Old 04-22-2005, 02:47 PM
Dealer : Karl Malone Toyota
Last Online: 03-26-2008 08:07 PM
hiro24601 is on a distinguished road.
hiro24601's Photo Albums
Default Low volume in Tundra rear speakers...
I have a 2000 Access cab Tundra. I installed a Nav unit from oemvalue.com and just realized that the volume in my rear speakers is awfully low. Furthermore when I adjust the sound to the rear of the truck the volume of the speakers does not change.
I never messed with the sound when the stock head unit was installed so I don't know if I can attribute the problem to the new JBL amp and Nav unit.
Has anybody else experienced this problem with or without Nav unit? If so how can I get more volume out of my access door speakers?
My nav unit was made for a 2005 Camry. Does the Camry have more than 6 speakers? If so maybe the harness at the head unit is sending the wrong chanel to my rear speakers...?
Old 04-22-2005, 03:02 PM
Agent WD-40's Avatar
Dealer : Fox Toyota of Rochester
Last Online: 11-18-2009 01:44 PM
Images: 12
Agent WD-40 is on a distinguished road.
Agent WD-40's Photo Albums
Do you have the factory speakers? If so the rear speakers are designed to be quieter than the fronts. I personally think it sounds better that way. I have my aftermarket system set up the same way.
The fronts are 4 ohm speaker, the rears are 6 ohm. The fronts will thus sound louder than the rear because the fronts will get more power. The fronts will probably sound close to 2x as loud as the rear.
Old 04-22-2005, 08:12 PM
I do have factory speakers. I appreciate the suggestion. I'll install more powerfull speakers this weekend. I'll let you know what happens...
Old 04-23-2005, 12:33 PM
Didn't work. I replaced the 6 ohm 60 watt speakers with 4 ohm 160 watt speakers. No difference whatsoever. Once again, when I try to fade the music to the access cab speakers there is no change in volume.
This can't be normal...
Old 04-23-2005, 04:16 PM
Images: 12
I'm not sure what the problem is. Probably the wrong wire going to the rear. If you got a wiring diagram (or perhaps ask nhparrot) you can find out of there are wires designed to go to more speakers.
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Tundra: PLEASE explain adjusting rear brakes. lendaddy Brakes 12 09-18-2006 11:26 AM
Can I Do This? (wire speaker channel amp) Brandon1 Audio & Stereo 14 03-09-2004 12:24 AM
Wiring for a speaker level input GuardianED Audio & Stereo 11 12-10-2003 06:26 PM
Question about stock Tundra Foglights..Help! nhparrot Electrical & Computer Systems 0 03-28-2002 01:13 PM
