 8.5" x 1.5" and the otehr 11" x 8.5" x 1.5". With the openings parts of the amp could be larger. I would like to be able to put the cover back on.
Old 03-10-2005, 08:08 PM
2005 Toyota Tundra
Last Online: 10-16-2007 11:10 AM
Litlbul may have some regrets.
Litlbul's Photo Albums
I found a amp that fits. Check out my pictures
2005 Tundra Double Cab Limited
Old 03-10-2005, 08:46 PM
Dealer : Toyota Of Batavia
2005 Toyota Tundra
Last Online: 01-07-2007 06:20 PM
mikeshine may have some regrets.
mikeshine's Photo Albums
memphis m-class amp's will fit under the driver's rear seat storage compartment
Old 03-10-2005, 11:22 PM
christophertowle's Avatar
Dealer : Joe Myers Toyota
2004 Toyota Tundra
Last Online: 03-08-2009 07:27 AM
christophertowle may have some regrets.
Send a message via ICQ to christophertowle Send a message via AIM to christophertowle christophertowle's Photo Albums
Litlbul,
Do you have any pics of how the amp is mounted?
It looks like you had to cut the panel, is that correct?
Just curious, I was able to fit passive crossovers there.
Cheers,
Chris
Old 03-11-2005, 04:22 AM
2005 Toyota Tundra
Originally Posted by christophertowle
Litlbul,
Cheers,
Chris
That is correct, I cut the storage pocket and mounted the amp right where the stock amp was.
Old 03-11-2005, 07:23 AM
2004 Toyota Tundra
Thanks for the response.
How did you mount it the amp though? Did you build a bracket to use the factory mounting points and mount the amp vertically? or is the amp attached to the back wall?
Any pics to share with the community?
Old 03-11-2005, 04:49 PM
2005 Toyota Tundra
The amp is attached to the back wall. I just used short self tapping metal screws.
Old 03-12-2005, 09:46 PM
Dealer : Piercey Toyota Scion
2005 Toyota Tundra
Last Online: 01-22-2008 08:33 PM
pierceman may have some regrets.
pierceman's Photo Albums
I fit a 1000w ppi amp there by removing the big plastic cover. It is all hidden anyway.
MAtt
2002 Acura NSX, supercharged +++
2006 BMW 530i awd-wagon, all black 20"s, wifey's
05 Tundra D-cab sr5, saws etc. SOLD
03 Sequoia Ltd, navi/dvd/back up camera, TOTALED
1991 S13 drifter, built to be beaten
09 Sequoia ltd, 4x4 navi dvd on order....
