Installing Motorola hf850 hands free Bluetooth car kit in 05 Tundra
NEWS
+ Reply to Thread
Results 1 to 10 of 10
Thread: Installing Motorola hf850 hands free Bluetooth car kit in 05 Tundra
  1. #1
    Junior Member T100_2_TUNDRA is on a distinguished road. T100_2_TUNDRA's Avatar
    Join Date
    Jan 2006
    Location
    Portsmouth, VA
    Posts
    170
    Liked
    0 times
    Rep Power
    7
    Default Installing Motorola hf850 hands free Bluetooth car kit in 05 Tundra
    I've just ordered a hands free cellular kit from Newegg, the Motorola HF850 model. I haven't got it yet and will post a review and installation summary when I get to the job in a week or so. It calls for professional installation, but looking over some of the documentation I can find, most of the job looks pretty straightforward. One thing I am not sure of is the connection to the radio to mute the audio when a call comes in. It talks about an orange wire going to the radio for this mute function. Does anybody know if Toyota radios support this? My truck has the non-JBL 6 CD changer with the separate amp. The unit can operate without the mute function, but it sure would be nice if I can implement it.
    Here is the link to the unit if anybody's interested:
    MOTOROLA HF850 Bluetooth Car Kit - Retail at Newegg.com
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra is a splendid one to behold. Bluethundra's Avatar
    Join Date
    Dec 2005
    Location
    Sugar Hill, Ga
    Age
    32
    Posts
    416
    Liked
    0 times
    Rep Power
    13
    Default Re: Installing Motorola hf850 hands free Bluetooth car kit in 05 Tundra
    I am not sure if the factory radio will have it. I know it is pretty much standard on aftermarket radio's.
  4. #3
    Join Date
    Jan 2006
    Location
    Portsmouth, VA
    Posts
    170
    Liked
    0 times
    Rep Power
    7
    Thread Starter
    I found some general references and they dont mention a yellow or orange wire to mute the radio. The installation guide talks about using a bosch type relay to cut ignition power to the radio to mute it. May be more trouble than its worth, can always turn the radio knob down when the phone rings.
  5. #4
    Rookie fredmertz is on a distinguished road. fredmertz's Avatar
    Join Date
    Jun 2004
    Location
    Orange County, CA
    Posts
    13
    Liked
    0 times
    Images
    2
    Rep Power
    0
    T100_2_TUNDRA,
    I have the JBL stereo , im not sure if they are the same ( as non-JBL) , but I installed a Samsung Bluetooth kit in my 2004 Tundra Double cab. My stereo has the mute wire I believe it was yellow . . If I find out any more info I willl let you know.
    FM
    2004 Double Cab- Phantom Gray-SR5-2WD
    Samsung Bluetooth Car Kit
    Bilstein BTS Coil Overs w/spacers
    T/C UCA
    XM Radio
  6. #5
    Join Date
    Jan 2006
    Location
    Portsmouth, VA
    Posts
    170
    Liked
    0 times
    Rep Power
    7
    Thread Starter
    I started the install yesterday. Not a hard job at all. Here is the kit with all the parts:
    I mounted the control to the left of the steering wheel. It has a self adhesive tape on the back. I routed the wire down through the gap on the steering column.
    The speaker I mounted at the bottom of the dash with two scews into the bottom of the dash plastic.
    I mounted the electronics box under the center of the steering column since proximity to the phone is key to having it work well. Bluetooth doesnt have all that much range. The microphone I mounted to the left of the driver in the trim over the door and routed the wire down to the footwell.
    Finally,Here is a shot of the box with all the connections.
    I'm still not done with the truck. I made the ignition connection to one of the 12v outlets. Finding a battery connection is tougher. Thats todays part of the project. I have tested the unit and it works well with my phone.
  7. #6
    Rookie mit_peid is on a distinguished road.
    Join Date
    Apr 2006
    Location
    Los Angeles, CA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Any updates on installing the HF850? I just ordered it from amazon.com and am anxiously awaiting its arrival for installation into my '05 4Runner with an AVN5435. Were you able to find the 'orange' wire? Is the speaker loud enough below the steering column?
  8. #7
    Veteran Member dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold. dibble9012 is a splendid one to behold.
    Join Date
    Jul 2006
    Location
    na
    Posts
    1,519
    Liked
    1 times
    Images
    11
    Rep Power
    16
    be careful hooking it up to the 12v plugs. On the newer toyotas the plugs stay active for I think 2 hours after the truck is turned off
    This means that your cell could still be connected to the truck when you get out of the truck and lets say, sitting in your office (depending on how close to the truck your office is.)
  9. #8
    Rookie jumong69 is on a distinguished road.
    Join Date
    Jun 2007
    Location
    van
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Quote Originally Posted by T100_2_TUNDRA View Post
    Did you ever find and connected the battery connection (the red wire on your hf-850)? (Not the ignition connection ((green)). Do you think connecting just ground wire and ignition(green) wire will make hf-850 to work? I do not understand why you need to connect the red wire to v12 battery connection.. I thought the ignition green wire is enough to operate.
    Thank you.
  10. #9
    Join Date
    Jun 2007
    Location
    van
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    UPDATE: you have to connect all the wires to work. I have installed it yesterday. Everything is working great! Still need to figure out how to connect it to car speakers...
  11. #10
    Lurking Member bmann7 is on a distinguished road.
    Join Date
    Sep 2006
    Location
    Seattle, WA
    Posts
    48
    Liked
    0 times
    Images
    1
    Rep Power
    6
    ANY UPDATES? I will be attempting the same installation this weekend (possibly) and would LOVE some tips/best practices etc. Where did you get power for the system? Did you ever get the auto-mute feature to work? What about getting the sound to come from the truck speakers (so as to skip using hte Motorola one)?
    Thank you!
  1. K&n Gen Ii Intake Kit
    By nhparrot in forum Engine & Drivetrain
    Last Post: 07-06-2006, 08:19 PM
  2. BOOSTED TUNDRA Supercharger Kit Fits 00-06 Tundra
    By rwelsh in forum 1Gen-Tundra
    Last Post: 10-26-2005, 06:00 AM
  3. Replies: 0
    Last Post: 09-16-2004, 04:05 PM
  4. Question about stock Tundra Foglights..Help!
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
