LinkBack (15) Thread Tools Display Modes
  4 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 02-11-2006, 08:33 PM
marathonpaul's Avatar
Dealer : De Luca Toyota Scion
Last Online: 07-04-2009 10:36 PM
marathonpaul is on a distinguished road.
marathonpaul's Photo Albums
Default E7007/8 Sienna NAV into 2006 Tundra
I'm going to start another thread about this E7007/8.
I have a 2006 DC with JBL and the E7006. I just bought an E7007 (the new Sienna Nav unit with 4 disc internal changer, Blue tooth)
It has the same rear camera and Voice capability.
The things I will need are the new connector for the camera and mic (which are now combined, and is the connector in the lower LH side of the picture) 90980–12404.
Also, since I have a volume control on my steering wheel (LH), I'm going to add the RH switch from a Sienna. I don't have a p/n yet.
Here is the front and back of the new E7007.
E7007/8 Sienna NAV into 2006 Tundra-jan-0041.jpg   E7007/8 Sienna NAV into 2006 Tundra-jan-0031.jpg
Old 02-19-2006, 11:54 PM
Default Re: E7007/8 Sienna NAV into 2006 Tundra
Saturday was a reasonably successfull day. I made a connector and used it to do the install.
I've attached a picture..(but it is not pretty). Everything was plug and play except for the connector which allows the rear view camera and the microphone (and the external aux input)
The camera was a success but not the microphone.
I have a BC-105 and here is the color codes:
From the camera harness Radio schematic color and pin number
Red Red pin 24
Black White pin 21
Yellow Black pin 22
White Shield pin 23
I tried all six combinations of the microphone, but none seemed to work. I don't have the steering wheel switch so I couldn't activate the Nav units voice.
I did get the Bluetooth to pair with my Verizon Motorola V710 phone, but until I can figure out the mic and get a switch, that aspect will be on hold.
The Sirius (toyota solara kit) radio worked fine as does the 4 disc internal changer.
I didn't get a chance to hook up or try the aux input.
Paul
E7007/8 Sienna NAV into 2006 Tundra-jan-0481.jpg
Old 04-18-2006, 01:01 AM
Dealer : Power Toyota Irvine
2004 Toyota Sequoia
Last Online: 12-02-2008 11:06 AM
mycotopian is on a distinguished road.
mycotopian's Photo Albums
I'm very interested in more updates, pics, diagrams etc if they are available
Old 04-18-2006, 08:06 AM
Nothing at this point. I still need to get the steering wheel switch set (which is not yet available).
Paul
Old 05-26-2006, 05:20 PM
Dealer : Phillips Toyota Scion
2005 Toyota Tundra
Last Online: 05-31-2006 03:06 PM
chops0000 is on a distinguished road.
chops0000's Photo Albums
Paul I have the E2006 and I am trying to figure out how to add a back-up cam. Is one of the plugs on the rear of the unit designated for this purpose, and if so, can you tell me which one?
Or..do I need some sort of wire harness or converter to add a cam?
Any help is appreciated. Thx.
Old 05-27-2006, 06:47 AM
If it is a E7006, then there is a 4 prong plug on the back of the radio. The camera plugs directly into it. No converter needed.
Paul
Old 08-05-2006, 07:38 PM
2004 Toyota Sequoia
Whats the latest and greatest on this?
Old 08-06-2006, 08:52 AM
Default Re: E7007/9 Sienna NAV into 2006 Tundra
The Sienna forum has been a wealth of information!
A steering wheel switch is 84250-08030-B0 (B0 for the gray <taupe> switch), which I've just ordered. (includes both sides)
Parts for the Aux port are 84480-AE0303 and 86190-AE010. I've ordered them also.
My final bit of news is that I used the original electrical diagram and ran a wire between pin 12 and 15, but an update diagram showed the jump er between 12 and 18. I need to try this when I pull the radio. This may help my microphone issues.
More to come.....
Paul
Old 08-06-2006, 11:55 AM
Dealer : Ardmore Tcsc-Central City
2005 Toyota 4Runner
Last Online: 07-31-2007 12:22 PM
054runner is on a distinguished road.
054runner's Photo Albums
what did you use to make the pins? I have a different unit but I broke the plug for my bu cam. i was thinking of just making new pinout but dont know what to use. i want to try pc jumpers but they may be too big to fit.
Old 08-07-2006, 09:17 AM
Two ways I can think of...First look at old wiring harnesses/connectors. When I made my "Y" cable, I had an extra connector and use the pins from it.
Also I've heard that the Jumpers for PC hard drives will work (along with an IDE cable end)
Let us know what works for you.....
Paul
Old 08-07-2006, 09:02 PM
2005 Toyota 4Runner
Smile Re: E7007/8 Sienna NAV into 2006 Tundra
just in case any one is interested i bought a 9pin female din connector, the type for monitors and serial cables, and they worked perfectly. nice snug fit on the pin and a little elec. tape to prevent crosstalk.
Old 08-08-2006, 01:03 PM
Do you have a picture?
Thanks,
Old 08-08-2006, 03:14 PM
2005 Toyota 4Runner
of what i used or what i did?
RadioShack.com - Cables, Parts & Connectors: Connectors & connectivity: D-Sub connectors: 9-Position Female Crimp D-Sub Connector
that is what i used. in the package are little female connectors. used those to replace the adapter all together. just crimped those females to the 4 wires and attached them to the male pins behind the unit. to get pictues of the final would mean id have to take the dash apart again which is not much fun.
Old 08-09-2006, 10:48 AM
Great idea, I had forgotten the pins came seperately.
Thanks,
Paul
Old 08-09-2006, 11:52 AM
2005 Toyota 4Runner
no problem
LinkBack to this Thread: http://www.tundrasolutions.com/forums/audio-and-stereo/57507-e7007-8-sienna-nav-into-2006-a/
Posted By For Type Date
99-02 4runner fog light pre-wiring - YotaTech Forums This thread Refback 05-10-2009 10:10 PM
Propane vs gasoline? - YotaTech Forums This thread Refback 05-01-2009 02:37 PM
Toyota Corolla Air Bag System, Toyota Corolla Acessories Fog Light Covers, Toyota Corolla All Wheel Drive - Championenergy This thread Refback 03-08-2009 11:16 AM
Toyota Sienna Repair Manual, Toyota Sienna Power Window Repair, Toyota Sienna Review - Cartrader This thread Refback 03-08-2009 09:17 AM
Orange + Red?? Yuck!! (How to change gauge colors) - Page 26 - Toyota Forums :: Toyota Nation This thread Refback 02-04-2009 07:50 PM
2005 Toyota Tundra HID Retrofit Progress - Toyota Forums :: Toyota Nation This thread Refback 11-20-2008 10:03 AM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 04-19-2008 12:38 PM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 10-20-2007 08:45 PM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 10-16-2007 11:44 AM
SiennaClub.org Forums > Service manual for E7007 unit This thread Refback 09-23-2007 12:46 AM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 09-05-2007 01:39 PM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 09-02-2007 08:39 AM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 08-13-2007 05:25 PM
Service manual for E7007 unit - SiennaClub.org Forums This thread Refback 08-13-2007 08:23 AM
E7007 - SearchMapr (beta) - Visual Web Searching This thread Refback 07-12-2007 07:56 PM
