Speed sensor wire
+ Reply to Thread
Results 1 to 5 of 5
Thread: Speed sensor wire
  1. #1
    Supporter banyadog has disabled reputation
    Join Date
    Mar 2006
    Location
    Clackamas,OR
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Default Speed sensor wire
    Sup Guys,
    Does anyone know what color the speed sensor wire is for my 2005 tundra ec. Got a superlift unit (calibrater) and wondering what and where on the tranny to tap into?
    thanks, the dog
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Mar 2006
    Location
    Clackamas,OR
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Default Re: Speed sensor wire
    Sup Guys,
    Does anyone know what color the speed sensor wire is for my 2005 tundra ec. Got a superlift speed sensor unit (calibrater) and wondering what color and where on the tranny to tap into?
    thanks, the dog
  4. #3
    Junior Member rizico is on a distinguished road. rizico's Avatar
    Join Date
    Sep 2003
    Location
    LULING, TX
    Age
    30
    Posts
    267
    Liked
    0 times
    Images
    3
    Rep Power
    10
    Noticed you were a subscriber, that means you have access to the wiring diagram specific for your truck, I could tell you what color it is for the 03' ac, but it might not be the same. Look at the wiring diagram for your truck, find the gage cluster, and look for the wire labeled "SPD" or "spd sense", you get the idea. Then map the wire back to the tranny.
    EDIT: I just looked at my book, and it might not be that simple, but and my truck it is yellow with a red runner @ the ECM, but good luck anyway, gottag go, will check back.
    2007 Tundra CrewMax 4X4 Limited
  5. #4
    Join Date
    Mar 2006
    Location
    Clackamas,OR
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks,
    Yes I have looked at the diagram, and I did locate the wire it is yelow w/ a red stripe. what I wanted to do was connect it at the ect connector wire harness at the plug. I found some plugs behind the glove box but cant find the right color wire. That way everything would be inside the cab. What do you think?
  6. #5
    Join Date
    Sep 2003
    Location
    LULING, TX
    Age
    30
    Posts
    267
    Liked
    0 times
    Images
    3
    Rep Power
    10
    Inside is better. When I had to tie in for my GPS HU, I went behind the gage cluster an tapped into the Speed sensor wire there. You could do that and just run it a few feet to where you need it. I did read after my install, that some tundras were pre-wired for factory GPS units, this means there would be an unised male plug bhind the radio that has a speed sensor wire running into it, I have not looke back there since my install to verify this, but it's worth a shot. Good Luck!
  1. 05 TUNDRA Max Speed is 103 mph???
    By Nzo in forum 1Gen-Tundra
    Last Post: 02-09-2009, 01:53 PM
  2. Dynamic Laser Cruise Control
    By TS Support in forum Toyota, Scion & Lexus News
    Last Post: 09-20-2006, 06:07 PM
  3. Electric Fan w/ Variable Speed Controller Installed...
    By bamachem in forum Engine & Drivetrain
    Last Post: 06-16-2005, 09:41 AM
  4. Grinding while switching from 2wd to 4wd
    By harkeyjt in forum Engine & Drivetrain
    Last Post: 08-06-2004, 03:05 PM
  5. Best Speed For Optimal Fuel Efficiency
    By jdoherty in forum Engine & Drivetrain
    Last Post: 01-28-2004, 07:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
