LinkBack (15) Thread Tools Display Modes
  #76 (permalink)
Old 10-30-2006, 09:37 AM
marathonpaul's Avatar
Dealer : De Luca Toyota Scion
Last Online: 07-04-2009 10:36 PM
marathonpaul is on a distinguished road.
marathonpaul's Photo Albums
Default Re: E7007/8 Sienna NAV into 2006 Tundra
Originally Posted by dibble9012 View Post
for those of you with the mic mounted on the steering column or on the top of the combination meter, how is the reception for cell phone conversations? Can the other person hear you ok? I am going out to my truck now to install an automatic lock module, and I will try to install the mic at the same time, just want to see how the reception is before I start drilling, lol
No need to drill, use velcro! As for the sound, the Tundra is sooo quiet, that mounting the mic is not an issue. Mine works fine on top of the steering column.
$.02
Paul
  #77 (permalink)
Old 10-30-2006, 10:58 AM
Dealer : Miller Toyota
2005 Toyota Tundra DC Phantom Gray
Last Online: 11-19-2009 10:28 PM
Images: 11
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
$.02
Paul
Ended mounting it on the combination meter surround above the ignition. If I installed it on the steering column, I would have drilled a hole for the wire
EDIT: Finally got the connector and pins today, installed. I cannot believe how clear the mic reception is on a phone call!! It doesn't recognize many commands though that well. The connector came from the dealer (only two day wait time!!!, yes day not week!!!) and the pins came from mouser.com, the link is earlier in this thread.
heres a picture where I mounted the mic (above ignition)
works great, I love the hands free cell phone feature, very clear, the other person on the phone can hear me fine. Voice recognition works ok, but its just easier to reach and press the buttons on the screen. The recognition works well on the phone dialing though.
  #78 (permalink)
Old 11-10-2006, 11:30 PM
Images: 11
Well I finished my temporary backup camera today, works great, but cant wait till the custom tailgate handle camera comes out I will immediately replace this with the custom Tundra camera. I made a custom harness for my OEM nav. I bought some "rca female" solder type jacks that are made to go on the end of a cable. I attached that to the wires coming out of the R10 connector on the back of the headunit. This way I can always upgrade my camera and it will always be plug and play. I ran the cable under the drivers seat through the grommet and zip-tied the cable to the OEM loom running to the back of the truck, big job but it looks really neat Then I just roto-zipped the toyota tow hitch blank so the camera would fit. I wired the camera to ignition hot instead of reverse hot because it was easier, and the headunit senses reverse from a separate reverse wire, not from the camera input
Anyways, it's a really a nice piece of mind with all the kids around our neighborhood, doesn't replace rear view mirrors though,lol
These first 3 pics are with the flower post closest to the truck.
These pics are with the flower pot farther away.
  #79 (permalink)
Old 11-12-2006, 06:24 PM
Dealer : Ourisman Fairfax Toyota
2006 Toyota Tundra DC Limited
Last Online: 12-16-2007 12:16 PM
adzoesch is on a distinguished road.
adzoesch's Photo Albums
Does anybody know if the E7007/8/9 will allow continued functionality of the rear audio (not DVD) in my 2006 DC Tundra? Would like to have the NAV and retain that functionality.
  #80 (permalink)
Old 11-13-2006, 08:18 AM
I assume you are asking about the rear speakers/amp. What's in your truck from the factory? If you have a Nav system, the newer 7/8/9 will still drive the rear.
$.02
Paul
  #81 (permalink)
Old 11-13-2006, 07:04 PM
Thanks - I have the JBL 3-in-1 AM/FM/Cassette/6-Disc CD Changer w/8 Speakers (non NAV)
Actually, I'm speaking of the rear seat audio controls - gives the rear passangers the ability to listen to any of the sources (CD, Radio, etc) via headphones regardless of what the head unit is set to - has display on roof with remote to change source with a couple jacks on center console including volume control. Just want to know if E7007/8/9 NAV will allow continued use of those functions.
Thanks Again!
  #82 (permalink)
Old 11-16-2006, 02:34 PM
Images: 11
Here are some pictures of the install, the sirius radio module is below the passengers seat. I am not really impressed with the reception of the glass antenna, but it has been really overcast so that might have something to do with it. I had to drill a small hole on each end of the plastic casing so I could pass the wire for the auto-dim mirror through it.
  #83 (permalink)
Old 11-17-2006, 11:37 PM
Images: 11
wooohooo!! I am finished with my OEM nav completely (except for one connector that is not really needed, and the VSE sub)
Installed the aux input from a Toyota Sienna today. Part number 86190-AE010 ($28)
Here is what the Sienna part looks like, you have to take it completely apart. I then removed the grey connector on it so I had bare pins to solder wires to. (this picture is from siennaclub.org)
Then I ordered the pins from mouser.com for the end that hooks up to the headunit (I am missing the connector for the pins,so I just put heat shrink on them and inserted them into the corresponding pins)
The most difficult part was putting the aux port in the dash knockout, I am a perfectionist so it had to look good I ended up taking a small drill bit from behind through the small circle thing, lol. Then I took a bigger bit and drilled from the front, this took out that circular post on the back.
The circuit board was too large to fit in properly so I CAREFULLY used a roto-zip with the sanding bit to make it narrower. I then had to slowly enlarge the hole to match the port, it's an odd size so I didn't have a drill bit that matched. Then I used epoxy to glue the circuit board in place, let that dry, then filled everything in with hot glue. Then it was just a matter of plugging it in
Here are the wiring diagrams/parts I used: (Thanks seany @ siennaclub.org for posting the first diagram for me!!) Comparing the 1st and 2nd pictures below: From AUX pin 2 connects to 2 on nav, pin 1 connects to 3, pin 3 connects to 5, pin 4 connects to 6. It's hard to explain but the pins on the AUX unit are numbered weird, if needed I can go back and get exactly how they are connected and post.
  #84 (permalink)
Old 11-28-2006, 05:30 PM
chrisc16's Avatar
Dealer : Toyota of Orange
2006 Toyota Tundra,
2005 Toyota Highlander
Last Online: 09-29-2009 06:32 PM
chrisc16 is on a distinguished road.
chrisc16's Photo Albums
Where did you get the Sirius radio kit from? How much was it? And after a few more weeks of use, how has the reception been on the glass antenna?
Thanks,
Chris
2006 Tundra 4x4 Double Cab
ORS manual hub conversion, TC UCAs, Donahoe coilovers, Firestone RideRite airbags, '07 Solara Nav, SAAV backup camera, Flip-Pac camper
  #85 (permalink)
Old 11-28-2006, 05:36 PM
Images: 11
Thanks,
Chris
I bought the Sirius radio kit off of a member on siennaclub.org. not sure of the part numbers. I got it for $100. The reception is ok with the glass mounted antenna. It cuts off if you go under trees a lot. I might replace it later, but for now it is good because I don't have to have a visible antenna on the exterior.
  #86 (permalink)
Old 12-12-2006, 09:54 PM
Images: 11
I could not edit the pictures in some of the posts before (I guess the edit option expires or something)
anyways, here are all of them again, re-organized, lol, in my photobucket account.
LINK
  #87 (permalink)
Old 03-21-2007, 07:39 PM
Images: 11
Lately I have been getting a lot of PM's concerning my navigation install Figured I would add a post at the end of this thread with all the part numbers/parts I used for the entire install.
1: Navigation Unit: Toyota E7009 (DOES NOT WORK WITH REAR ENTERTAINMENT SYSTEM)
2: Steering wheel phone controls
Only come in pairs, for the most part if you don't have controls on the left from the factory, you cannot add them on later, too expensive and time consuming
Part Number: 84250-08030-B0 (B = Grey, replace B with E for Tan. The grey switches are a match to the taupe door panels of my truck, does not match steering wheel, both have green illumination
3: Microphone Kit: If ya want the other people on the phone to hear you
Ordered from LINK
4: Backup camera, ordered from ebay
5: Sirius radio, bought off ebay, not sure of part number (navigation is compatible with either xm or sirius, will work with "Toyota Solara/Camry" fit kits
6: GPS Antenna: Part Number 86860-47050, also a Lexus part
7: R10 Connector: Used for connecting microphone and backup camera.
Part Number: 90980-12404
8: Pins for R10 connector: LINK Stock #: 571-104480-7
9: Aux input from sienna, just adds audio, no ipod control
Part Number: 86190-AE010
There is some custom work to be done for this part, not a plug and play type thing, the wiring diagram is earlier in this thread
Another VERY GOOD threads about the E7008/E7009 with LOTS of info
  #88 (permalink)
Old 04-04-2007, 03:32 PM
Dealer : Elmore Toyota Scion
2006 Toyota Sequoia
Last Online: 06-02-2009 10:21 AM
Maxworld is on a distinguished road.
Maxworld's Photo Albums
Hi ,
Do you have any installation diagram for the R10 connection for the camera and mic? I am curious to get my installed, i purchased the E7007 and Eclipse BEC106 and also the same mice from Japan base on your link. If you can email or post this diagram on how you did it I greatly appreciated. Do you know if I didn't purchase the steering wheel kit and not planning to get that, will the mic still work?
Vince
  #89 (permalink)
Old 04-04-2007, 06:31 PM
Images: 11
Yup, heres the info. Originally came from siennaclub.org
Yes the mic would still work. To pick up a call you would click on a green phone icon on the bottom right of the screen. To make a call you would press info - phone, (I believe, double check in a couple minutes.)
  #90 (permalink)
Old 05-22-2007, 10:29 PM
Images: 11
I decided to do a more complete write-up since I have had a few PM's about the aux input for the E7009. The file is linked below, let me know what you think (it's a lot of typing so there may be minor typo's and grammar errors ) Tried to think of everything involved.
LINK
LinkBack to this Thread: http://www.tundrasolutions.com/forums/audio-and-stereo/57507-e7007-8-sienna-nav-into-2006-a/
Posted By For Type Date
99-02 4runner fog light pre-wiring - YotaTech Forums This thread Refback 05-10-2009 10:10 PM
Propane vs gasoline? - YotaTech Forums This thread Refback 05-01-2009 02:37 PM
Toyota Corolla Air Bag System, Toyota Corolla Acessories Fog Light Covers, Toyota Corolla All Wheel Drive - Championenergy This thread Refback 03-08-2009 11:16 AM
Toyota Sienna Repair Manual, Toyota Sienna Power Window Repair, Toyota Sienna Review - Cartrader This thread Refback 03-08-2009 09:17 AM
Orange + Red?? Yuck!! (How to change gauge colors) - Page 26 - Toyota Forums :: Toyota Nation This thread Refback 02-04-2009 07:50 PM
2005 Toyota Tundra HID Retrofit Progress - Toyota Forums :: Toyota Nation This thread Refback 11-20-2008 10:03 AM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 04-19-2008 12:38 PM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 10-20-2007 08:45 PM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 10-16-2007 11:44 AM
SiennaClub.org Forums > Service manual for E7007 unit This thread Refback 09-23-2007 12:46 AM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 09-05-2007 01:39 PM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 09-02-2007 08:39 AM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 08-13-2007 05:25 PM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 08-13-2007 08:23 AM
E7007 - SearchMapr (beta) - Visual Web Searching This thread Refback 07-12-2007 07:56 PM
