2007 Camry Factory Radio Removal
+ Reply to Thread
Results 1 to 9 of 9
Thread: 2007 Camry Factory Radio Removal
  1. #1
    Join Date
    Jun 2006
    Location
    Cambridge
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default 2007 Camry Factory Radio Removal
    Just purchased a 2007 Camry SE. I am going to replace the factory radio with an aftermarket Alpine system. Currently there are no radio kits available but I am told by my local car radio supplier that it should not be much longer.
    My question is regarding the removal of the factory radio. Has anyone had the opportunity to remove there radio? If so, I would appreciate any tips that you may offer on the removal process.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jun 2006
    Location
    Los Angeles, CA
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default Re: 2007 Camry Factory Radio Removal
    I just pulled the JBL head unit from my 07 Hybrid to add the XM satellite radio. Procedure is pretty straight forward:
    1. Remove the top center air vent assembly. It comes straight out but there are clips along the top and bottom seams. Disconnect harness.
    2. Remove shift knob and the shift console cover by gently pulling up to release clips. Take your time so you don't break any of the plastic pieces.
    3. Remove shift console top cover trim by gently pulling up. Note harness.
    4. Remove the vertical trim columns to the right and left of the storage box (that is below the climate controls) by pulling straight out - again releasing clips.
    5. The space behind the vertical trim columns will reveal screws that hold down the storage box. Remove the screws and partially pull out the box. Note harness.
    6. (Steps 2 thru 5 are necessary to gain access to two bottom bolts securing the bottom of the head unit/climate control assembly) Remove the two bottom bolts.
    7. (Step 1 gains access to two top bolts securing the top of the head unit/climate control assembly) Remove the two top bolts.
    8. Slide head unit/climate control assembly out. Disconnect harnesses.
    Before you start - disconnect the negative battery terminal and set your shifter as far back as possible. Good luck.
  4. #3
    Join Date
    May 2006
    Location
    las vegas,NV
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Did your HYBRID have the nav unit or the base unit
  5. #4
    Join Date
    Sep 2007
    Location
    San Jose, CA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I am getting ready to do the exact same thing. Where did you put the XM antenna?
  6. #5
    Rookie ncalmike76's Avatar
    Join Date
    Nov 2007
    Location
    Sacramento,CA
    Posts
    7
    Liked
    0 times
    Rep Power
    0
    Any diagrams available for this? Or is it pretty str8 forward as mentioned?
    Join Date
    Feb 2008
    Location
    VA
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Can you give me a PDF file?
    Thanks
    colmeq@yahoo.com
  8. #7
    Rookie boomcar's Avatar
    Join Date
    Aug 2008
    Location
    Richmond Hill, Ontario
    Posts
    3
    Liked
    0 times
    Images
    14
    Rep Power
    0
    Would any modification/personal installation to upgrade speakers or head unit void the warranty of the car? Does anyone know?
  9. #8
    Supporter millsp's Avatar
    Join Date
    Jul 2007
    Location
    Fort Lauderdale FL
    Age
    45
    Posts
    1,323
    Liked
    1 times
    Images
    39
    Rep Power
    9
    Quote Originally Posted by boomcar View Post
    Never. Unless you damaged something in the install and it can be proved that your work did the damage. Even then only the item you damaged would not have the coverage.
    TundraSolutions.com Forum Rules
    Classified Forum Rules
    What is Rep Power? read more HERE!
    Florida Panthers Season Ticket Holder! Sweet!
  10. #9
    Join Date
    Aug 2008
    Location
    Posts
    3
    Liked
    0 times
    Images
    14
    Rep Power
    0
    Quote Originally Posted by radams View Post
    I got these step by step pics from someone else, I found it very helpfull. Just type the "http://www.toyotanation.com/forum/showthread.php?t=236753" address and you should get it.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 2007 Camry XLE PRICE
    By usrbzk in forum Pricing and Dealers
    Last Post: 03-23-2006, 07:29 PM
  2. Toyota Environmental Update - Toyota introduces 2007 Camry Hybrid
    By nhparrot in forum Toyota, Scion & Lexus News
    Last Post: 02-20-2006, 12:04 PM
  3. Factory Bedliner Removal
    By Amocat00 in forum Interior & Exterior
    Last Post: 05-27-2004, 05:55 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
