Sealed or Ported Storage Enclosure?
+ Reply to Thread
Results 1 to 10 of 10
Thread: Sealed or Ported Storage Enclosure?
  1. #1
    Veteran Member S-Man is on a distinguished road. S-Man's Avatar
    Join Date
    Sep 2002
    Location
    Houston, Texas
    Age
    32
    Posts
    767
    Liked
    1 times
    Rep Power
    11
    Default Sealed or Ported Storage Enclosure?
    I'm going to make a sub enclosure for my A-Cab Storage Compartment.
    Should i make it sealed or ported?
    I'm planning on having a 10" sub.
    As far as sound, whats the difference in having a sealed enclosure, verses a ported one?
    I did a search and could not find an article on this particular topic of "sealed vs. ported"
    thanks in advance for any help.
    P.S. JnEsPappa, this has your name all over it
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member supritdeol is on a distinguished road. supritdeol's Avatar
    Join Date
    Mar 2005
    Location
    my car
    Posts
    356
    Liked
    0 times
    Rep Power
    9
    go with sealed, there is not enough room (volume) in the storage compartment to run a ported subwoofer. I would recomend completely sealing the compartment with fiberglass for better sound quality.
  4. #3
    Join Date
    Sep 2002
    Location
    Houston, Texas
    Age
    32
    Posts
    767
    Liked
    1 times
    Rep Power
    11
    Thread Starter
    I don't understand how a Ported enclosure would'nt have enough "room". The reason for the port is so that the air can escape right? I can see the sealed enclosure not having enough room. But what would it sound like, a sealed storage compartment vs. a ported one?
    Also, i do intend to use fleece, and fiberglass for added strenth, and an mdf baffle/mounting plate.
    thanks for the suggestions superitdeol.
    can somone explain the aforementioned question? thanks.
  5. #4
    Junior Member craigferriter is on a distinguished road.
    Join Date
    Apr 2003
    Location
    Atlanta
    Posts
    76
    Liked
    0 times
    Rep Power
    11
    Quote Originally Posted by S-Man
    Ported typically equals lower bass, better for rap, etc. Ported boxes must be bigger by around 50% than sealed. A sub in a ported box will require less power to drive, but can be blown easier. A sealed enclosure requires more power, is more diff to blow and doesn't dip quite as low. However, is very good for rock and some rap.
  6. #5
    Junior Member MadMax1019 is on a distinguished road. MadMax1019's Avatar
    Join Date
    Jun 2004
    Location
    Ann Arbor, MI
    Age
    26
    Posts
    105
    Liked
    0 times
    Rep Power
    9
    I also don't think you will have enough room in your ac cab storage compartment for a proper ported enclosure. In my experience, a ported sub will sound louder b/c it tends to move more air, also it will sound punchier. But hell if you are good with fiberglass I'd say try a ported enclosure. I'm sure everyone in the audio section would love to see it.
    - Max
    2004 Tundra Double Cab SR5
    Mods: Extang Platnum Tonneau Cover, Cobra 11 Band Radar Detector, Three 6.5" TangBand Subwoofers powered by a JBL 150.1 amp.
    Go Blue!
  7. #6
    Veteran Member longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon has done just about everything...and then some. longwoodklon's Avatar
    Join Date
    Feb 2002
    Location
    Murrieta, CA
    Age
    40
    Posts
    1,756
    Liked
    15 times
    Images
    9
    Rep Power
    868
    Quote Originally Posted by craigferriter
    Exactly. Ported is a great way to go if you have room. You need more room with ported because the port length determines the fundamental frequency. The longer the port, the lower it will play. There is a free progam used for designing enclosures, especially ported ones. It's called WinISD, search around and you should find it. And it's wise to run a subsonic filter with ported, because once you try playing a note that is lower than what you ported for, you are essentially running at free air and you will likely blow your sub. Sealed is your only realistic option for the storage compartment. /Mike
    2001 2WD Silver Tundra: 4x4 TRD springs, Camburg Uniballs with adjustable Bilsteins, Carson AAL, red/blue Bilsteins in rear, 265/75 Yokohama A/T, IS kit(minus bumper) and rims(hand polished), Billet Wing Window Latch Upgrade, TC Steering Bushings, RF851X amp, Alpine HU, JL 6.5"XR comps, Qlogic with JL 8W3V2 subs. Stebel 300Hz Air Horn.
    202k miles and counting......
    2011 Honda Pilot EX-L, black with gray interior.
  8. #7
    Supporter rytherwr is on a distinguished road.
    Join Date
    Feb 2003
    Location
    leesburg, GA
    Posts
    121
    Liked
    0 times
    Rep Power
    11
    Quote Originally Posted by longwoodklon
    Lottsa good answers to the question, and for the size of the storage compartment, you should go with a sealed enclosure with some fiber in it. Low frequencies are all about moving air, so get a sub with the longest throw you can find. Now to the meat of the question.....Good speaker enclosures must be designed to fit the electrical and mechanical properties of the speaker you are going to use. All good woofer manufacturers will also provide optimum alignments for their woofers, so all you really have to do is determine if you have the room to make the enclosure. When you are measuring for the size, you must take into consideration the basket and magnet and add it to your optimum enclosure size because it takes up room inside the box. Sealed enclosure alignments are much more forgiving of box size than ported boxes. In order to design a use-able ported box, you MUST either get the recommendations from the woofer manufacturer, know the speaker properties or be able to measure the speaker properties. Most of us hackers don't have the equipment to measure that stuff, so taking the advice of OEM's is very useful. My experience has been that there isn't enough room in the storage compartment to make a workable vented box. Hope this helps......)
    regards
    Wayne
  9. #8
    Join Date
    Sep 2002
    Location
    Houston, Texas
    Age
    32
    Posts
    767
    Liked
    1 times
    Rep Power
    11
    Thread Starter
    Thanks alot guys. All these responses help me out ALOT.
    Guess i'll be going sealed. I have a good idea how to build one from some pics somone posted on the classifieds here about a custom box they were trying to sell.[IMG]Box[/IMG]
    Its made from MDF with fiber, and its removable so i don't have to stink up my cab with resin fumes.
    Any recommendations on wattage handling, RMS, and so forth?
    I don't want to blow peoples clothes off, wait, that might be kinda cool...
    no, i just need to have a nice clean addition to round out my mids and highs.
    Thanks.
    (I can't figure out how to post a pic on the msg, so i'll just upload them.)
  10. #9
    Lurking Member wernerlab is on a distinguished road.
    Join Date
    Sep 2004
    Location
    Ringgold, GA
    Posts
    30
    Liked
    0 times
    Rep Power
    9
    I think these guys pretty much nailed the answer. If you did port it it's likely the port would be noisy or it would be tuned so high (50-75hz) that it would be boomy and kill the low end bass. (or both)
    Sealed has less group delay so it sounds more accurate. Not a rap 808 kick drum mind you but bass guitar, real drums, etc. will sound realistic. Not that same old tone (boom boom).
    Thanks.
  11. #10
    Drunk Redneck rx7vert will become famous soon enough. rx7vert will become famous soon enough. rx7vert will become famous soon enough. rx7vert will become famous soon enough. rx7vert will become famous soon enough. rx7vert will become famous soon enough. rx7vert's Avatar
    Join Date
    Nov 2004
    Location
    South Mississippi
    Age
    26
    Posts
    1,708
    Liked
    0 times
    Images
    6
    Rep Power
    12
    Ports also have to be tuned depending on volume of the box, x-max of the sub, and volume that the sub displaces. Ported boxes are VERY difficult to get right.
    the port is not just to let air in and out, a port actually adds to the sound output. A 40hz tuned port puts out a constant 40hz sound wave that adds power to the sound from the sub itself. You cannot sepparate the two sounds when listening, you just sense that it is a slight bit less accurate sounding than a comperable sealed box.
    The only way to get great sound quality out of a ported box is to tune LOW like 32hz. In order to do that well you need a very large box.
    A good ported box for a 10 would be AT LEAST 2 cubic feet. There are some programs that can give you the exact port demensions for your box, but they are pricey.
  1. Rear Center Enclosure Started - 2005 Tundra Double-Cab
    By tamu1996 in forum Audio & Stereo
    Last Post: 08-04-2005, 05:45 PM
  2. why is a ported box better then a sealed?
    By uracowman in forum Audio & Stereo
    Last Post: 11-02-2003, 01:33 AM
  3. Ported sub in the storage compartment
    By davecsu in forum Audio & Stereo
    Last Post: 04-11-2003, 11:00 AM
  4. Rear Storage Compartments for subwoofers, amps, etc.
    By nhparrot in forum Audio & Stereo
    Last Post: 03-28-2002, 11:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
