Old 11-10-2005, 10:01 AM
2002 Toyota Sequoia
Last Online: 04-30-2007 11:00 PM
tneg is on a distinguished road.
tneg's Photo Albums
Default Front Speaker JBL
I need to replace the front woofer speaker of a JBL 10 speaker system in my sequoia. I called the dealer and they wanted $200 for one speaker (part # 86160-AF060). This speaker consists of a 7" woofer 2.2ohms 28 watts, a 2.2" mid at 3-4ohms 10watts, and the tweeter. I would like to get a speaker that maintains the impedance match, since I only have to replace the woofer I was thinking I could get a speaker that is about 2 ohms like the Infinty 62.7i. Since thsi is a two way speaker it has connections fro the woofer and the tweeter. the speaker is rated for 2 ohms but I am not sure if that is just the woofer or a combination of tweet/woofer. Is there a way to just change the speaker with an of the shelf item and not sacrificing the way the HU drives these?
Another alternative I was considering was just refurbushing the foam around tghe original speaker for $30 , this avoids my connections , bracket modification and matching impedance problems but its not a sure fix.
Help is appreciated
tneg
Old 11-11-2005, 09:33 AM
JnEsPappa's Avatar
Dealer : Hampton Toyota
Last Online: 06-12-2008 05:49 PM
JnEsPappa is on a distinguished road.
Send a message via AIM to JnEsPappa JnEsPappa's Photo Albums
Did I gather correctly that the surround is torn on one of the drivers? If so, I would back your suggestion to fix the surround and leave all else alone.
Partsexpress.com has some repair kits.
- Mark
Just a hangin' out.
Old 11-11-2005, 11:08 AM
2002 Toyota Sequoia
tneg's Photo Albums
Hello Mark , Thanks for giving me your opinion. The foam sorrounding the cone of the speaker was brittle, hence at low frequncies the speaker would make vibrating noises. Since I am keeping the same HU I am limited in speaker selections, I was hoping to upgrade the speakers to ones having better material but there is no inexepensive solution to this. i have found a local palce where they refoam ( and recone if needed, $60) these speakers for $30/ each. I most likely will do this unless I hear a better solution.
Thanks
Tneg
Old 11-12-2005, 02:24 AM
2005 Toyota Tundra
Last Online: 10-03-2006 08:18 PM
helica is on a distinguished road.
helica's Photo Albums
If you're gonna replace a speaker, if it's not an EXACT match, you should replace the pair.
Vehicle: 2005 Toyota Tundra Double Cab 4x4 vvt-i 4.7L V8 in Timberland Mica
Current Mods: Donahoe Racing Adjustable 2.5" Coilovers, Hellwig Rear Sway Bar, Bilstein 5100 Shocks, TRD Add-A-Leafs, Magnaflow 18" oval custom cat-back exhaust, Genuine-Toyota Tundra rubber floor mats, Delphi Roady2 XM Radio, USA Spec dual-aux input adaptor, custom-built dash-mount auxilary input for iPod, JL Audio 10W1v2-4 subwoofer, JL Audio e1200 monoblock, BedRug, Challanger step bars (Genuine-Toyota accessory), AVS Bugflector II
Future Mods: Westin Chrome Nurf Bars, Wheels, Tires, Double-Din Navigation, Leather seat-skins
Need a Left front speaker output color wire. Brandon1 Audio & Stereo 2 08-22-2005 12:51 PM
front hitch/towing chrislloyd Towing 7 05-29-2004 08:07 AM
Front Speaker suggestion please Froggy Audio & Stereo 4 10-12-2003 04:02 AM
Front door Speaker Mod TundraTenn Audio & Stereo 1 09-19-2003 12:50 PM
Front door Speaker Mod TundraTenn Audio & Stereo 0 09-19-2003 09:14 AM
