Old 08-29-2002, 01:34 AM
Dealer : Durant Toyota
2003 Toyota Tundra
Last Online: 09-24-2008 11:27 AM
4cranch is on a distinguished road.
4cranch's Photo Albums
Question Stereo Wiring Difference (Sequoia vs. Tundra)
Have an '02 Sequoia and recently aquired an '02 Tundra 6cd stereo head unit to replace the basic 3 in 1 single stereo unit.
Found that the plugs didnt match as I figured they would. Anyone come across this that can suggest a simple alternative...or is there a harness adapter to be had?
Old 08-29-2002, 06:43 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Today 11:27 AM
nhparrot's Photo Albums
What didn't match the connector coming from the amp to the HU, or the 2 connectors that plug into the amp?
~Glenn
Old 08-29-2002, 03:55 PM
bomber's Avatar
Dealer : Cobb County Toyota Scion
Last Online: 06-29-2009 10:45 PM
bomber is on a distinguished road.
bomber's Photo Albums
I did this in my Tundra. Plugs don't match? Are you trying to install the JBL amp or are you using your existing amplifier? On the standard Tundra amplifier, the cable that you need to use the JBL amplifier is terminated inside, i.e., no plug. The simple solution is to use the exisiting or standard amplifier with the 6 CD changer. Hope this helps.
bomber
Old 08-29-2002, 04:32 PM
2003 Toyota Tundra
The wiring plugs from the amp to HU dont match.
I am using the original amp and wiring to the new HU... This makes sense now, I'll need to change the amp too I suppose. I just assumed the the wiring would all be the same.
Thanks guys.
Old 11-29-2005, 07:38 PM
2002 Toyota Tundra
Last Online: 12-03-2005 07:22 PM
Dumaine is on a distinguished road.
Dumaine's Photo Albums
Default connect me please
Ok sorry but I am lost......
I have a 2002 Tundra, and bought a Sequioa 6 disc cd player on ebay.
connections dont match on the back of the radio.
I read the above posts, and admit I still dont understand how to adapt this.
Old 11-29-2005, 07:57 PM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
Who do the connections look like on the Tundra radio (# of connectors & number of pins for each) and on the Sequoia radio (# of connectors & number of pins for each)?
What year Sequoia is it out of?
~Glenn
Old 11-29-2005, 08:06 PM
2002 Toyota Tundra
suposed to be a 2000 Sequoia
the Sequoia pin connectors look like small needles
the tundras pins are flat and wide
20, 12 and 20 pins on the Sequioa conectors.
12, 10 and 6 pins on the Stock Tundra.
Old 11-29-2005, 08:31 PM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
(I can tell you the Tundras in the Morning, have to remove it.)
Sequoia Model # is 86120-0c121
Tundra Model # is (in the morning)
The Sequoia radio needs an external amp. Your Tundra maybe the type with a built-in amp. The Tundra radio with an internal amp will have a 6, 10 & 12 pin connectors. A Tundra radio with an external amp will be like the Sequoia with a 20, 12 & 20 pin connectors.
~Glenn
